Code Red => AutoLISP (Vanilla / Visual) => Topic started by: andrew_nao on January 05, 2012, 03:13:13 PM
hello all and happy new year.
my first request for the new year :-o
can anyone help me with how i can get code to tell the difference between a variable being words or numbers?
example
(if var = a word
(do this)
(if var = a number
(do this)
any help is appreciated
You could check with the type function - if I'm understanding correctly.
Command: (type 3.4)
REAL
Command: (type 3)
INT
Command: (type "3.4")
STR
thanks for the reply Alan, however my variables will always be in quotes so it will come up as a string and not an integer
Try distof...
Command: (distof "3.4")
3.4
Command: (distof "blah")
nil
thanks again but that isnt working either
my number is returned as a string and looks like this
"97 01000 000 16 99 10"
and distof returns nil
Give me a few examples to go on - as word and as number.
a word, for instance, would be
"plate" or "pipe". just a plain word.
and a number would be
the number would be exactly like you see it here but with different digits
same spacing format.
both would be returned via my existing code as strings
A fairly simplistic solution for this specific case:
(if (wcmatch str "*@*")
(princ "\nIt is a string.")
(princ "\nIt is a number")
just for the single words without digits (not for "cloud number 9" etc):
(vl-some '(lambda(x)
(or (distof (chr x))(eq 32 x)))
(vl-string->List StringExpression))
(alert "number")
(alert "word"))
Nice 8-)
There you go. :-)
Nice 8-)
thanks everyone
both solutions work perfectly
didnt think it was that easy... :ugly:
