Code Red => VB(A) => Topic started by: jnieman on July 16, 2008, 06:18:55 PM
Title: Create and Populate Autocad Table
Post by: jnieman on July 16, 2008, 06:18:55 PM
Does anyone know where I can find some good information about various controls and commands for creating/editting a table object in Autocad?
I'm creating a routine that will populate a table with X,Y coordinates for each instance of a certain block that's inserted into a drawing numerous times.
I have the coordinate extraction part down, I just need to know how to pass that information to a table that I create.
I searched through the Autodesk VBA book but it excludes tables altogether regarding object creation, and did some googling for a while, as well as searching these forums... I found some that almost help, but fell decidedly short.
Does anyone have a snippet I could examine or some functions I can look for?
The visual basic reference from the help menu is not being too helpful either (or I don't know the right place to look)
Title: Re: Create and Populate Autocad Table
Post by: Spike Wilbury on July 16, 2008, 06:35:45 PM
Here is one:
http://www.theswamp.org/index.php?topic=9730.0
It is ARX but might be easy to port (don't know) - but I guess you will end up moving or trying to use C# instead.
There are some .NET samples in the ARX SDK.... over here: www.objectarx.com
Post by: jnieman on July 16, 2008, 06:51:14 PM
Thanks for the help, Luis, I got some good information that's already helped me.
Also, embarrassingly enough, I... was looking in the help accessed via the visual basic editor, and wow... big difference if you use the developer's help accessed from the main Autocad window!
*slams forehead on keyboard*
The entry for "Autocad table object" is quite robust.
Post by: fixo on July 17, 2008, 09:16:54 AM
Here is Q&D example but this will get
you started
Option Explicit
Sub Blocks_Table()
    Dim oSset As AcadSelectionSet
    Dim oEnt As AcadEntity
    Dim oBlk As AcadBlockReference
    Dim varPt As Variant
    Dim ftype(0) As Integer
    Dim fdata(0) As Variant
    Dim bName As String
    Dim xStr As String
    Dim yStr As String
Dim i As Long, j As Long
    ftype(0) = 0: fdata(0) = "INSERT"
    Dim dxfCode, dxfValue
    dxfCode = ftype: dxfValue = fdata
    With ThisDrawing.SelectionSets
        While .Count > 0
            .Item(0).Delete
        Wend
        Set oSset = .Add("$Blocks$")
    End With
    oSset.SelectOnScreen dxfCode, dxfValue
    Dim oSpace As AcadBlock
    If ThisDrawing.ActiveSpace = acModelSpace Then
        Set oSpace = ThisDrawing.ModelSpace
    Else
        Set oSpace = ThisDrawing.PaperSpace
    End If
    varPt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Specify insertion point: ")
    Dim oTable As AcadTable
    Set oTable = oSpace.AddTable(varPt, oSset.Count + 2, 3, 10, 30)
    ZoomExtents
    With oTable
    .RegenerateTableSuppressed = True
        .SetCellTextHeight i, j, 5
        .SetCellAlignment i, j, acMiddleCenter
        .SetCellType i, j, acTextCell
        .SetText 0, 0, "Blocks Position"
        .SetText 1, j, "Block Name"
        .SetCellTextHeight 1, j, 4.5
        .SetText 1, j + 1, "X"
        .SetCellTextHeight 1, j + 1, 4.5
        .SetText 1, j + 2, "Y"
        .SetCellTextHeight 1, j + 2, 4.5
        For i = 0 To oSset.Count - 1
            Set oEnt = oSset.Item(i)
            Set oBlk = oEnt
            If oBlk.IsDynamicBlock Then
                bName = oBlk.EffectiveName
            Else
                bName = oBlk.Name
            End If
            xStr = Format(CStr(Round(oBlk.InsertionPoint(0), 3)), "#0.000")
            yStr = Format(CStr(Round(oBlk.InsertionPoint(1), 3)), "#0.000")
            .SetCellTextHeight i, j, 4
            .SetText i + 2, j, bName
            .SetCellTextHeight i + 2, j, 4#
            .SetText i + 2, j + 1, xStr
            .SetCellTextHeight i + 2, j + 1, 4#
            .SetText i + 2, j + 2, yStr
            .SetCellTextHeight i + 2, j + 2, 4#
        Next i
    .RegenerateTableSuppressed = False
    .Update
    End With
    MsgBox "done"
~'J'~
Post by: jnieman on July 17, 2008, 09:35:28 AM
you started
~'J'~
I just stepped through that and it has all the function that I require... I have the most trouble using selection sets but I think once I go through this and figure out what's doing what... I should be in good shape.
