Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Marc'Antonio Alessi on February 20, 2015, 05:04:44 AM
1) (ssget "_X" ...) can not be used in ObjectDBX doc
2) (ssget "_X" ...) is much faster
Question: under normal conditions (activedocument) it is better to use (ssget "_X" ...) or is there a faster method?
(setq *AcAcDwg* (vla-get-activedocument (vlax-get-acad-object)))
(defun ALE_Block_GetInserts1 (VlaDoc LayNms BlkNms / OutLst Vl_Tms)
(setq Vl_Tms (car (_vl-times)))
(vlax-for LayFor (vla-get-layouts VlaDoc)
(if (wcmatch (strcase (vla-get-name LayFor)) (strcase LayNms))
(vlax-for ObjFor (vla-get-block LayFor)
(and
(= (vla-get-objectname ObjFor) "AcDbBlockReference")
(wcmatch (vla-get-Name ObjFor) BlkNms)
(setq OutLst (cons ObjFor OutLst))
; OutLst
(- (car (_vl-times)) Vl_Tms)
(defun ALE_SSGetInserts ( / Vl_Tms)
(ssget "_X" '((0 . "INSERT") (2 . "FOO*")(410 . "Model")))
Command: (ALE_SSGetInserts)
187
Command: (ALE_Block_GetInserts1 *AcAcDwg* "Model" "FOO*")
9422
Using vlax-for provides direct access to the vla-object representations of objects in the layout, whereas the required conversion using vlax-ename->vla-object whilst iterating over the selection set returned by ssget can be slow if I recall correctly.
For a better comparison, I would use:
(defun ALE_SSGetInserts ( / Vl_Tms sel idx lst )
(if (setq sel (ssget "_X" '((0 . "INSERT") (2 . "FOO*") (410 . "Model"))))
(repeat (setq idx (sslength sel))
(setq lst (cons (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))) lst))
For a better comparison, I would use: ...
I agree but there is not much difference:
(ALE_Block_GetInserts1 *AcAcDwg* "Model" "FOO*") => 10577
(ALE_SSGetInserts) => 359
(ALE_SSGetInsertsLee) => 312
(ALE_SSGetInsertsLee) => 281
(ALE_SSGetInserts) => 328
(Sslength (ssget "_X" '((0 . "INSERT") (2 . "FOO*") (410 . "Model"))))
=> 252
(Sslength (ssget "_X" '((0 . "INSERT") (2 . "*") (410 . "Model"))))
=> 4146
(Sslength (ssget "_X" '((410 . "Model"))))
=> 108256
Hi
If you want work With (ssget "x") and vlisp, you can use vla-get-activeselectionset
For example
(defun c:test
(/ blo doc sel
Hi
For example...
Thanks, I do not want work With (ssget "x") but to know if (ssget "x") is the best/faster method to get a SelSet or a list of Vla Objects...
Yes, ssget with activeselectionset is the best
( / Vl_Tms doc sel
(and (ssget "_X" '
((0 .
"INSERT") (2 .
"FOO*") (410 .
"Model"))) )
Not much difference:
Comando: (ALE_SSGetInsertsLee) 203
Comando: (ALE_SSGetInsertsP35) 343
Comando: (ALE_SSGetInsertsLee) 312
Comando: (ALE_SSGetInsertsP35) 328
Comando: (ALE_SSGetInsertsP35) 374
Comando: (ALE_SSGetInsertsLee) 374
Comando: (ALE_SSGetInsertsLee) 359
About half the time if executed on the same file opened in ObjectDBX:
; DbxDoc > ObjectDBX.AxDbDocument
(ALE_Block_GetInserts1 DbxDoc "Model" "FOO*") => 6630
(ALE_Block_GetInserts1 DbxDoc "Model" "FOO*") => 6833
(ALE_Block_GetInserts1 DbxDoc "Model" "FOO*") => 6896
I've had some trouble with the activeselectionset method in the past (an intermittent and inconsistent error: Automation Error. Calling method Clear of interface IAcadSelectionSet failed) and have now abandoned this method entirely.
Precisely why I abandoned its use as well.
Why is that again guys? can you enlighten us more on this issue?
I had the same problem that I solved using systematically erasing the selection. Since then, no problems. Now all my lisps use this method.
Look at the two lisps I posted
I would also delete the selection set [ (vla-delete sel) ] after processing, but this did not seem to resolve the issue; or are you referring to something else when you say 'solved using systematically erasing the selection'?
I am unsure exactly why the error occurs, as there appears to be no consistent condition which causes it to fail - in my experience, the same code will sometimes work and sometimes not; and of course, with such unpredictability and with other methods readily available, I abandoned the use of the activeselectionset property.
@ Lee:
What do you think of this version? (I had to write it in this form for compatibility with the previous...)
; Function: ALE_Block_GetInserts
; Version 1.00 - 30/11/2005
; Version 1.01 - 06/12/2005
; Version 2.03 - 22/02/2015
; Description:
; returns a list of all blocks in VlaDoc matching Layout names,
; Layers names and Block names
; Arguments:
; LayNms: Layout names - Wcmatch string > "Model,Layout1" or "*" for all
; LyrNms: Layer names - Wcmatch string > "Layer1,Layer2*" or "*" for all
; BlkNms: Block names - Wcmatch string > "Block001,BlockNnn" or "*" for all
; > "[~*]*" > no anonimous blocks
; FlgAtt
; = :vlax-true > only with attribs
; = :vlax-false > only without attribs
; = nil > all
; Return Values: LIST
; Example:
; (ALE_Block_GetInserts
; (vla-get-activedocument (vlax-get-acad-object)) "*" "*" "*" nil
; Block name Layer name Layout name
; > (("TITLEBLOCK" "LAYERX" "MODEL"
; #<VLA-OBJECT IAcadBlockReference2 08330c34>) (...) ...)
