Code Red => VB(A) => Topic started by: Harun KILIC on April 11, 2007, 01:35:09 PM
If a dwg file saved when a layout tab was active, even if Acad it self can not show the thumbnail preview.
I set accuracy value to max level from Thumbnail Preview Settings in Acad2007, then able to get the preview.
But for each file I have to open it and make this setting. Also earlier releases do not have this setting.
BUT, I need to get the preview of a Layout Tab in any dwg file as thumbnail, using VB6.0
Is it possible, is there anybody to inform me?
Thanks.
Really need help..
P.S.:
I'm using dwgthumbnail.ocx 2.0
I have performed a search in the forums but can not get something similar..
Thanks ASMI.. :-)
Maybe this will help??!?
Thanks. Using API..
It is just doing the same as the ocx file does. The problem is Acad sometimes misses something while saving preview info, then you have to open each file and resave it. No more chance I think..
But I could not succed to convert the code in order to paint inside an image or a picture object.. so it is not usefull for me in this condition.
Thanks a lot.
lngHwnd = FindWindow(vbNullString, Me.Caption)
lngDc = GetDC(lngHwnd)
'I thought this was a nice touch..
Me.Caption = strFile
'Clean any old paint off..
Me.Repaint
Just open and save each file with VB. This should help you get the files (Credit to James Crowley for most of this code.):
Module stuff
Option Explicit
Private Declare Function apiShellExecute Lib "shell32.dll" _
Alias "ShellExecuteA" _
(ByVal hwnd As Long, _
ByVal lpOperation As String, _
ByVal lpFile As String, _
ByVal lpParameters As String, _
ByVal lpDirectory As String, _
ByVal nShowCmd As Long) _
As Long
Public Type BROWSEINFO
hOwner As Long
pidlRoot As Long
pszDisplayName As String
lpszTitle As String
ulFlags As Long
lpfn As Long
lParam As Long
iImage As Long
End Type
Public Type SHITEMID 'mkid
cb As Long 'Size of the ID (including cb itself)
abID As Byte 'The item ID (variable length)
End Type
Type ITEMIDLIST 'idl
mkid As SHITEMID
End Type
Public Declare Function SHGetPathFromIDList Lib "shell32.dll" Alias "SHGetPathFromIDListA" (ByVal pidl As Long, ByVal pszPath As String) As Long
Public Declare Function SHGetSpecialFolderLocation Lib "shell32.dll" (ByVal hwndOwner As Long, ByVal nFolder As Long, pidl As ITEMIDLIST) As Long
Public Declare Function SHBrowseForFolder Lib "shell32.dll" Alias "SHBrowseForFolderA" (lpBrowseInfo As BROWSEINFO) As Long
Public Const BIF_RETURNONLYFSDIRS = &H1
Public Const BIF_DONTGOBELOWDOMAIN = &H2
Public Const BIF_STATUSTEXT = &H4
Public Const BIF_RETURNFSANCESTORS = &H8
Public Const BIF_BROWSEFORCOMPUTER = &H1000
Public Const BIF_BROWSEFORPRINTER = &H2000
Private Declare Function apiGetSystemDirectory& Lib "Kernel32" _
Alias "GetSystemDirectoryA" _
(ByVal lpBuffer As String, ByVal nSize As Long)
Private Declare Function apiGetWindowsDirectory& Lib "Kernel32" _
Alias "GetWindowsDirectoryA" _
Public Declare Function GetAsyncKeyState Lib "user32.dll" (ByVal vKey As Long) As Integer
'***App Window Constants***
Public Const WIN_NORMAL = 1 'Open Normal
Public Const WIN_MAX = 3 'Open Maximized
Public Const WIN_MIN = 2 'Open Minimized
Private Const MAX_PATH As Integer = 255
'***Error Codes***
Private Const ERROR_SUCCESS = 32&
Private Const ERROR_NO_ASSOC = 31&
Private Const ERROR_OUT_OF_MEM = 0&
Private Const ERROR_FILE_NOT_FOUND = 2&
Private Const ERROR_PATH_NOT_FOUND = 3&
Private Const ERROR_BAD_FORMAT = 11&
Private Declare Function SetWindowPos Lib "user32" (ByVal hwnd As Long, _
ByVal hWndInsertAfter As Long, ByVal X As Long, ByVal y As Long, ByVal Cx As Long, _
ByVal Cy As Long, ByVal wFlags As Long) As Long
Form stuff
Option Explicit
Private Sub cmdIBrowse_Click()
Dim selectFolder As String
Dim bi As BROWSEINFO
Dim idl As ITEMIDLIST
Dim rtn&, pidl&, path$, pos%
' set the type of folder to return
' play with these option constants to see what can be returned
bi.ulFlags = BIF_RETURNONLYFSDIRS 'BIF_RETURNFSANCESTORS 'BIF_BROWSEFORPRINTER + BIF_DONTGOBELOWDOMAIN
' show the browse folder dialog
pidl& = SHBrowseForFolder(bi)
' if displaying the return value, get the selected folder
' If Check1 Then
path$ = Space$(512)
rtn& = SHGetPathFromIDList(ByVal pidl&, ByVal path$)
If rtn& Then
' parce & display the folder selection
pos% = InStr(path$, Chr$(0))
selectFolder = Left(path$, pos - 1)
Else
selectFolder = ""
End If
Private Sub cmdOBrowse_Click()
' If Check1 Then
path$ = Space$(512)
If rtn& Then
Else
selectFolder = ""
End If
Private Sub cmdCancel_Click()
Unload Me
Private Sub cmdGO_Click()
Dim FileCountx As Integer
Dim FilesArray() As String
Dim inpath As String
Dim OutPath As String
Dim teststring1 As String
Dim teststring2 As String
Dim MyFilename As String
Dim MyOldFilename As String
Dim MyNewFilename As String
Dim AddText As String
Dim RemoveText As String
FilesArray = GetFiles(inpath)
FileCountx = -1
For FileCountx = LBound(FilesArray) To UBound(FilesArray)
MsgBox MyFilename
'open the file, set the active doc and save it, switch the active doc back, open the next and save and so on.
'you can add code to go to a layout in paperspace/modelspace, zoom extents, whatever you need.
Next
Unload Me
Sub Main()
Private Sub Form_Load()
Populate
Private Sub Populate()
Dim S As String
Dim PathIName As String
Dim SlashPos As Integer
Dim PathOName As String
'add some form code here
Function GetFiles(ByVal FullPath As String) As String()
Dim FileName As String
Dim num_files As Integer
num_files = -1
Dim file_name As String
If Right(FullPath, 1) <> "\" Then FullPath = FullPath & "\"
FullPath = FullPath & "*.*"
file_name = Dir(FullPath, vbNormal)
Do While Len(file_name) > 0
If FileName <> "." And FileName <> ".." Then
num_files = num_files + 1
ReDim Preserve FilesArray(0 To num_files)
FilesArray(num_files) = file_name
End If
' Get the next file.
file_name = Dir$()
Loop
GetFiles = FilesArray
'the array is filled
End Function
