Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Fabricio28 on January 04, 2013, 11:05:48 AM
Hi all,
I wanna fill the attribute with fields. I've tried many lisp from the internet, but no success.
Is it possible to match cells from attribute as a field?
thank in advance.
Hi guys!
Sorry for my bad english. Now I have a better explanation with my request.
I'm having a trouble with my project and I need some help.
In my drawing have about 200 blocks and every time I change the project I have a bad headache, because I have to update all blocks in multiple projects.
I've already tried to use the command convert block to reference in express tools, but it didn't work as wanted to.
In my file attached is a simple example of my task.
Project.dwg is my main project, there are just one kind of block that i put sequencial numbers.
Project-Xref blocks, there are the same amount of blocks as Project.
I wanna linking the two project so that I changed the numbers in Project the Project-Xref updated automatically.
Please guys, any help will be really appreciated.
Thank in advance.
Global Attribute Extractor & Editor.lsp
Thanks Lee, excellente tool!
Worked like a charm.
Many Thanks!
Fabricio :-D
