Author Topic: Blocks, Whats in there?  (Read 10033 times)
« on: March 27, 2004, 09:56:16 PM »
In a effort to understand block entity structure a little better I
Took some code and came up with this routine that writes a blocks
entity list to a text file. It works with nested blocks and xrefs
as well. I believe it writes the complete entity list of blocks,
entities and sub blocks to the text file.
Please test it for yourself.
Here is the test DWG I used. Block Test.dwg
Suggestions & comments welcome..
;;; FUNCTION BlockInfo.lsp
;;;   Send a block definition to text file "Block Data-[block name].txt"
;;;   You should view text file with word wrap off because
;;;   some of the lined are very long
;;; ARGUMENTS
;;;   none
;;; USAGE
;;;   BlockInfo
;;; PLATFORMS
;;; 2000+
;;; AUTHOR
;;; Copyright© 2004 Charles Alan Butler
;;;   ab2draft@TampaBay.rr.com
;;; VERSION
;;; 1.1 Sep. 23, 2004
;;; This routine may be used and copied for non-profit
;;;  purposes only. If you wish to include any of the file in a
;;;  commercial program, contact the author.
(defun c:BlockInfo (/ bname dxf data indent fname fn blkcnt indent)
  ;;  extract the data from dotted pair
  (defun dxf (x) (cdr (assoc x data)))
  (if (setq bname (entsel "Pick a block: "))
    (if (and (setq data (entget (car bname)))
    (or (= "INSERT" (dxf 0))
        (= "DIMENSION" (dxf 0))
) ;and
      (setq bname (dxf 2))
      (setq bname nil)
    ) ;if
  ) ;if
    (bname
     (setq Fname (Strcat "Block Data-" bname ".txt"))
     (setq fn (open  fname "w"))
     (prt "===============================================")
     (prt "                 BlockInfo.lsp")
     (prt "               Charles Alan Butler")
     (prt "            ab2draft@TampaBay.rr.com")
     (prt "               09/23/2004 Ver 1.1")
     (setq blkcnt 0
  indent "| "
     (listb bname)
     (prt "*********** END OF PARENT BLOCK *************")
     (setq indent nil)
     (prt "=             End of Routine                  =")
     (close fn)
     (prompt (strcat "\nBlock data written to file: " fname))
    (t (print " no block found."))
  ) ;cond
;;  do the actual line print to file
(defun prt (txt)
  (if indent
    (princ indent fn)
  (princ txt fn)
  (write-line "" fn)
;;  This sub routine does all the work
(defun listb (bname / dxf data wait)
  ;; return value from a dotted pair
  ;; begin the main program
  (if (= blkcnt 0)
    (setq header (strcat "         Parent Block : " bname))
    (setq header (strcat "          Sub Block "
(itoa blkcnt); number of nested levels
bname
  (prt "***********************************************")
  (prt header)
 ; (prt (setq data (tblsearch "block" bname)))
  (prt (setq data (entget(tblobjname "block" bname))))
  (prt "---------    Objects In Block  ----------------")
  (setq data (dxf -2)) ; get first entity
  (prt (setq data (entget data '("*")))) ; get assoc list
  (while data
    (if (= (dxf 0) "INSERT")
(setq blkcnt (1+ blkcnt)
     indent (strcat indent "| ")
(listb (dxf 2))
(setq indent (substr indent 3))
(prt "************ END OF SUB BLOCK **************")
    (if (setq data (entnext (dxf -1)))
  ) ;while
(prompt "\nBlock Info Loaded, Enter BlockInfo to run.")
;;;--- end of file -----------------------------------------
Re: Blocks, Whats in there?
« Reply #1 on: October 13, 2008, 10:41:14 PM »
I see I have a newer version.
;;; ARGUMENTS
;;;   none
;;; USAGE
;;;   BlockInfo
;;; PLATFORMS
;;; 2000+
;;; AUTHOR
;;; Copyright© 2004-2008 Charles Alan Butler
;;; VERSION
;;; 2.1 Oct 14, 2008
(defun c:BlockInfo (/ ent bname dxf data indent fname fn blkcnt indent)
  (if (setq ent (entsel "Pick a block: "))
    (if (and (setq data (entget (car ent)))
) ;and
      (setq bname nil)
    ) ;if
    (if (and
         (setq bname (getstring t "\nEnter the block name: "))
         (setq ss (ssget "_X" (list '(0 . "INSERT")(cons 2 bname))))
         (setq ename (ssname ss 0)))
      (princ); got a block
      (setq bname nil); GETNAME FAILED
      ); if
  ) ;if
    (bname
     ;;  Revised for dynamic blocks, code by Tim Willey
     (setq Fname (Strcat (getvar 'dwgprefix) "Block Data-"
                   (if (= (substr bname 1 1) "*") (strcat "-star-" (substr bname 2)) bname) ".txt"))
     ;;(setq Fname (Strcat (getvar 'dwgprefix) "Block Data-" bname ".txt"))
     (prc "===============================================")
     (prc "                 BlockInfo.lsp")
     (prc "               Charles Alan Butler")
     (prc "            ab2draft@TampaBay.rr.com")
     (prc "               04/06/2008 Ver 2.1")
      ;;  Create current Date & Time
      (setq tmp (rtos (getvar 'cdate) 2 4))
      (setq tmp (strcat "     <<  File Date "
                       (substr tmp 5 2) "/" (substr tmp 7 2) "/"
                       (substr tmp 1 4) "@" (substr tmp 10 2) ":"
                       (substr tmp 12 2) " >>"
     (prc tmp)
     (setq blkcnt 0
   indent "| "
     (if ent
         (prc "---------    Insert entlist   -----------------")
         (prt (entget (car ent)))
     (listb bname)
     (prc "*********** END OF PARENT BLOCK *************")
     (setq indent nil)
     (prc "=             End of Routine                  =")
     (close fn)
     (startapp "notepad" (findfile  Fname))
  ) ;cond
(defun prt (txt)
  (if indent
    (write-line (strcat indent (vl-prin1-to-string txt)) fn)
    (write-line (vl-prin1-to-string txt) fn)
(defun prc (txt)
  (if indent
    (write-line (strcat indent (vl-princ-to-string txt)) fn)
    (write-line (vl-princ-to-string txt) fn)
;;  This recrusive sub routine does all the work
  (if (= blkcnt 0)
bname
  (prc "***********************************************")
  (prc header)
  (prc "---------    Block entlist   ------------------")
  (prc "---------    Objects In Block  ----------------")
  (while data
(listb (dxf 2)) ; recrusive call for sub blocks
(prc "************ END OF SUB BLOCK **************")
  ) ;while
<edit: code updated>
« Last Edit: October 15, 2008, 07:21:23 PM by CAB »
taner
« Reply #2 on: October 14, 2008, 01:13:09 AM »
Dear CAB,
I do not understand the code: (entget data '("*")),can you explain it more clearly. Can you change the code,I want to get the ename list of all subentity.Thanks.
