Code Red => AutoLISP (Vanilla / Visual) => Topic started by: cadpoobah on May 30, 2014, 02:42:26 PM
All,
I would like to create/find a utility that will let me select a cell in a table and have it add a "strikethrough" to all the text (in any cells) in that entire row.
I've found a few vla- functions for working with cells and table text but nothing that would lead me to manipulating the strikethrough property.
Ultimately, it would act as a toggle; unstriking rows that had been "striken" and vice versa.
Any leads?
Thanks!
Don't know about newer version of Autocad but as
of 2012 Strikethrough was not available.
You can have underline or Overline.
ymg
As of Version 2013 Strikethrough is available,
(setq myvar "\\KAll this will be strikehrough\\k")
ymg
Give this a try :)
(defun c:strike (/ _togglestrike i o p row ss txt)
(defun _togglestrike (string)
(if (wcmatch string "{\\K*")
(substr string 4 (- (strlen string) 4))
(strcat "{\\K" string "}")
(setq i -1)
(if (and (setq ss (ssget "_X" (list (cons 0 "acad_table") (cons 410 (getvar 'ctab)))))
(setq ss (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))))
(if (and (setq p (getpoint "\nPick a Cell: "))
(vl-some '(lambda (x)
(and (eq :vlax-true
(vla-hittest
x
(vlax-3d-point (trans p 1 0))
(vlax-3d-point (trans (getvar 'viewdir) 1 0))
'row
'col
(setq o x)
ss
(repeat (vla-get-columns o)
(and (vlax-invoke o 'getcellvalue row (setq i (1+ i)))
(/= "" (setq txt (vla-gettext o row i)))
(vla-settext o row i (_togglestrike txt))
(princ "\nCell not detected!")
(princ "\nNo Tables found!")
Ronjonp,
Good show !
I believe it would be a good idea to turn the cell selection
into a function returning row and column.
ymg
Search for 'LM:getcell' :lol:
EDIT: Or as another example: http://www.theswamp.org/index.php?topic=37154.msg448331#msg448331
Nice job as usual Lee :kewl:
Lee,
ASMI had something very similar in https://autocadtips.wordpress.com/2012/02/27/autolisp-copy-text-to-table-cells/ (https://autocadtips.wordpress.com/2012/02/27/autolisp-copy-text-to-table-cells/)
So did Lee Ambrosius here http://hyperpics.blogs.com/beyond_the_ui/2012/07/create-a-table-and-select-a-cell-to-change-with-autolisp-and-activex.html (http://hyperpics.blogs.com/beyond_the_ui/2012/07/create-a-table-and-select-a-cell-to-change-with-autolisp-and-activex.html)
Could not find getcell. But it is easy enough to derive from what we got.
ymg
Thanks Ron, you too :-)
