Actually I could not access the attributed block definition with entnext function , of course with the same one that is attached with Mleader entity.
(344 . <block def ename>)
(330 . <attdef ename>)
(177 . <attribute index>)
(44 . <attribute width factor>)
(302 . <attribute content>)
Unfortunately when running the lisp I get the following error message:Code: [Select]; error: Automation Error. Calling method AddItems of interface IAcadSelectionSet failed
That works.
Would it be possible to make it so that the value of the increment could be specified and to have the increment be a negative value.
Thanks for the great work
