Code Red => .NET => Topic started by: T.Willey on June 12, 2007, 02:52:01 PM
Title: DeSelect current selectin set from Tool Palette
Post by: T.Willey on June 12, 2007, 02:52:01 PM
I have code that will make a tool palette, and fill it with combo boxes and put one button on it.  I use the current selection set to populate the tool palette (single block with attributes).  Everything works fine except that I can't figure out how to deselect the objects once the button is pushed.  Any help/comments are appreciated.
Thanks in advance.
Question in reference to here. (http://www.theswamp.org/index.php?topic=16861.0)  Posting new thread because this question may get lost in the other one.
I have seen this method posted on the Adesk Ng, but didn't work for me.
PromptSelectionResult psr = Doc.Editor.SelectImplied();
psr = null;
Title: Re: DeSelect current selectin set from Tool Palette
Post by: Paul Richardson on June 12, 2007, 03:07:38 PM
Thanks in advance.
psr = null;
Tim - I think I'm the one who posted that code... Strange it does work for me. I just tried this on a block
with references and it works here. Maybe another way to do it?
Editor ed =
    Autodesk.AutoCAD.ApplicationServices.Application.
        DocumentManager.MdiActiveDocument.Editor;
PromptSelectionResult psr = ed.SelectImplied();
psr = null;
Post by: T.Willey on June 12, 2007, 03:19:43 PM
That didn't work either Paul.  I think the issue is trying to deselect from the tool palette.  Did you get it to work from a tool palette?
Post by: LE on June 12, 2007, 03:29:53 PM
Hey Tim;
How about using: SetImpliedSelection()
ed.SetImpliedSelection(new ObjectId[0]);
Post by: T.Willey on June 12, 2007, 03:37:55 PM
Hey Tim;
Build error.
error CS1501: No overload for method 'SelectImplied' takes '1' arguments
c:\Program Files\Autodesk\Acade 2006\acmgd.dll: (Location of symbol related to previous error)
Doc.Editor.SelectImplied(new ObjectId[0]);
Man this is frustrating.
Edit:
Now using the correct code.  Man, still get build error.
error CS0117: 'Autodesk.AutoCAD.EditorInput.Editor' does not contain a definition for 'SetImpliedSelection'
On Acad '06
Post by: LE on June 12, 2007, 03:42:15 PM
Hey Tim;
Build error.
Count to 10... 9 8 7 6 5 4 3 2 1 0...
I simple posted from memory, don't have my vs open....
Post by: LE on June 12, 2007, 03:57:30 PM
It is working here, as far as I see it...
       public static  void onDocBecameCurrent(object sender, DocumentCollectionEventArgs e)
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            ed.SetImpliedSelection(new ObjectId[0]);//clear first any selection
            if (!ps.Visible) return;
            PromptSelectionResult psr = e.Document.Editor.SelectImplied() as PromptSelectionResult;
            //if (psr == null) return;
            SelectionSet ss = psr.Value as SelectionSet;
            if (ss != null && ss.Count > 0) FillInControl(ss.GetObjectIds());
            else if (ps.Count > 0) ps.Remove(0);
Post by: Paul Richardson on June 12, 2007, 03:58:31 PM
I haven't tried...
Post by: T.Willey on June 12, 2007, 04:02:02 PM
What version are you testing on?
Post by: LE on June 12, 2007, 04:03:01 PM
2007
Post by: T.Willey on June 12, 2007, 04:04:07 PM
2007
Must be new to 2007 because I get a build error when trying it with 2006.
Post by: LE on June 12, 2007, 04:09:58 PM
no idea Tim.
this is what I see on the object browser:
Post by: LE on June 12, 2007, 04:17:08 PM
In case is not there, do you know how to use P/Invoke? (because I do not)... that function is a wrapper from the ARX functions of:
acedSSSetFirst()
acedSSFree()
Post by: T.Willey on June 12, 2007, 05:00:07 PM
acedSSSetFirst()
acedSSFree()
If this is the only way in .Net (for '06), then I guess I better learn about P/Invoke.  Thanks for the heads up Luis.  I'll see what I can find.
