Code Red => .NET => Topic started by: latour_g on October 16, 2015, 11:03:22 AM
I'm looking for a way to get the command line window text in AutoCAD 2014.
I found this (http://adndevblog.typepad.com/autocad/2012/06/how-to-obtain-the-command-line-window-text-using-objectarx.html) but I don't want to use ObjectArx.
I only need the last line, as shown in the attached image.
Thank you
Autodesk.AutoCAD.Internal.Utils.GetLastCommandLines(int, bool)
Thanks a lot !
