Code Red => AutoLISP (Vanilla / Visual) => Topic started by: DanB on February 14, 2005, 10:26:01 AM
Could someone help explain and/or give an example(s) of how to maintain a default value from a previous user input. In my routine I would like the user to input an elevation change value (i.e. 1.5, 0.87) and when the routine is run in the same session to remember that input but also allow you to change at prompt. I'm not sure if leaving a variable global is appropriate/necessary for this application.
"snip-it of code"
;; Portions of this Code supplied by Jeff_M and Others at the Swamp
(defun C:Addsurf (/ acadObj1 aecApp1 aecProj aecSurfs aecSurf aecUtil pt# e-n selev newelev acadObj2 aecApp2 aecDoc
PrefDoc Hscale xsf ysf rta typ ctp ipt atr emsg elevdif elevc) ;; Removed BLK to "remember" last used Block Name
ALSO Removed chelev to "remember last User Elevation Change
(if chelev
(setq chelev (rtos chelev))
(setq elevdif (strcat "\nElevation Change: <" chelev "> "))
(setq chelev (atof
(if (= (setq elevc (getstring elevdif)) "") chelev elevc
(setq chelev (atof (getstring "\nElevation Change: ")))
I'm just looking to see if I am going about this in the "right" way or not.
Thanks,
Dan
PS. Jeff_M - things are looking good for my Surface Lisp which this is part of, couldn't of done it without your help and all the rest here at the Swamp
I don't see anything wrong with creating global variables for the purpose of offering default values. Only if it's a value that needs careful preservation or should be saved from session to session, it would be preferrable to save it somewhere (e.g. in a dictionary or a system var - or perhaps, for cross-session use, in the registry).
Is there a specific reason for using GETSTRING to retrieve a number?
As I see it there is several ways to do this, this is just one. It's not bullet proof my any means.
(defun c:myfunc ()
((not ggg) ; if 'ggg' doesn't exist
(setq ggg (getreal "\nEnter value for 'ggg': "))
(ggg ; 'ggg' does exist prompt user to change
(strcase
(getstring (strcat "\nChange value ["(rtos ggg)"](Y/N)<No>: "))
"Y"
) ; if the user answered with y/Y
; then prompt for new value
(princ
(strcat "the value of 10 x " (rtos ggg)" = " (rtos (* ggg 10)))
Here is a short example of how to use a global var.
;;; This procedure will use a global variable to prompt the
;;; user the number of times (s)he has called this procedure.
;;; This is only ment as an example.
(defun timesrun ()
(if (eq _#times nil)
(setq _#times 1)
(setq _#times (1+ _#times))
);_ end if
(princ (strcat "\nYou have called this procedure " (rtos _#times 2 0) " times."))
);_ end defun
*shock* ...holy cow are you guys fast!
(I was beaten to the puch by not only one person but two!!??)
Don't forget, there is always the RRBDM (http://www.theswamp.org/phpBB2/viewtopic.php?p=474#474) (a.k.a. "Robert R. Bell Default Method")
Here is another approach to a routine that reuses settings.
If the variables are not changed frequently don't make the user press enter
to bypass the change. Just give them the option to change or continue without
interruption. In this example the user picks an insert point but has the option
of entering 'E' to reset the elevation or 'B' to change the block name.
I did not test the code so you will have to. :)
;; Load a default if null variable
(setq chelev (cond (chelev) (10.0)))
(setq blknam (cond (blknam) ("ElevPt")))
;; loop until user presses enter
(setq loop t)
(while loop
(initget 1 "Elevation Block")
(setq
ptpick (getpoint
(strcat "\nPick insert point or [Elevation / Block]: Elev="
chelev ": "
((= (type ptpick) 'list) ; point picked
;; INSERT the block here
;; Loop continuies to the next pick
;; You could (setq loop nil) exit loop to allow only one insert
((= ptpick "Elevation")
;; get new elevation
(setq newelev (getreal "\nEnter New Elevation: "))
(if newelev
(setq chelev newelev)
((= ptpick "Block")
(setq newblk (getstring t "\nEnter New Block name: "))
(if (and newblk (tblsearch "Block" newblk))
(setq blknam newblk)
(alert "Block not found.")
(t
;; User pressed ENTER, so Bye Bye :)
(setq loop nil) ; exit loop
) ; end while
Thanks all, some good feedback here. I am very new to LISP writing, actually I am just trying to understand the processes and do more of Cut-n-Paste and some minor edits at this point. I don't consider myself a writer to say the least.
