Code Red => AutoLISP (Vanilla / Visual) => Topic started by: CADworker on August 19, 2020, 02:22:06 PM
I'm looking for some help on how to get this working. I've been searching and found an older post, located here: https://www.theswamp.org/index.php?topic=42488.msg476831#msg476831 (https://www.theswamp.org/index.php?topic=42488.msg476831#msg476831). I would like to be able to do a table search for multiple layers and change their colors respectively but ignore those layers that don't exist. I need to be able to search for layers and change their color inside of a viewport for color plotting. This is what I have so far but it only works on one layer.
(defun c:try ()
(command "Tilemode" 0 "pspace")
(setvar "TileMode" 0)
(command "._MSPACE")
(setq UserVP (entsel "\nSelect Viewport to work on:"))
(COMMAND "._vplayer" "C" "137" "PL-V*HIDD" "select" uservp "" "")
(princ))
(defun c:OvrCol (/ en match)
(setq match "PL*V*HIDD") ;Save the wildcard match, since it's used more than once
(cond ((CheckLayerExists match)
(command "._PSPACE")
(if (progn (princ "\nSelect vieports: ")
(setq uservp (ssget '((0 . "VIEWPORT")))))
(command "._VPLAYER" "_Color" 137 match "_Select" uservp "" "")
(princ "\nNo viewports selected.")))
((princ (strcat "\nNo layers matching " match " exists, routine stopped."))))
(princ))
I would like to find other layers such as "PL-W*HIDD" and change the color to 46.
P.S. I'm somewhat new to LISP coding.
Any help would be appreciated.
Look into
(foreach match '("PL*V*HIDD" "ABCD" "XYZ")
Setting a Layer State inside a viewport creates viewport overrides for the layers defined in them by default.
Select an object on each of those layers, copy them to a blank drawing, modify the layer colors , create a Layer State which would only contain those layers, export to a las file and import it into drawings and templates as needed. Switching viewport overrides or simply removing them is just as easy.
I have a handful of Layer States in my templates I use every day. You have to make sure "Turn off layers not found in layer states" is unchecked so it doesn't turn off all the other layers. I've added(vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\AcLayerApps:LayerStatesManager") "LayerNotFound" "0")
to my acaddoc.lsp to make sure it's unchecked when a drawing is opened.
You do need to open the Layer States Manager to set them though. Using the Layer States ribbon drop-down or lisp functions ignore the Layer States Manager settings and would turn off all the other layers.
Thanks for the input.
BIGAL could you guide me on how to use the "foreach match"? I believe this sets each found layer to a variable, my question is how do I use that and change the layers respectively. Again, I'm somewhat new to lisp and I'm not familiar with the foreach function.