(defun ALE_Block_GetInserts (VlaDoc LayNms LyrNms BlkNms FlgAtt / VlaObj LayNam LyrNam BlkNam OutLst Ss_Tmp Countr EntNam)
( (not (= 'VLA-OBJECT (type VlaDoc))) )
( (vl-catch-all-error-p (vl-catch-all-apply 'vla-get-ActiveLayer (list VlaDoc)))
; ActiveLayer it is not a property of a IAxDbDocument: Interface then
; I use vla-get-layouts else (ssget "_X" ...) because it is 20 times faster
;(vlax-property-available-p VlaDoc 'Layouts) ;da aggiungere in futuro 20140213
(if (wcmatch (setq LayNam (strcase (vla-get-name LayFor))) (strcase LayNms))
(and
(not (vlax-property-available-p ObjFor 'Path)) ; not Xref
(wcmatch (setq LyrNam (strcase (vla-get-Layer ObjFor))) (strcase LyrNms))
(wcmatch (setq BlkNam (strcase (vla-get-Name ObjFor))) (strcase BlkNms))
(if FlgAtt (= (vla-get-hasattributes ObjFor) FlgAtt) T)
(setq OutLst (cons (list BlkNam LyrNam LayNam ObjFor) OutLst))
( (setq Ss_Tmp
(ssget "_X"
( (= :vlax-true FlgAtt) (list '(0 . "INSERT") (cons 410 LayNms) (cons 8 LyrNms) (cons 2 BlkNms) '(66 . 1)) )
( (= :vlax-false FlgAtt) (list '(0 . "INSERT") (cons 410 LayNms) (cons 8 LyrNms) (cons 2 BlkNms) '(66 . 0)) )
( T (list '(0 . "INSERT") (cons 410 LayNms) (cons 8 LyrNms) (cons 2 BlkNms)) )
(repeat (setq Countr (sslength Ss_Tmp))
(and
(setq VlaObj (vlax-ename->vla-object (setq EntNam (ssname Ss_Tmp (setq Countr (1- Countr))))))
(not (vlax-property-available-p VlaObj 'Path)) ; not Xref
(setq OutLst (cons (list (vla-get-Name VlaObj) (vla-get-Layer VlaObj) (DXF 410 (entget EntNam)) VlaObj) OutLst))
OutLst
Sorry if my English is not great.
What I mean is that you make a selection with ssget and then your treatment with activeselectionset.
Then you make a vla-delete on activeselectionset
From what I could deduce is that a stacking selections causes this error and that systematically erasing the selection set, I do not have this problem.
I use it for years, post lisps with this method on other forums.
draw few objects.
start XXX
(defun c:XXX (/ doc)
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(ssget)
(vlax-for %
(vla-get-activeselectionset
(princ %) (princ "\n")
make few undo CTRL+Z.
try to run XXX and -> error: Automation Error. Calling method Clear of interface IAcadSelectionSet
as Patrick said. we add vla-delete and so far no more error.
(defun c:XXX (/ doc ss)
(ssget)
(vlax-for %
(setq ss
(vla-delete ss)
i noticed that errors occurs very often after undo (when no vle-delete)
k.
You may directly select inserts using filters
sss
sname
"SomeSet"
ssflt0
(vlax
-make
-safearray vlax-vbinteger '
(0 .
0)) ssflt1
(vlax
-make
-safearray vlax-vbvariant '
(0 .
0)) )
ss
acselectionsetall
nil
nil
ss
If my test is valid I do not see the convenience:
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
(ALE_SSGETINSERTS).....1388 / 2.4 <fastest>
(ALE_SSGETINSERTS).....1450 / 2.3
(P35_SSGETINSERTS).....1482 / 2.25
(P35_SSGETINSERTS).....1529 / 2.18
(NAZ_SSGETINSERTS).....2745 / 1.22
(NAZ_SSGETINSERTS).....3338 / 1 <slowest>
(defun ALE_SSGetInserts ( / sel idx lst )
(if (setq sel (ssget "_X" '((0 . "INSERT"))))
(defun naz_SSGetInserts ( / ss lst)
(setq ss ( (lambda ( sname sss )
( (if (vl-catch-all-error-p
(vl-catch-all-apply 'vla-item
(list sss sname)
vla-add
vla-item
sss
sname
"SomeSet"
(vla-get-selectionsets
(vla-clear ss)
(setq
ssflt0 (vlax-make-safearray vlax-vbinteger '(0 . 0))
ssflt1 (vlax-make-safearray vlax-vbvariant '(0 . 0))
(vla-select
ss
acselectionsetall
nil
nil
(vlax-safearray-fill ssflt0 '(0))
(vlax-safearray-fill ssflt1 '("INSERT"))
(if ss (vlax-for blo ss (setq lst (cons blo lst))))
(defun P35_SSGetInserts ( / doc sel lst)
(setq
doc (vla-get-activedocument (vlax-get-acad-object))
(and (ssget "_X" '((0 . "INSERT")))
(vlax-for blo (setq sel (vla-get-activeselectionset doc))
(vla-delete sel)
lst
:-( wow, my way is slowest. so, if i have to delete some garbage entities such as points, small lines, blank texts or wipeouts, what is the fastest way to do it?
I do not understand the question, it seems to me that there is the solution...
