Code Red => .NET => Topic started by: DBARANAS on October 21, 2006, 03:14:35 AM
Title: Palettes Revisited
Post by: DBARANAS on October 21, 2006, 03:14:35 AM
During the last few months I have been exploring the ways to get my apps GUI to be efficeint and slick. When I was a CAD monkey I had to endure to torture of navigating through menu structures in plain Autocad. In a production environment trying to crank out drawings everyday do the same things over and over again (navigating menus) gets boring and painful.
Recently I ran across this:
http://www.codeproject.com/cs/miscctrl/TgXPPanel.asp?df=100&forumid=59468&exp=0&select=1337707 (http://www.codeproject.com/cs/miscctrl/TgXPPanel.asp?df=100&forumid=59468&exp=0&select=1337707)
This control is not yet implemented in VS.....but it ROCKS!!!!!
Put this in a palette and it changes everything. I had to tweek it up a bit by killing off the other panels when I clicked on the panel I wanted to display. Now I have the same thing as the tabs in the stock palette but I don't have read sideways when I want to go somewhere else. Think of the user doing this all day long :ugly:
The guy that wrote this should be given a .Net hero award.
The next thing I would like to happen is to get rid of the menu structure in Autocad and not even see it anymore.
Here is what I am so happy about.
Title: Even Better
Post by: DBARANAS on October 21, 2006, 03:35:21 AM
OverRiding the Right Click event when an object is selected and displaying what is exactly available to the user has got to speed things up.  :lol:
Imports System
Imports System.Windows.Forms
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports AcAp = Autodesk.AutoCAD.ApplicationServices.Application
Imports AcOp = Autodesk.AutoCAD.Interop
Imports AcRu = Autodesk.AutoCAD.Runtime
Public Class AcadDocumentRightClick
    Private _AcadDocument As AcOp.AcadDocument
    Public Sub RightClick()
        If _AcadDocument Is Nothing Then
            _AcadDocument = CType(AcAp.DocumentManager.MdiActiveDocument.AcadDocument, _
            Autodesk.AutoCAD.Interop.AcadDocument)
            AddHandler _AcadDocument.BeginRightClick, AddressOf _AcadDocument_BeginRightClick
        Else
            RemoveHandler _AcadDocument.BeginRightClick, AddressOf _AcadDocument_BeginRightClick
            _AcadDocument = Nothing
        End If
    Private Sub _AcadDocument_BeginRightClick(ByVal PickPoint As Object)
        Dim MdiActiveDocument As Document = AcAp.DocumentManager.MdiActiveDocument
        Dim GetSelection As PromptSelectionResult = MdiActiveDocument.Editor.GetSelection()
        Using DocumentLock As DocumentLock = MdiActiveDocument.LockDocument()
            If GetSelection.Status <> PromptStatus.OK Then Return
            If GetSelection.Value.Count <> 1 Then Return
            Dim ObjectId As ObjectId = GetSelection.Value(0).ObjectId
            Using Transaction As Transaction = MdiActiveDocument.TransactionManager.StartTransaction()
                Dim DBObject As DBObject = Transaction.GetObject(ObjectId, DatabaseServices.OpenMode.ForWrite)
                Dim Entity As Entity = TryCast(DBObject, Entity)
                If Entity Is Nothing Then Return
                Dim RightClickWall As New frmRightClickWall
                AcAp.ShowModalDialog(RightClickWall)
                Transaction.Abort()
            End Using
        End Using
End Class
Public Class AcadDocumentDoubleClick
    Private _AcadDocument As Autodesk.AutoCAD.Interop.AcadDocument
    Public Sub DoubleClick()
            AddHandler _AcadDocument.BeginDoubleClick, AddressOf _AcadDocument_BeginDoubleClick
        Else
            RemoveHandler _AcadDocument.BeginDoubleClick, AddressOf _AcadDocument_BeginDoubleClick
        End If
    Private Sub _AcadDocument_BeginDoubleClick(ByVal PickPoint As Object)
        Dim SelectImplied As PromptSelectionResult = MdiActiveDocument.Editor.SelectImplied()
            If SelectImplied.Status <> PromptStatus.OK Then Return
            If SelectImplied.Value.Count <> 1 Then Return
            Dim ObjectId As ObjectId = SelectImplied.Value(0).ObjectId
                Dim Entity As Entity = TryCast(GetObject(), Entity)
                Dim DBDictionary As DBDictionary = Transaction.GetObject(Entity.ExtensionDictionary(), _
                DatabaseServices.OpenMode.ForWrite, False)
                Dim Xrecord As Xrecord
                Xrecord = Transaction.GetObject(DBDictionary.GetAt("EntityData"), DatabaseServices.OpenMode.ForRead)
                Dim ObjectType As TypedValue = Xrecord.Data.AsArray(0)
                Dim MyObjectID As TypedValue = Xrecord.Data.AsArray(1)
                Select Case ObjectType.Value
                    Case "Wall"
                        Walls.Adjust(Walls.Find(Walls.ID), Enu.Adjust.UnHighlite)
                        Dim Wall As _Wall = Walls.Find(MyObjectID.Value)
                        Walls.ID = Wall.ID
                        ctlProject.PropertyGrid1.SelectedObject = WallItems
                        ctlProject.SplitContainer2.Panel2Collapsed = True
                        Walls.Adjust(Wall, Enu.Adjust.Highlite)
                End Select
                Transaction.Commit()
            End Using
        End Using
End Class
Title: Re: Palettes Revisited
Post by: Kerry on October 21, 2006, 03:55:46 AM
Dave .. is this acceptable as used ?