I appreciate this very much, you've helped me a great deal!
Post by: fixo on July 17, 2008, 10:42:25 AM
You're welcome
Cheers :)
~'J'~
Post by: jnieman on July 17, 2008, 10:43:16 AM
I must thank you again fixo, you've been a godsend for this.  The last hour I've spent on this was more productive than the 8 hours on and off I spent from the beginning!!  (although I'm sure those beginning hours were needed to understand what was going on, this much)
I am having some trouble with my table creation.  I'm trying to not have a single-column top row.  I wish for it to be un-merged as the rest of the table is.  I cannot see or find what it is in the definitions that make the top row into a single cell, rather than a cell for each column.
I can't figure it out.  I've only learned how to merge cells using the "object.MergeCells(minRow, maxRow, minCol, maxCol) " method.
Option Explicit
Sub Blocks_Table()
    Dim bName As String
    Dim xStr As String
    Dim yStr As String
        While .Count > 0
            .Item(0).Delete
        Wend
    End With
    ThisDrawing.ActivePViewport.Display True
    ThisDrawing.ActiveSpace = acPaperSpace
    Dim paSpace As AcadPaperSpace
    Set paSpace = ThisDrawing.PaperSpace
    Set oTable = paSpace.AddTable(varPt, oSset.Count + 2, 5, 0.3, 1.5)
    ZoomExtents
    With oTable
        .SetCellTextHeight i, j, 0.09375
        .SetText 0, j, "ITEM"
        .SetCellTextHeight i, j + 2, 0.09375
        .SetText 0, j + 2, "EQUIPMENT DATUM"
        .SetCellTextHeight i, j + 4, 0.09375
        .SetText 0, j + 4, "DATUM LOCATION"
        .SetText 1, j + 1, "N"
        .SetCellTextHeight 1, j + 1, 0.09375
        .SetText 1, j + 2, "E"
        .SetCellTextHeight 1, j + 2, 0.09375
        .SetText 1, j + 3, "EL"
        .SetCellTextHeight 1, j + 3, 0.09375
            Set oBlk = oEnt
            Else
                bName = oBlk.Name
            End If
            xStr = Format(CStr(Round(oBlk.InsertionPoint(1), 3)), "#0.000")
            yStr = Format(CStr(Round(oBlk.InsertionPoint(0), 3)), "#0.000")
            .SetText i + 2, j, "-ID #-"
            .SetCellTextHeight i + 2, j, 0.09375
            .SetCellTextHeight i + 2, j + 1, 0.09375
            .SetCellTextHeight i + 2, j + 2, 0.09375
        Next i
    .Update
    End With
    MsgBox "done"
(also, interesting side note... FF3 crashed consistently when trying to paste the code directly from the VBA Manager in acad... I pasted it to notepad, and copied it over here successfully however.)
Post by: jnieman on July 17, 2008, 03:08:32 PM
Oh man, I'm not thinking 'outside the box'
It's set that way because the first row is of "Title" type in the table style.  I assumed it defaulted to a "data" type, but since it's a title, it spans the whole table by default... it's not in the code, but the active table style  *smacks forehead*
Now I gotta figure out how to set the first row as 'data' type, as opposed to title or header, now...
Post by: fixo on July 17, 2008, 04:16:42 PM
Glad you soved it by yourself
so I can rest :)
~'J'~
Post by: jnieman on July 17, 2008, 04:25:19 PM
Fixo, I don't think you realize how much you're helping me today, beyond the post above!
