Code Red => .NET => Topic started by: teslaxx on February 10, 2011, 10:20:00 AM
I have a entity (an alignment - a Civil entity).
I exploded it, and I obtain a BlockReference.
But when I explode the block, a very large number of entities (componentes of the blockReference) dissapear and I need those components to edit. Any ideas?
Apparently, I had to select the entities in a specific order.
If I would explode Entity1, Entity2 would disappear, but if I would change the order, all entities remained. :)
So, case solved.
