Code Red => .NET => Topic started by: Draftek on November 28, 2007, 10:09:25 AM
I need a strongly typed collection of an object I'm building. I derive from collectionbase and all is good except I cannot seem to serialize the collection.
Am I going to have to implement some serializing interfaces?
Code?
Also, what version of AutoCAD and the framework?
The last paragraph of this is 'interesting' ..
http://www.mattberther.com/2004/09/05/implementing-collectionbase/
The object:
[Serializable]
public enum LiteType
Row,
Col,
Main
/// <summary>
/// Container for the dlo lite object
/// </summary>
[XmlRootAttribute("Lite", Namespace = "", IsNullable = false)]
public class cLite
#region private members
private cLite m_parentLite = null;
private cLites m_childLites;
private string m_Name = "";
private LiteType m_liteType;
private double m_Width = 0;
private double m_Height = 0;
private double m_SillOffset = 0;
#endregion
#region public members
// the parent lite or null if this is the root note
[XmlElementAttribute("parentLite", typeof(cLite))]
public cLite ParentLite
get { return m_parentLite; }
set { m_parentLite = value; }
// the name string
[XmlElementAttribute("Name")]
public string Name
get { return m_Name; }
set { m_Name = value; }
// the child lites collection
[XmlArray("childLites"),
XmlArrayItem("childLite", typeof(cLite))]
public cLites ChildLites
get { return m_childLites; }
set { m_childLites = value; }
[XmlElementAttribute("LiteType", typeof(LiteType))]
public LiteType liteType
get { return m_liteType; }
set { m_liteType = value; }
[XmlElementAttribute("Width")]
public double Width
get { return m_Width; }
set { m_Width = value; }
[XmlElementAttribute("Height")]
public double Height
get { return m_Height; }
set { m_Height = value; }
// the offset of the bottom of the lite - this is used so we can drop
// the jamb members for a door that would run down to the floor, ignoring
// any sill gap
// These would only be used in the vertical sense of the primary children
// basically the initial rows of the mark
[XmlElementAttribute("SillOffset")]
public double SillOffset
get { return m_SillOffset; }
set { m_SillOffset = value; }
#endregion
// default constructor
public cLite() :this("No Name", 0, 0, LiteType.Main)
// default constructor calls the other one
// constructor to use
public cLite(string name, double Width, double Height, LiteType lType)
m_Name = name;
m_Width = Width;
m_Height = Height;
m_liteType = lType;
m_childLites = new cLites(this);
The collection:
// this is basically the child lites collection
[Serializable]
public class cLites :CollectionBase
// constructor - when the collection is created, you need a parent lite
// to add to all of the children created from the add method
public cLites(cLite parent)
m_parentLite = parent;
// parent lite
private cLite m_parentLite;
#endregion
#region public Members
#endregion
// the collection stuff
public int Add(cLite child)
child.ParentLite = m_parentLite;
return List.Add(child);
public void Remove(cLite child)
List.Remove(child);
public void Insert(int index, cLite child)
List.Insert(index, child);
public cLite this[int index]
get { return (cLite)List[index]; }
set { List[index] = value; }
Good point on the framework - 2.0
No autocad required
I stumbled on a workaround - wrapping the collection and then serializing the wrapper. It works but I don't know. Apparently there is a problem with the IList interface and serialization.
Sorry Kerry, didn't see your post. I'm not sure how that will help my case since I need an object.
Any reason why you're not using generics then, if it's framework v2?
That code looks like it has some nasty traps possible.
That whole thing where the collection has a "parent" property, with getter and setter, but then each individual "Lite" also has a parent... That sounds nasty to me. What happens if someone changes the parent Lite for the collection after a bunch of Lites are added?
And I too would recommend that you use generics instead. The old List needs to box/unbox the elements inside it every time you do something, which results in a performance hit (although it's possible the hit isn't big enough to really notice).
And out of curiosity, what is a "Lite", anyway, besides a type of beer? :-) Looks like it has something to do with doors, but I've never heard the term...
The code is merely thrown together for proto-typing at this point.
The parent object in the collection is used to set the parent of each member. I've used this method before and it works really well where you need to 'chain' children.. Think of browser nodes in a treeview control.
If somebody will throw me a 'generics' example, I'd be very interested to see it.
Give this (http://www.theswamp.org/lilly_pond/GlennR/DraftekSerialization101.htm) a run around the yard.
Cheers,
Glenn.
Whoops! Forgot the starter XML file:
<Projects>
<Project>
<Number>100</Number>
<Description>First project</Description>
</Project>
<Project>
<Number>101</Number>
<Description>Second project</Description>
</Project>
</Projects>
Place in the same folder as the dll.
I'll give it a shot Glenn.
works great! I changed cLites to this:
[Serializable]
public class cLites :List<cLite>
// parent lite
#endregion
#endregion
works AND cut out the implementation code AND the wrapper class - Nice!
Looks like I have some reading to do...
Thanks Glenn
nurries.
okay, you got me with that one. I can usually decipher the Australian but..... :)
yes, generics ..
thats what I meant by the reference to the last paragraph of the article I referenced to.
Glenn,
those samples look functionally familiar.
no flaming worries = nurries.
or
all is cool.
added:
it's actually just 'no worries'
Strine is easy if you hold your nose and run words together.
also added later:
* sometimes reality should not stand in the way of a good story
IMHO, everything's fine unless it's a keyed collection of elements. Here's an example:
1) There's an Attribute type, having Name property (String). Two Attributes are considered equal if their Names are equal.
2) There's also a generic keyed collection of Attribute elements named Attributes:
<Serializable()> _
Public Class Attributes
Inherits KeyedCollection(Of String, Attribute)
Sub New()
MyBase.New()
Protected Overrides Function GetKeyForItem(ByVal item As Attribute) As String
Return item.Name
End Function
Then, here's how you access collection elements (by name):
Dim myAttributes As New Attributes()
... fill the collection ...
Dim myAttribute As Attribute = myAttributes("KeyName")
Both Attribute and Attributes types need to be decorated with Serializable() attribute. That's it. You don't need to bother with property/method serialization attributes since only Public ones will get serialized/deserialized.
Regards,
Maksim Sestic
Glenn,
Hehe...I thought you would spot that Kerry.
also added later:
Correct on both counts there Kerry and yes you definately shouldn't let reality ruin a good yarn.