Many times I have searched for how to get a certain thing to work (such as merging cells, amongst others) and doing a search on the Swamp has revealed that you already explained it to someone :-D
Your vba guidance on this forum is excellent!
I'm currently having trouble extracting the value of a defined attribute within that block, for placing into this same table... but I'm not given up quite yet.
Post by: jnieman on July 17, 2008, 05:03:37 PM
ok I ended up giving up :(
I've looked over so many examples of people using GetAttributes that I cannot figure out what is going on... the help file does not seem to be very helpful, for me, either.
Below is the code I have so far.
The block I am going to be using for this table has a 3 or 4 attributes in it that hold information that will be passed to this table.
Tags:
ID
ELEVATION
DATUMLOC
DESC
I need to get the value for each individual attribute/tag and output it to a table cell exactly how I am doing with xStr and yStr as you have showed me.
Option Explicit
Sub Blocks_Table()
    Dim bName As String
    Dim Atts As Variant
    Dim xStr As String
    Dim yStr As String
    Dim ID As String
    Dim Desc As String
        While .Count > 0
            .Item(0).Delete
        Wend
    End With
    Set oTable = paSpace.AddTable(varPt, oSset.Count + 3, 6, 0.3, 1.5)
    oTable.TitleSuppressed = False
    oTable.HeaderSuppressed = True
    ZoomExtents
    With oTable
        .SetCellTextHeight i, j, 0.15625
        .SetText 0, 0, "EQUIPMENT LAYOUT SCHEDULE"
        .SetText 1, 0, "ITEM"
        .SetCellTextHeight 1, 0, 0.09375
        .SetText 1, 1, "EQUIPMENT DATUM"
        .SetCellTextHeight 1, 1, 0.09375
        .SetText 1, 4, "DATUM LOCATION"
        .SetCellTextHeight 1, 4, 0.09375
        .SetText 1, 5, "DESCRIPTION"
        .SetCellTextHeight 1, 5, 0.09375
        .SetText 2, 1, "N"
        .SetCellTextHeight 2, 1, 0.09375
        .SetText 2, 2, "E"
        .SetCellTextHeight 2, 2, 0.09375
        .SetText 2, 3, "EL"
        .SetCellTextHeight 2, 3, 0.09375
            Set oBlk = oEnt
            Else
                bName = oBlk.Name
            End If
            .SetCellTextHeight i + 3, j, 0.09375
            .SetCellAlignment i + 3, j, acMiddleCenter
            .SetText i + 3, j, ID
            .SetText i + 3, j + 1, xStr
            .SetCellTextHeight i + 3, j + 1, 0.09375
            .SetText i + 3, j + 2, yStr
            .SetCellTextHeight i + 3, j + 2, 0.09375
            .SetText i + 3, j + 3, Desc
            .SetCellTextHeight i + 3, j + 3, 0.09375
        Next i
    .Update
    End With
        oTable.MergeCells 1, 2, 0, 0
        oTable.MergeCells 1, 2, 4, 4
        oTable.MergeCells 1, 2, 5, 5
        oTable.MergeCells 1, 1, 1, 3
    MsgBox "Yahoooooo!"
Post by: jnieman on July 17, 2008, 05:04:14 PM
Right now I have not set a value to ID or DESC, but I'm not sure how to even do so.
Post by: fixo on July 17, 2008, 05:21:17 PM
Upload your sample drawing with blocks
(delete unused information and other things before)
I'll look at it tomorrow
~'J'~
Post by: jnieman on July 17, 2008, 05:31:07 PM
Here is everything necessary.
From what it seems... I think my problem is that I don't know how to handle arrays to get the information I need :(
test.dwg
Contains the block "DATUM" in model space in a variety of instances.
I select all those blocks during the routine, it switches to paperspace, asks for the insertion point of the table, and then creates it.
I just don't know how to get the value of the attributes and then put them into the table.
Thank you very much for your time!
Post by: jnieman on July 17, 2008, 06:43:08 PM
fixo!
Please do not spend any more of your time on me!
