CAD Forums => Vertically Challenged => Land Lubber / Geographically Positioned => Topic started by: Dinosaur on April 13, 2008, 06:18:47 PM
There is a question in the Autolisp forum about accessing Land Desktop drawings without a path and also where to derive project path information when it is present. The only thing I remember about Land Desktop is that I was under threat of losing my computer keys if I didn't use the project paths when using it. Perhaps someone over here can help him out at the other end of THIS (http://www.theswamp.org/index.php?topic=22492.0) link.
i dont' want to suppress the prompt forever, only for batch editing purposes from a script (the prompt just stops the script).
as far as getting the path, i want it so i can finish a routine that will copy certain files to the project folder.
any help would be greatly appreciated :)
thanks donosaur for posting it in here as well.
I would suggest accessing the data you want to batch edit through a MAP query process, thus it has no impact on the project paths. And you have MAP, right there inside Land you might as well use it for what it does best.
