Code Red => .NET => Topic started by: dugk on July 15, 2010, 02:59:14 PM
Building on this post: http://www.theswamp.org/index.php?topic=33483.msg388566#msg388566
I would like to have the Mouse Right-click cancel the EntityJig being dragged. I've tried several things as simple as returning SamplerStatus.Cancel when the bool userCancel == true to using try/catch and throwing an System.Exception("User cancelled."). Nothing gets me to cancelling the EntityJig.
using System.Linq;
using AcApSrvApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace psPlc
class BlockJig : EntityJig
private static BlockJig currentJig;
private Point3d mPosition;
private int mOffsetIdx;
private Vector3d[] mOffset;
private JigMessageFilter mMsgFilter;
private Point3d _pos;
private Dictionary<ObjectId, AttInfo> _attInfo;
private Transaction _tr;
private static bool userCancel;
public BlockJig(Transaction acTrans, BlockReference br, Dictionary<ObjectId, AttInfo> attInfo,
ObjectId btrId, Vector3d[] nodeVectors)
: base(br)
_pos = br.Position;
_attInfo = attInfo;
_tr = acTrans;
mOffset = nodeVectors;
mPosition = Point3d.Origin;
Editor ed = AcApSrvApp.DocumentManager.MdiActiveDocument.Editor;
Matrix3d ucsRotation = ed.CurrentUserCoordinateSystem;
//cancel translation component of UCS matrix
ucsRotation = ucsRotation.PostMultiplyBy(Matrix3d.Displacement(ucsRotation.Translation));
//Respects UCS orientation
Entity.TransformBy(ucsRotation);
mOffsetIdx = 0;
//We need to transform also those offsets depending of the UCS
for (int idx = 0; idx < mOffset.Length; ++idx)
mOffset[idx] = mOffset[idx].TransformBy(ucsRotation);
//Setup message filter for SPACE keydown -> change the offset (could be any other key or controlled by jig key word...)
mMsgFilter = new JigMessageFilter();
System.Windows.Forms.Application.AddMessageFilter(mMsgFilter);
currentJig = this;
public new BlockReference Entity
get
return base.Entity as BlockReference;
protected override bool Update()
BlockReference br = Entity as BlockReference;
Entity.Position = mPosition;
br.Position = _pos;
if (br.AttributeCollection.Count != 0)
foreach (ObjectId id in br.AttributeCollection)
DBObject obj = _tr.GetObject(id, OpenMode.ForRead);
AttributeReference ar =
obj as AttributeReference;
// Apply block transform to att def position
if (ar != null)
ar.UpgradeOpen();
AttInfo ai = _attInfo[ar.ObjectId];
ar.Position =
ai.Position.TransformBy(br.BlockTransform);
if (ai.IsAligned)
ar.AlignmentPoint =
ai.Alignment.TransformBy(br.BlockTransform);
if (ar.IsMTextAttribute)
ar.UpdateMTextAttribute();
return true;
protected override SamplerStatus Sampler(JigPrompts prompts)
JigPromptPointOptions jigOpts = new JigPromptPointOptions("\nInsertion point");
jigOpts.UserInputControls = UserInputControls.NoZeroResponseAccepted |
UserInputControls.GovernedByOrthoMode |
UserInputControls.Accept3dCoordinates;
PromptPointResult res = prompts.AcquirePoint(jigOpts);
psPlc.insertPn.basePoint = new Point3d(res.Value.X, res.Value.Y, res.Value.Z);
if (userCancel == true)// || res.Status == PromptStatus.Cancel)
//AcApSrvApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Right-click.");
//if (userCancel == true)
//userCancel = false;
//throw new System.Exception("User cancelled.");
//Run();
//try
//catch { };
//return SamplerStatus.Cancel;
if (res.Status == PromptStatus.Cancel)
aCommon.Methods.clearCommandLine();
Point3d newPos = res.Value.Add(mOffset[mOffsetIdx]);
if (mPosition == newPos)
return SamplerStatus.NoChange;
mPosition = newPos;
return SamplerStatus.OK;
public PromptStatus Run()
//try
// if (userCancel == true)
// userCancel = false;
// throw new System.Exception("User cancelled.");
// PromptResult promptResult = AcApSrvApp.DocumentManager.MdiActiveDocument.Editor.Drag(this);
// return promptResult.Status;
//catch { };
//return PromptStatus.Cancel;
public void MoveOffsetIndex()
mOffsetIdx = (++mOffsetIdx) % mOffset.Count();
public void Cleanup()
System.Windows.Forms.Application.RemoveMessageFilter(mMsgFilter);
class JigMessageFilter : System.Windows.Forms.IMessageFilter
int WM_KEYDOWN = 0x100;
public bool PreFilterMessage(ref System.Windows.Forms.Message m)
if (m.Msg == WM_KEYDOWN)
if ((int)m.WParam == 32 || (int)m.WParam == 9) //is this a tab or space?
currentJig.MoveOffsetIndex();
//triggers graphic update without the need to move the mouse
System.Windows.Forms.Cursor.Position = System.Windows.Forms.Cursor.Position;
//Block message for AutoCAD
return true;
else if ((int)m.WParam == 13)// || (int)m.WParam == 1 || (int)m.WParam == 27)
userCancel = true;
return false;
Thanks for you help.
Doug
Add UserInputControls.NullResponseAccepted to the jigOpts.UserInputControls
and just evaluates if promptResult.Status == PromptResult.OK
Here's a little sample
namespace BlockJigTest
BlockReference m_blkRef;
Point3d m_insPt;
public BlockJig(BlockReference br) : base(br)
m_insPt = br.Position;
m_blkRef = br;
JigPromptPointOptions jigOpts = new JigPromptPointOptions();
(UserInputControls.Accept3dCoordinates | UserInputControls.NullResponseAccepted);
jigOpts.Message = "\nEnter insert point: ";
PromptPointResult ppr = prompts.AcquirePoint(jigOpts);
if (m_insPt == ppr.Value)
else
m_insPt = ppr.Value;
m_blkRef.Position = m_insPt;
return true;
public class TestCommand
[CommandMethod("TEST")]
public void Test()
Database db = doc.Database;
Editor ed = doc.Editor;
PromptStringOptions opts = new PromptStringOptions("\nEnter block name: ");
PromptResult pr = ed.GetString(opts);
if (pr.Status != PromptStatus.OK)
return;
Transaction tr = doc.TransactionManager.StartTransaction();
using (tr)
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
if (!bt.Has(pr.StringResult))
ed.WriteMessage("\nBlock not found.");
return;
ObjectId blockId = bt[pr.StringResult];
while (pr.Status == PromptStatus.OK)
Point3d pt = new Point3d(0, 0, 0);
using (BlockReference br = new BlockReference(pt, blockId))
BlockJig entJig = new BlockJig(br);
pr = ed.Drag(entJig);
if (pr.Status == PromptStatus.OK)
BlockTableRecord btr =
(BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
btr.AppendEntity(br);
tr.AddNewlyCreatedDBObject(br, true);
doc.TransactionManager.QueueForGraphicsFlush();
tr.Commit();
Thank you!
That did the trick. By simply adding the line:
UserInputControls.NullResponseAccepted |
in:
mPosition = newPos;
it now works as requested.
Thanks again!
FYI - I have another issue with this EntityJig posted here: http://www.theswamp.org/index.php?topic=34230.0 (http://www.theswamp.org/index.php?topic=34230.0)
