Looks like you got the information about the file from .NET, C#, C++ or something else that I don't know, nor understand.
As soon as I.T. gets Visual Studio on my computer, I'm diving into C#. I'm so looking forward to learning it.
Perhaps try something like this:Code - Auto/Visual Lisp: [Select]
Returns Julian date.
You'll enjoy it a lot more after the initial learning curve... This thread (http://www.theswamp.org/index.php?topic=43616.0) may help with that.
Thank you for providing the explanation Renderman - saved me some time :-)
(defun _Try ( try_statement / try_catch try_result )
;; General purpose error trapper.
(vl-catch-all-error-p
(setq try_catch
(vl-catch-all-apply
(function
(lambda ( )
(setq try_result (eval try_statement))
(setq *try_errors* ;; lexical global
(cons
(list
try_statement
(vl-catch-all-error-message try_catch)
*try_errors*
try_result
(defun _JulianToDateStr ( julian_date / @floor @itoa a b c d e f y z year month day hours mins secs )
;; Renamed, reformatted and generally abused version of Jon
;; Fleming's classic JUL_CAL function written around 1991-09-09.
;; This version is coded to return the resulting value as a string,
;; e.g. "20121104_082248". I need this for file creation utilities
;; so often this is the default date format I use. Apologies if this
;; insults your sensibilities. MP.
;; Calculate date. It's magic, don't even ask. Some things we
;; weren't meant to know. Jon Fleming.
(defun @floor ( number )
(fix
(if (> number 0)
number
(- number 1)
(defun @itoa ( i / result )
(setq result (itoa i))
(while (< (strlen result) 2)
(setq result (strcat "0" result))
result
(setq
z (fix julian_date)
a (fix (/ (- z 1867216.25) 36524.25))
a (+ z 1 a (- (fix (/ a 4))))
b (+ a 1524)
c (fix (/ (- b 122.1) 365.25))
d (@floor (* 365.25 c))
e (fix (/ (- b d) 30.6001))
day (fix (- b d (@floor (* 30.6001 e))))
e (- e (if (< e 14) 2 14))
month (1+ e)
year (if (> e 1) (- c 4716) (- c 4715))
year (if (zerop year) (1- year) year)
;; Calculate time. First strip the time portion
;; from the input.
y (- julian_date (fix julian_date))
;; Number of hours since midnight.
hours (fix (* y 24))
;; A temporary variable we'll use a couple of times.
f (- y (/ hours 24.0))
;; Number of minutes since midnight (1440 minutes per
;; day).
mins (fix (* f 1440))
;; Number of seconds since midnight (86400 seconds per
;; day). MP added (+ 0.5 ...) to match values returned by
;; the vl-file-systime function.
secs (fix (+ 0.5 (* (- f (/ mins 1440.0)) 86400)))
(strcat
(itoa year) (@itoa month) (@itoa day)
"_"
(@itoa hours) (@itoa mins) (@itoa secs)
(defun _GetFileDateVL ( filename / path temp result )
;; Return the file's date (last modified) as a string,
;; e.g. "20120911_073435". I need this for file creation
;; utilities so often this is the default date format I
;; use. Apologies if it insults your sensibilities. MP.
(if (setq path (findfile (findfile filename)))
(if (_Try '(setq temp (vl-file-systime path)))
(strcat
(substr
(setq result
(apply 'strcat
(mapcar
(function
(lambda ( n / s )
(if (eq 1 (strlen (setq s (itoa (nth n temp)))))
(strcat "0" s)
s
'(0 1 3 4 5 6)
1 ;; 2014 11 03
8
"_"
(substr result 9)
(defun _FSO ( )
;; cache it (I call it repeatedly)
(setq *fso* (vlax-create-object "scripting.filesystemobject"))
(defun _FSO ( ) *fso*)
*fso*
(defun _GetFileDateFSO ( filename / file result )
;; Nods to Lee Mac, Black Box, Irneb and Jon Fleming for
;; respective tips, tricks, resources or sample code that
;; contributed to this variant.
(_Try
'(setq result
(_JulianToDateStr
(+ 2415019
(vlax-get
(setq file
(vlax-invoke
(_FSO)
'GetFile
(findfile filename)
'DateLastModified
(if file (_Try '(vlax-release-object file)))
result
(defun _GetFileDate ( filename / result )
;; Wrapper function for _GetFileDateVL and _GetFileDateFSO
;; functions, visual lisp and file system object methods
;; respectively.
(or
;; try visual lisp first
(setq result (_GetFileDateVL filename))
;; vl-file-systime failed, call the fso sledge hammer
(setq result (_GetFileDateFSO filename))
result
... I need to be able to (swiftly) determine the date stamp for many files, not just the active drawing, notwithstanding for file types beyond AutoCAD drawings. Cheers. :)
