Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Marc'Antonio Alessi on October 21, 2019, 03:27:39 PM
Example: DWG with LayerA - LayerB - LayerC - etc.
I can print a PDF file for each layer, question: how can I print in a single PDF file with multiple pages?
Various solutions have been put forward some depending on the pdf writer, I use Ghostscript which has an option to join pdf,s
This examples plots layouts and then joins them back together.
You could print single pdfs, then merge them and delete the original pdf files.
http://www.theswamp.org/index.php?topic=53974.msg586248#msg586248
Thanks to all, I had looked for "multi pages", I had to look for "merge"... :uglystupid2:
