CAD Forums => CAD General => Topic started by: deegeecees on September 20, 2007, 01:52:04 PM
I think my Norton 360 hosed this file for some reason. I tried recovering, but get this:
INTERNAL ERROR: !saveres.cpp@440: eGeneralModelingFailure
BAK file is the same since I saved it right before this happened, and AutoSave file is non-existent for some reason ???!!! Arrrghhh! I'd appreciate it if someone could look and see if they can recover it, or find a solution. I don't want to redraw this thing.
Does this work for you, Deeg?
I got it to open, but there wasn't much left in the drawing. Just a title sheet and a bunch of layouts with nothing but title blocks.
Modeling Operation Error:
Missing integer in restore file.
Duplicate definition of block Generic 24in x 36in Title Block ignored.
I may have saved the model for you, only the layouts got lost along the way using MAP, and Design center.
The attached seems complete.
YES!! What did you do?
oh, and maaaany thankyou's are needed here.
Thankyou x (many)
I opened Kindra's, and all is well. I was looking to save the model, titleblock info isn't important, so thank you too Chuck, and MJF!
I think I just used my hand.....
RDRR
I tried pulling it in as a block, opening it with TrueView, and got bupkis. Pulling it in one piece at a time through design center was not an option as all geometry is in solids only form, not blocked (aside from the 53 foot chassis, and the 48 foot container). So, I'm just curious as to how anyone else was able to accomplish this, and I may need to repeat your actions sometime in the future.
That's what she said...
OMG why am I doing this! I can't stop myself.
Thankyou x (many)
Ancient Chinese Secret
(I opened it as a DWG in MicroStation and used FileFixer)
Glad it worked out - redrafting sucks!
You're just saying what we're all thinking.
:lol:
Thankyou x (many)
I guess I'll be directing all my hosed drawings towards you, since MS is not an option for me anymore. Just name your subscription fee.
You mean you fixed an AutoCad file with Microstation!!! :lmao: :lmao: :lmao: :lmao:
Thats a good one Kindra
Truth is I ran RECOVER on it, and Autocad accepted the recovered database.
It funny sometimes how cad behaves when my hand is on the mouse.
I can't offer any subscription fees, I give free support with all my classes, and here and there on the web as time permits. The web stuff is my learning lab, where I learn from others having issues and trying to solve or resolve them. Sometimes I learn more than others; how can I charge for that?
Thankyou x (many)
Okay. The charge is a gallon of green M&Ms, a case of South African Cabernet, a pogo stick and a three-legged dog.
and you thought it was an insult!
Heh...now we all know better.
Interesting: Adding insult to inquiry.
:-D
.....Must send Kindra, delivery address for all that swell booty she is offering.......
Wow, I need to hang out here more often, getting very friendly.
Done, done, and done. Except it's gonna take me a while to separate all the green one's from the rest, as I will be munching on them, and the pile may diminish after a short while.
BTW, whats the pogo stick for?
You can have me booty, but leave me chest alone!
Oh carp, wrong day. You guys are animals :lol:
Arrrr 'tis a fine day to be a cad pirate any day one is breathin'.
>Removed Cheese<
I'm a guessing t'will taking a bit more than "EXPLODE" to changing that property state.
*smacks his forehead*
that was cheesy.
I've got another one. I need to figure out why these are getting hosed. Ohhhhhh Kindra, you out there?
This is from running a recover:
Reading handle 644 object type AcDb3dSolid
Error 13 (eUnknownHandle)
It opens fine here after.
I can't even open it. It does however open in TrueView, but I can't save it from there. I could plot to a plt file, and maybe pull it in from that, but I don't have alot of time (ever) so I can't muck around with it. Thanks RJP!
Kindra did you ever get paid the first time?
If she ever makes it to one of our shows, she'll get "Paid"...
bwaaahahahahahaha.....
*cough*
Hey RonJonp, ummm, could you possibly save it down to 04? PlzKthnx.
Ahh, I am DLing the latest version of TrueView which converts. Thanks again!
Salvaged database from drawing.
Loading Modeler DLLs.
Error 13 (eUnknownHandle) Object discarded
Reading handle 3AB object type AcDb3dSolid
Error 151 (eOutOfRange) Object discarded
Opening an AutoCAD 2004 format file.
58 Blocks audited
Pass 1 696 objects audited
Pass 2 696 objects audited
Pass 3 19900 objects audited
Total errors found 0 fixed 0
Here is an '04 version.
Thanks T.
I was able to open it in Autocad 2007
It had two errors but it opened. If you need I will save it as 2004 Looks like someone beat me to it
Better????
Late for the party, aintcha? Thanks though.
FWIW I now have the DwgTrueVue2008, and it'll open/convert the suspect dwg, but doesn't retain all geometry. I may have to play with some settings. Or try another avenue.