ditto for
I haven't had a real chance to look at the code, but just as a matter of interest, why do you use so much Com ?
Which Acad version is this for ?
Post by: Kerry on October 21, 2006, 03:58:48 AM
The Menu's look really interesting ..
Post by: DBARANAS on October 21, 2006, 04:03:05 AM
Hi Kerry
It seems to work. Mostly I can get away with naming things like the type they belong to.
It makes for easily readable code. In a few instances it thows up and I have to pick a new name for the instance of the object I am trying to create.
Post by: Kerry on October 21, 2006, 04:10:39 AM
I may misunderstand ..
DBObject is the base type for objects stored in the AutoCAD database.
.. how can you use a variable named the same and declare it's type to be the same as the name you are using .. ?
.. this may be an indicator of my lack of familiarity with VBNet.
Post by: Kerry on October 21, 2006, 04:13:35 AM
what happens if you add Option Strict << or whatever >> to the head of your code ??
.. or is that Option Explicit ?
Post by: DBARANAS on October 21, 2006, 04:14:58 AM
This if for 2k7 and If I can lose the COM I will do it too.
I ran across another UCS post in the AD group that solves my Twist UCS problem that also uses COM.  I think we are on the rough edge now and I have to suck a few things up and get on with finishing my project. I came here 4 months ago as a .Net newbe with a finished project in VBA except it leaked tons of memory and I could never even finish a project before things would crash and burn.
The whole .Net way and OOP has changed my whole view of things, I have basically rewritten my app in 4 months after 3 years of pain...either I am going to win or hang myself
Post by: DBARANAS on October 21, 2006, 04:21:46 AM
[/quote
Kerry I might be way off the wall with this naming convention stuff but the code runs and when I debug things it is easy to read.
I have been though camel,pascal, and my own conveluted abortion naming conventions.
It works and I do not have any project team supporting me...I am totally on my own trying to deliiver a product. I come at everything like an idiot, I only got as far a grade 8 in school. So I have hacked my way through every problem
Post by: Kerry on October 21, 2006, 04:23:29 AM
I think we are on the rough edge ...
hehehehe
.. bleeding edge actually ..
.. either I am going to win or hang myself ..
yeah, I know the feeling. :-)
Post by: Kerry on October 21, 2006, 04:28:57 AM
Heh :-) Dave, I know about the hacking stuff .. suck it and see <- thats me.
I'm just surprised the compiler will let you use variables names the same as Autodesk classes ... a real puzzle to me. Perhaps I recall incorrectly, and as I said, VB is NOT my language.
Post by: DBARANAS on October 21, 2006, 04:33:12 AM
Hey Kerry
I have not heard "Bleeding Edge" for the last 10 years!!!!!
I lived on it for 20 years...maybe I should check my pulse and see if there is any blood left inside.  :lmao:
Post by: DBARANAS on October 21, 2006, 04:47:23 AM
Anyway this naming convention scheme I have hit upon might seem different, but when I read lines of code when I have to debug things I know exactly what that line means without having to use any mental thought.
Just like I said about being a CAD monkey drafting doing the same things repetively and how that becomes a drag, being a CODE monkey I can eliminate that mental thought every time I look at a line of code that is cacking up that I wrote so long ago I can't even remember exactly why I even wrote it.
Maybe I am going to smash into a wall soon by doing this, but for now I am driving a race car with 600HP under the hood. :evil:
Post by: DBARANAS on October 21, 2006, 05:06:23 AM
BTW when I get my app finished this is the 600HP crash/pass car my company sponsers that I helped build and will get to have fun with :lol:
Post by: Kerry on October 21, 2006, 05:27:31 AM
OMG !! is that an 10" steel channel bolted to the body
[see, I do know what an inch is :-) ]
Post by: DBARANAS on October 21, 2006, 05:44:25 AM
Kerry go here:
http://www.saratogaspeedway.bc.ca/ (http://www.saratogaspeedway.bc.ca/)
Road Rage to its extreme. This is just 30km south of my factory. You gotta love Vancouver Island. Even Bill gates bought an island up here.
