CAD Forums => CAD General => Topic started by: M-dub on January 13, 2005, 12:06:15 PM
Someone back at the office got a zip file full of different file formats and was asked to "Print these E-Plan drawings". Does anyone know WAHT E-Plan is and if we can convert them to AutoCAD?
Yes, I did (and am still doing) a Google search...
Thanks a lot,
Mike
Did you get the file extension? I believe they might be using "E-Plan" to describe that they're electronic drawing files.
I believe that if you look they will be autocad drawings. "E-Plan" and "E-Copy" are the curently in vogue IT buzz words that are supposed to showthe superior intelligence of the utterer. Simply means an electronis data copy. Next time Brain Child shows his/her intellect, tell them it will take a minute because you need to go take an E-Whiz.
http://www.caduser.com/reviews/reviews.asp?a_id=157
Looks like it's some kind of 'CAD Replacement" sorta thing in Germany (which is where these drawings originated from).
REAL "CUTTING EDGE" ISN'T IT, IF IT WON'T WORK WITH AUTOCAD. "Hey, I got this great new cad program!! Nobody else can open my drawings, but it sure is cool!"
:lol:
If anyone's interested (which I can completely understand if no one is ;) ), here is what some of the files look like. There appears to be 4 drawings and all of these files make up one drawing. All I can say is that they better be pretty impressive for circuit diagrams!
C:\Documents and Settings\90260\My Documents\My Stuff\Temp\30552\30552450.P
ANL_ORT.DAT DAT File 431 11/19/2004 2:37pm
ANLAGE.DAT DAT File 952 11/19/2004 2:37pm
ANLAGE.IDX IDX File 4,096 11/19/2004 2:37pm
EDOC_PRJ.CUM CUM File 610 11/30/2004 4:06pm
EIN_ORT.DAT DAT File 0 02/26/2004 4:03pm
EIN_ORT.IDX IDX File 2,048 02/26/2004 4:03pm
KABEL.DAT DAT File 17,760 11/30/2004 4:05pm
KABEL.GEN GEN File 4,324 11/30/2004 4:05pm
KABEL.IDX IDX File 20,992 11/30/2004 4:05pm
KABEL.KAF KAF File 5,564 11/30/2004 4:05pm
KABEL.KAN KAN File 14,080 11/30/2004 4:05pm
KABEL.KLB KLB File 5,139 02/24/2004 2:50pm
KLEMMEN.DAT DAT File 200,100 11/30/2004 4:06pm
KLEMMEN.IDX IDX File 9,216 11/30/2004 4:06pm
KPLOT.DAT DAT File 50 11/30/2004 4:06pm
KPLOT.IDX IDX File 1,536 11/30/2004 4:06pm
ORT.DAT DAT File 196 11/19/2004 2:37pm
ORT.IDX IDX File 2,048 11/19/2004 2:37pm
P_FEHLER.DAT DAT File 3,840 11/30/2004 4:06pm
P_FEHLER.IDX IDX File 3,072 11/30/2004 4:06pm
P_INHALT.$$$ AutoCAD Emergency Backup 1,352 01/12/2005 8:44am
PROJEKT.PPD PPD File 8,000 01/12/2005 8:44am
PVW.DAT DAT File 32,385 11/30/2004 4:05pm
PVW.IDX IDX File 25,600 11/30/2004 4:05pm
PVW.PVW PVW File 560 11/30/2004 4:05pm
QVW.ANS ANS File 2,802 11/30/2004 4:05pm
QVW.DAT DAT File 5,782 11/30/2004 4:05pm
QVW.IDX IDX File 3,584 11/30/2004 4:05pm
QVW.KON KON File 4,346 11/30/2004 4:05pm
SEITEN.DAT DAT File 4,746 01/12/2005 8:44am
SEITEN.IDX IDX File 3,584 01/12/2005 8:44am
SEITEN.SPL Shockwave Flash Object 339,200 01/12/2005 8:44am
SPSDB.DAT DAT File 51,982 11/30/2004 4:05pm
SPSDB.IDX IDX File 27,136 11/30/2004 4:05pm
STECKER.KLS KLS File 464 04/02/2004 10:52am
TEXT_DB.DAT DAT File 636,456 11/19/2004 4:00pm
TEXT_DB.IDX IDX File 37,888 11/19/2004 4:00pm
Z_INHALT.$$$ AutoCAD Emergency Backup 662 01/12/2005 8:44am