JeffM gave me the final push in understanding what's going on with GetAttributes that I wasn't able to understand.
http://www.theswamp.org/index.php?topic=24004.0 is where I have the final entire code.
if you have comments, lessons, advice, I welcome it, but I won't ask any more of your time for this... you've done quite a lot already and I owe the success to you (and Jeff M) for sure!
Post by: fixo on July 18, 2008, 05:47:30 AM
Jeff M is my teacher too :)
Sorry I could not be able to explain the things
that you asked for becuase of my poor English level
Better yet I will to write the code you need :)
and Jeff M will explain it much better :)
(Change the text height, layout name etc to your suit)
Private Sub MakeTableStyle()
' creates a TableStyle object
     Dim oDict As AcadDictionary
     Dim aColor As New AcadAcCmColor
     Dim oTblSty As AcadTableStyle
     Dim sKeyName As String
     Dim sClassName As String
     'grab the tablestyle dictionary object
     Set oDict = ThisDrawing.Database.Dictionaries.Item("acad_tablestyle")
     sKeyName = "Block Table"
     sClassName = "AcDbTableStyle"
     'create the TableStyle object in the dictionary
     Set oTblSty = oDict.AddObject(sKeyName, sClassName)
     With oTblSty
          .Name = "Block Table"
          .Description = "Style For The Block Info"
          .HorzCellMargin = 0.03
          .SetTextHeight 3, 0.93625
          .SetGridVisibility 3, 3, True
          .SetAlignment 3, acMiddleCenter
          aColor.SetRGB 244, 0, 0
     End With
Sub BlockToTable()
     Dim fstRef As AcadBlockReference
     Dim blkRef As AcadBlockReference
     Dim bname As String
     Dim attVar() As Object
     Dim attObj As AcadAttributeReference
     Dim row As Long, col As Long
     Dim tmpStr As String
     Dim attColl As Collection
     Dim acCol As New AcadAcCmColor
     On Error GoTo Err_Control
     If ThisDrawing.ActiveSpace = acPaperSpace Then
     End If
     On Error Resume Next
     ThisDrawing.Utility.GetEntity oEnt, varPt, vbCrLf & "Select block to import data to table"
     If Err Then
          Err.Clear
     End If
     On Error GoTo 0
     If Not oEnt Is Nothing Then
          If TypeOf oEnt Is AcadBlockReference Then
               Set blkRef = oEnt
          End If
     End If
     If Not blkRef.HasAttributes Then
          MsgBox "This block does not have an attributes"
          Exit Sub
     End If
     If blkRef.IsDynamicBlock Then
          bname = blkRef.EffectiveName
     Else
          bname = blkRef.Name
     End If
     Dim ftype(1) As Integer
     Dim fdata(1) As Variant
               While .Count > 0
                    .Item(0).Delete
               Wend
          End With
     ftype(0) = 0: ftype(1) = 2
     fdata(0) = "INSERT": fdata(1) = bname
     oSset.Select acSelectionSetAll, , , dxfCode, dxfValue
     MsgBox oSset.Count
     Set oEnt = oSset.Item(0)
     Set fstRef = oEnt
     attVar = fstRef.GetAttributes
     ReDim tmp(0 To UBound(attVar) + 1) As String
     Set attColl = New Collection
     tmp(0) = "Block Name"
     For i = 0 To UBound(attVar)
     tmp(i + 1) = attVar(i).TagString
     Next
     attColl.Add tmp, "headers"
     For j = 1 To oSset.Count
     Set oEnt = oSset.Item(j - 1)
     Set blkRef = oEnt
     attVar = blkRef.GetAttributes
     tmp(0) = bname
     tmp(i + 1) = attVar(i).TextString
     Next
     attColl.Add tmp, "row " & CStr(j)
     Next j
     Call MakeTableStyle
     ThisDrawing.ActiveLayout = ThisDrawing.Layouts("C-02") '<--change the tab name here
     DoEvents
     Dim pt As Variant
     pt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Pick the upper left point of table:")
     Set oTable = ThisDrawing.PaperSpace.AddTable(pt, oSset.Count + 2, UBound(tmp) + 1, 2.5, 10)
     oTable.RegenerateTableSuppressed = True
     oTable.HorzCellMargin = 0.03
