Code Red => AutoLISP (Vanilla / Visual) => Topic started by: mkweaver on September 19, 2015, 12:49:08 PM
I'm working on a couple of subroutines to add xdata to an entity. Everything works fine until I do the ENTMOD, which fails. Here is the entity data for the line to which I'm trying to add the xdata.
((-1 . <Entity name: 7ff785c04e60>)
(0 . "LINE")
(330 . <Entity name: 7ff785c039f0>)
(5 . "1E6")
(100 . "AcDbEntity")
(67 . 0)
(410 . "Model")
(8 . "0")
(100 . "AcDbLine")
(10 14.5179 15.4665 0.0)
(11 25.7092 14.1183 0.0)
(210 0.0 0.0 1.0)
And the list I'm sending to ENTMOD:
(0 . "LINE")
(5 . "1E6")
(67 . 0)
(410 . "Model")
(8 . "0")
(100 . "AcDbLine")
(210 0.0 0.0 1.0)
(-3 ("MyApp"
(1002 . "{")
(1000 . "KEY1")
(1000 . "Value1")
(1002 . "}")
(1002 . "{")
(1000 . "KEY2")
(1000 . "Value2")
(1002 . "}")
ENTMOD returns NIL. There must be something wrong with the xdata, but I'm not seeing it.
Suggestions?
Thanks,
Mike
Is "MyApp" registered? (regapp "MyApp")
Mike,
Your data is ok, so has to be what Lee suggested
that is you must issue (regapp "MyApp") before
attempting the entmod.
(defun c:test ()
(regapp "MyApp")
(setq entl (entget (car (entsel)))
xdta '((-3 ("MyApp"
(1002 . "{")
(1000 . "KEY1")
(1000 . "Value1")
(1002 . "}")
(1002 . "{")
(1000 . "KEY2")
(1000 . "Value2")
(1002 . "}")
newl (append entl xdta)
(entmod newl)
$ (c:test)
((-1 . <Entity name: 7ffff43db90>) (0 . "LINE") (330 . <Entity name: 7ffff43f9f0>) (5 . "1D1") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbLine") (10 14.4366 5.4871 0.0) (11 27.3359 13.0912 0.0) (210 0.0 0.0 1.0) (-3 ("MyApp" (1002 . "{") (1000 . "KEY1") (1000 . "Value1") (1002 . "}") (1002 . "{") (1000 . "KEY2") (1000 . "Value2") (1002 . "}"))))
_$
That was it - I hadn't registered the app name.
Thanks!
