Code Red => AutoLISP (Vanilla / Visual) => Topic started by: John Kaul (Se7en) on September 23, 2003, 01:55:00 PM
Title: vl-dll1.fas
Post by: John Kaul (Se7en) on September 23, 2003, 01:55:00 PM
Ive built a sorta .dll for visual lisp. It isnt anything special, but i was wondering who wanted a copy? This is one of my new projects, and i was hoping to set a couple of these. One for each area like strings, lists, and stuff. This is the general one. (and you guys will be my testers.)
How to use. Include this in your startup suite (or however you do it) and you can call these functions in any of your lisps. (Mostly just the ones for your quick needs, unless you want to use this in your program development and distribute it over a network, etc.)  Its compiled in a "fas" format so you can add this to any "vlx" you compile for distribution.
Here is whats in it.
Include: Use this to include a file for your lisp's. It could be a
         utlity file you need or just a need to call another lisp file.
vl-UndoBegin: Use this to set an undo mark.
vl-UndoEnd: Use this to set an undo mark.
*ThisDrawing*: Pointer to active Document.
*Acad-Object*: Pointer to Acad application.
*ModelSpace*: Pointer to Modelspace.
*PaperSpace*: Pointer to PaperSpace.
dll-ver: Returns the version number of the fas
dll-authour: Returns a string of the author of this fas file.
IsLoaded: Checks to see if a function is loaded by its name.
        - Usage: (IsLoaded '("vl-load-com"))
vl-dll1-dump: Dumps all functions included in this ".fas" file.
Title: vl-dll1.fas
Post by: Mark on September 23, 2003, 02:49:48 PM
OH HECK YEA, SEND ME THAT
Title: vl-dll1.fas
Post by: daron on September 23, 2003, 05:28:00 PM
Yeah that^. Now, what I came here for in another thread.