     oTable.HeaderSuppressed = False
     oTable.SetTextHeight 7, 0.18
     row = 0
     col = 0
     acCol.SetRGB 143, 189, 164
     tmpStr = "Block Attributes Info"
     oTable.SetRowHeight row, 0.25
     oTable.SetCellTextHeight row, col, 0.18
     oTable.SetCellBackgroundColor row, col, acCol
     acCol.SetRGB 173, 43, 0
     oTable.SetCellContentColor row, col, acCol
     oTable.SetText row, col, tmpStr
     oTable.SetCellAlignment row, col, acMiddleCenter
     row = 1
     For i = 0 To UBound(tmp)
          acCol.SetRGB 236, 237, 238
          oTable.SetCellTextHeight row, i, 0.15
          oTable.SetCellBackgroundColor row, i, acCol
          acCol.SetRGB 0, 0, 180
          oTable.SetCellContentColor row, i, acCol
          tmpStr = attColl.Item(1)(i)
          If i <> UBound(tmp) Then
          oTable.SetColumnWidth i, 2#
          Else
          oTable.SetColumnWidth i, 3#
          End If
          oTable.SetText row, i, tmpStr
          oTable.SetCellAlignment row, i, acMiddleCenter
     Next
     For row = 2 To attColl.Count
     oTable.SetRowHeight row, 0.21
          oTable.SetCellTextHeight row, i, 0.12
          tmpStr = attColl.Item(row)(i)
          Else
          End If
     Next
     Next
     oTable.RegenerateTableSuppressed = False
     Set acCol = Nothing
Err_Control:
If Err.Number <> 0 Then
MsgBox Err.Description
End If
~'J'~
Post by: jnieman on July 18, 2008, 10:12:50 AM
Wow, that's some great additions!
The error handling is so simple and easy to understand... that was one of the things I planned on adding in as I go, so thank you for saving me from searching for a solution.
I read through it all, slowly, and you've given me some extra tools to use, thank you.
I like how  you changed how I counted attributes.  Before I had to set a new integer (c) to count with, rather than using the previous (i) because I did not know how to add the attributes, and it was giving me wrong output when I tried.  I knew my method was not the best, so thank you for showing me the right way.
I have one question though.  I am currently trying to find a solution.  How can I take the array of object in a selection set... and reverse the order?
To explain:  When it creates the table, it places the information starting with the block I placed LAST, and then descending in order to the block I placed FIRST... I wonder: is there a way to reverse the order it reads the attributes and dxf codes as it loops?  I guess I'm wanting to loop in reverse order.  I've tried a couple guesses but they've failed.
Post by: Jeff_M on July 18, 2008, 12:07:12 PM
This small change will do that, Josh. The code between the first & last lines is all I modified. This Steps thru the SS from the end to the the beginning.
'<snip>
     Dim idx As Integer
     idx = 0
     For j = oSset.Count To 1 Step -1
        Set blkRef = oEnt
        tmp(0) = bname
        Next
        idx = 1 + idx
        attColl.Add tmp, "row " & CStr(idx)
     Next j
     Call MakeTableStyle
'<snip>
Post by: Jeff_M on July 18, 2008, 12:12:20 PM
FYI, your method was just fine, based on the example I showed you. What ~'J'~ did was streamline how the table data was added to it which, in turn, changed how the data was gathered. That is why he was able to re-use the counter. Note that he still used 2 counters, though, I & J, just in different ways. :-)
Post by: jnieman on July 18, 2008, 12:15:08 PM
Ah, I see, then, Jeff.  I guess when I used another integer I thought that there must've been a more elegant way, but did not push too hard for elegance, since I'm a beginner.
I don't have time for now to get the reverse put in there, but will add that in soon.  I was approaching the method of counting wrong.
Thanks again to both of you for the extremely helpful guidance and support.  Couldn't have done this without you guys.
