Code Red => AutoLISP (Vanilla / Visual) => Topic started by: John Kaul (Se7en) on September 26, 2003, 11:15:36 AM
I was wondering if anyone had any code that would return the path of the selected xref? ...I tell ya what. Let me just tell you what i want and you tell me if you have the whole thing or just peices.
I want a tool for reloading an xref. If i select it, i want it to reload.
I also want a tool for returning th path of that xref.
Any code out there?
I might. Let me see. Yep. Here's an old one. Please forgive it's ugliness.
;;;reloads xrefs by selecting the xref.
(defun c:xre ()
(setq cme (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq xref
(car (entsel
"\nSelect referenced object to reload or <Enter>: "
) ;_ end of entsel
) ;_ end of car
) ;_ end of setq
(if (= xref nil)
(command ".xref" "reload" "*")
(princ "\nAll xref's have been reloaded.")
) ;_ end of progn
(setq xreload (cdr (assoc 2 (entget xref))))
(command ".xref" "reload" xreload)
(princ (strcat "\n" xreload " reloaded."))
) ;_ end of progn
) ;_ end of if
(setvar "cmdecho" cme)
) ;_ end of defun
It doesn't tell you the path, but hey, you wanted something that was said and done.
Thank you sir.
Daron -
Great program...One thing I noticed, is that when I tried reloading a small topo file, I was kicked out of LDD...It didn't really like that, but all well...not like I am changing my topo very often.
Rug