Not really, more of lack of knowing any better. This was more of a case of Copy-N-Edit other code to do something "new." I will try to apply some of these concepts to better my code and look into (getreal) :oops:
Thanks again
Dan
Alright guys:
You got the ticker going and now it's broken :D .
(initget 0 "Tree Shrub Bub Header Cv") ;Gets T or S or B
(if (not *default*)(setq *default* "S"))
(setq P (getkword (strcat "\nEnter an option (T)ree, (S)hrub, (B)ub, (H)eader, or (C)v Lateral (" *default* "): ")))
(if (not (eq P ""))(setq *default* P))
How do I get this section to accept the default? I've got it tt show the last user input....but thats it.
Thanks,
Ron
If it can help, here are some applications of the aforementioned default method. The first part is eqivalent to CAB's way of assigning global variables (only assigning each variable in case it evaluates to nil).
;; Setting up some global default values
;; unless already assigned
(foreach n '((str1_default "string_no_spaces")
(str2_default "string with spaces")
(int_default 89)
(real_default 89.35)
(key_default "Mykey")
(if (not (eval (car n)))
(set (car n) (cadr n))
(defun rrbdm_test (/ testType)
;; The default method used for determining which test to use
;; An empty response will assign the string "Keyword" to testType
(initget 0 "keyString Getstring Integer Real Keyword")
(setq testType
(cond ((getkword
"\nTest GETxxx method [keyString/Getstring/Integer/Real/Keyword] <Keyword>: "
("Keyword")
(cond ((= testType "Keyword")
;; GETKWORD default method
;; An empty response will assign key_default to variable default
(initget 0 (strcat "Abc Def " key_default))
(setq default (cond ((getkword (strcat "\nEnter keyword [Abc/Def/"
key_default "] <"
key_default ">: "))
(key_default)
((= testType "Real")
;; GETREAL default method
(setq real_default (cond ((getreal (strcat "\Enter real <" (rtos real_default) ">: ")))
(real_default)
((= testType "Integer")
;; GETINT default method
(setq int_default (cond ((getint (strcat "\Enter integer <" (itoa int_default) ">: ")))
(int_default)
((= testType "keyString")
;; Get a string default method
;; This one uses INITGET 128 which allows for arbitrary string input for GETKWORD, but
;; it doesn't accept spaces with the string
(initget 128 str_default)
(setq str1_default (cond ((getkword (strcat "\nEnter string w/o spaces <" str1_default ">: ")))
(str1_default)
((= testType "Getstring")
;; Get a string defualt method
;; This one uses GETSTRING which allows spaces in the return value. On the other
;; hand it produces an empty string when getting an empty response so it can't be
;; tested for nil .. only for equal to "" (or STRLEN > 0, or some other predicate)
(cond ((/= (setq str2_default (getstring T (strcat "\nEnter string <" str2_default ">: ")))
str2_default
Try this:
(initget "Tree Shrub Bub Header Cv") ;Gets T or S or B
(setq p (cond (P)(*default*))
*default* p)
You beat me CAB...
(if (not *default*)(setq *default* "Shrub"))
(setq P (cond ((getkword (strcat "\nEnter an option (T)ree, (S)hrub, (B)ub, (H)eader, or (C)v Lateral (" *default* "): ")))
(*default*)))
I got it to work like this but it's ugly :oops:
Food for thought (http://theswamp.org/phpBB2/viewtopic.php?t=4041).
(Admittedly probably overkill, but idea posted anyway).
I'd just add that if you want to use global variables, its a good idea to use informal namespaces. The name of your routine is a good choice for the informal namespace.
For example, say you have a routine called "MYTWEEK". This routine asks for user input , and you want to store it in a global variable named *AREA*. Obviously, being somewhat generic, you might have problems with other routines also trying to use a global variable named *AREA*. A good way to prevent this is to name your global variable *MYTWEEK:AREA*. A different program named FUNKYTOWN might also use a similar global variable, but would instead call it *FUNKYTOWN:AREA*.
This is called using an "informal namespace". It is called "informal" because the use of the namespace is not parsed or enforced by the Lisp interpreter in any way. The colon in the variable name is not any sort of special syntax, it is treated just like any other letter. But chances of having a global variable named *MYTWEEK:AREA* in two different programs are slim indeed; much slimer than two programs both trying to use the global variable *AREA*.
At one point, I also posted this rough guideline (http://theswamp.org/phpBB2/viewtopic.php?p=25983#25983) about various ways to store user data in programs.
sinc, thanks for the feedback as well, I followed your posted link and copied the post for my future reference. :D