Edit: Found this link. (http://through-the-interface.typepad.com/through_the_interface/2006/07/calling_objecta.html)  Reading it now.
Post by: Paul Richardson on June 12, 2007, 08:05:55 PM
acedSSSetFirst()
acedSSFree()
For now you could try this - until you master P/Invoke...:)
 object o = AcadApp.GetSystemVariable("Pickfirst");
 AcadApp.SetSystemVariable("Pickfirst", o);
Post by: Glenn R on June 13, 2007, 01:11:14 AM
Something like this perhaps:
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedSSSetFirst")]
private static extern int acedSSetFirst(long[] pset, long[] unused);
[CommandMethod("SetFirstTest", CommandFlags.UsePickSet | CommandFlags.Redraw | CommandFlags.Modal)]
static public void SetFirstTestCommand( ) {
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
try {
PromptSelectionResult prs = ed.SelectImplied();
if(prs.Status != PromptStatus.OK)
return;
SelectionSet ss = prs.Value;
ed.WriteMessage("\nNumber of selected objects: {0}", ss.Count);
acedSSetFirst(null, null);
} catch(System.Exception ex) {
ed.WriteMessage(ex.Message);
Completely untested of course :)
Cheers,
Glenn.
Post by: Paul Richardson on June 13, 2007, 08:34:52 AM
try {
return;
Cheers,
Glenn.
Glenn, Do you know why most of the names are mangled but some not?
Thanks.
Post by: It's Alive! on June 13, 2007, 08:58:04 AM
I know you asked Glenn, but… :-P
The function was probably exported as a global function for ARX, but not yet wrapped for .NET
Post by: Glenn R on June 13, 2007, 09:07:58 AM
It has to do with the c++ compiler, function exports and name collisions wrt the vtable AFAIK.
Cheers,
Glenn.
Post by: Paul Richardson on June 13, 2007, 09:40:04 AM
Well... I meant anyone with the answer...~) Thanks...
Post by: Paul Richardson on June 13, 2007, 09:41:33 AM
Cheers,
Glenn.
Danka... Just curious.
Post by: T.Willey on June 13, 2007, 11:19:51 AM
This doesn't look like it will happen anytime soon.  :-)  I didn't understand the article on first read, so I have to reread it when I have more time to comprehend it.
This worked nicely.  I will post the full code in the other thread as that is where it is posted now.
Thanks Paul!
Post by: T.Willey on June 13, 2007, 11:33:47 AM
try {
return;
Cheers,
Glenn.
Thanks for the example Glenn.  I will try and understand it when I have more time later today.
Edit: May take more time than I originally thought. =D  Need to study up on DllImport.
Post by: T.Willey on June 13, 2007, 06:56:31 PM
Thanks Glenn that worked with one small correction.  The function name is 'SSSetFirst', with three 's'.
I have the program 'depends', and I see the call to 'SSSetFirst' within there, but the entry point is a number.  How do I know which one to use (for future situations)?
Post by: Glenn R on June 13, 2007, 07:11:33 PM
Tim,
The function name was correct in my code (look at the entrypoint)...I just dropped an 'S' in my alias of it, which doesn't matter (you could it anything you want).
I use "Dumpbin /E" on the file and redirect it's output to a text file...that will give you all the names.
Glenn.
Post by: T.Willey on June 13, 2007, 07:22:38 PM
Tim,
I thought I looked there first.  Must have thought you named them all the same.  :wink:
Glenn.
I think that is how Kean said to do it on his blog (nope, but something like this method).  I was hoping there would be an easier way.
Thanks again.
Post by: Paul Richardson on June 13, 2007, 10:11:58 PM
Tim,
Glenn.
Thanks again.
To use Fenton's method save the batch as findfile.bat (or whatever you like) to your acad root. Using VS comamnd prompt call as such - findfile.bat functionname If you want to write to a text file use the redirection operator as stated findfile.bat functionname > text.txt. This is slow so be patient...
Edit: Browse (cd) to the acad root in the command line tool before running.
