Code Red => .NET => Topic started by: It's Alive! on October 26, 2007, 01:55:17 AM
Does anyone know why Autodesk chose not to mark some of the basic types
such as Point3d, Point2d, ObjectId, etc [Serializable] ?
Insomniac response so it's probably way out to lunch but - perhaps because they are all primitive data types the overhead / bloat isn't justifiable, in particular because of the cascaded effect upon the object model greater.
http://msdn2.microsoft.com/en-us/library/ms979193.aspx
Hi Daniel .. I'm playing guessing games as well, but Michael's conjecture seems to make sense.
... I'd also guess that the serialization would need to be purpose specific'
.. .. from memory very few of the library classes are Serializable.
There is a .net sample in the ObjectARX SDK called TestFiler.cs demonstrating Object dumping ... but there probably won't be much new stuff there for you :-)
sorry I can't be of help.
Thanks for the replies. I’ll just wrap the objects I need serialized in new serializable objects and/or breakout the primitives I need stored.
My guess would be is seeing that acad looks after serialisation itself and the .net lib's are just a wrapper/interface to the 'real' objects it wasn't required...from their point of view of course.
Having a little fun here
//(Serialize "c:\\test.dat" "hola")
//(Serialize "c:\\test.dat" '(1 1 1))
//(Serialize "c:\\test.dat" '(1 2 3 1.2 "Wow This is almost cool"))
//(UnSerialize "c:\\test.dat")
//(SaveVars "c:\\test.dat")
//(RestoreVars "c:\\test.dat")
//(defun savevars (path / outlist varlist)
// (setq outlist '())
// (setq varlist '("osmode" "cmdecho" "attdia" "pickstyle"))
// (foreach e varlist
// (setq outlist (cons (cons e (getvar e)) outlist))
// (Serialize path outlist)
//(defun RestoreVars (path / e inlist)
// (setq inlist (UnSerialize path))
// (if (/=(car inlist) nill)
// (foreach e inlist
// (setvar (car e)(cdr e) )
// (princ)
using System;
using System.Runtime.Serialization;
using System.IO;
using System.Runtime.Serialization.Formatters.Binary;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(LispSerialization.Commands))]
namespace LispSerialization
public class Commands
public Commands()
[LispFunction("Serialize")]
static public ResultBuffer dome(ResultBuffer Rb)
ResultBuffer RetRb = new ResultBuffer();
try
TypedValue[] tvArray = Rb.AsArray();
Stream stream = new FileStream((string)tvArray[0].Value, FileMode.Create);
try
List<KeyValuePair<int, Object>>
kvList = new List<KeyValuePair<int, object>>();
for (int i = 1; i < tvArray.Length; i++)
switch ((int)tvArray[i].TypeCode)
case (int)LispDataType.Point2d:
Point2d pt = (Point2d)tvArray[i].Value;
kvList.Add(new KeyValuePair<int, object>
((int)LispDataType.ListBegin, null));
((int)LispDataType.Double, pt.X));
((int)LispDataType.Double, pt.Y));
((int)LispDataType.ListEnd, null));
break;
case (int)LispDataType.Point3d:
Point3d pt = (Point3d)tvArray[i].Value;
((int)LispDataType.Double, pt.Z));
break;
case (int)LispDataType.Angle:
case (int)LispDataType.DottedPair:
case (int)LispDataType.Double:
case (int)LispDataType.Int16:
case (int)LispDataType.Int32:
case (int)LispDataType.ListBegin:
case (int)LispDataType.ListEnd:
case (int)LispDataType.Nil:
case (int)LispDataType.None:
//case (int)LispDataType.Orientation:
case (int)LispDataType.T_atom:
case (int)LispDataType.Text:
case (int)LispDataType.Void:
((int)tvArray[i].TypeCode, (object)tvArray[i].Value));
break;
IFormatter formatter = new BinaryFormatter();
formatter.Serialize(stream, kvList);
RetRb.Add(new TypedValue((int)LispDataType.T_atom));
finally
stream.Close();
catch
RetRb.Add(new TypedValue((int)LispDataType.Nil));
return RetRb;
[LispFunction("UnSerialize")]
static public ResultBuffer undome(ResultBuffer Rb)
Stream stream = null;
try
stream = new FileStream((string)tvArray[0].Value, FileMode.Open);
List<KeyValuePair<int, Object>> kvList =
(List<KeyValuePair<int, Object>>)formatter.Deserialize(stream);
for (int i = 0; i < kvList.Count; i++)
RetRb.Add(new TypedValue(kvList[i].Key, kvList[i].Value));
catch
finally
stream.Close();
return RetRb;
