Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Andrea on January 26, 2009, 11:24:46 AM
hi all..
any one know how to select entity without showing grips ?
Turn off Grips, but make sure to turn them back on when you are done.
(setvar "grips" 0)
Not sure if this is correct or not, but when I used
(sssfirst selset) ;objects selected NO GRIPS
(sssfirst nil selset) ;objects selected with grips
When I try that, d-unit, it reports a selection set but nothing is actually selected. If I initiate the Move command afterwards then it still asks for a selection, so it doesn't recoginze anything being previously selected.
well...
...I think that i've seen something for that.
thanks.
Ahh you are correct. In that case, seems the only way would be to set grips to 0 first.