Is there another way? such as vlisp?
« Last Edit: October 14, 2008, 04:34:44 AM by taner »
« Reply #3 on: October 14, 2008, 05:19:43 AM »
Dear CAB,
In the Vlide editor type entget .  Then select the entget text so it is highlighted.
Then press Ctrl F1 ... and read the help ... it is fairly clear.
(entget ename [applist])
« Reply #4 on: October 14, 2008, 08:49:19 AM »
Runnig my routine, selecting a block named "blk1" like this:
Command: blockinfo
Initializing...
Block Info Loaded, Enter BlockInfo to run.Pick a block:
Block data written to file: [b]Block Data-blk1.txt[/b]
You need to open the text file "Block Data-blk1.txt"
and you would find this:
                 BlockInfo.lsp
               Charles Alan Butler
               04/06/2008 Ver 2.0
     <<  File Date 10/14/2008@08:38 >>
| ((-1 . <Entity name: 1c80778>) (0 . "INSERT") (330 . <Entity name: 1c6c810>) (5 . "A1FF") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "Duct") (100 . "AcDbBlockReference") (2 . "blk1") (10 1072.7 -166.344 0.0) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 1.0))
|          Parent Block : blk1
| ((-1 . <Entity name: 1c80498>) (0 . "BLOCK") (330 . <Entity name: 1c80490>) (5 . "A193") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockBegin") (70 . 0) (10 0.0 0.0 0.0) (-2 . <Entity name: 1c804a8>) (2 . "blk1") (1 . ""))
| ((-1 . <Entity name: 1c804a8>) (0 . "LWPOLYLINE") (330 . <Entity name: 1c80490>) (5 . "A195") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbPolyline") (90 . 4) (70 . 1) (43 . 0.0) (38 . 0.0) (39 . -0.76) (10 12.8495 36.7524) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 17.0811 36.7524) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 17.0811 17.9402) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 12.8495 17.9402) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c804b0>) (0 . "LWPOLYLINE") (330 . <Entity name: 1c80490>) (5 . "A196") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbPolyline") (90 . 4) (70 . 1) (43 . 0.0) (38 . 0.0) (39 . -0.76) (10 11.8112 10.0695) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 1.56641 10.0695) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 1.56641 28.753) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 11.8112 28.753) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c804b8>) (0 . "LWPOLYLINE") (330 . <Entity name: 1c80490>) (5 . "A197") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbPolyline") (90 . 10) (70 . 0) (43 . 0.5) (38 . 0.0) (39 . -0.76) (10 12.7473 0.0) (40 . 0.5) (41 . 0.5) (42 . 0.0) (10 0.0 0.0) (40 . 0.5) (41 . 0.5) (42 . 0.0) (10 0.0 38.7977) (40 . 0.5) (41 . 0.5) (42 . 0.0) (10 9.85533 38.7977) (40 . 0.5) (41 . 0.5) (42 . 0.0) (10 9.85533 38.7977) (40 . 0.5) (41 . 0.5) (42 . 0.0) (10 19.9437 38.7977) (40 . 0.5) (41 . 0.5) (42 . 0.0) (10 19.9437 38.7977) (40 . 0.5) (41 . 0.5) (42 . 0.0) (10 29.8757 38.7977) (40 . 0.5) (41 . 0.5) (42 . 0.0) (10 29.8757 0.0) (40 . 0.5) (41 . 0.5) (42 . 0.0) (10 17.1409 0.0) (40 . 0.5) (41 . 0.5) (42 . 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c804c0>) (0 . "LWPOLYLINE") (330 . <Entity name: 1c80490>) (5 . "A198") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbPolyline") (90 . 4) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . -0.76) (10 15.3658 8.87504) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 14.5649 8.87504) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 14.0521 9.3484) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 14.0521 17.9402) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c804c8>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A199") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 13.0686 17.1784 0.0) (11 16.9266 17.95 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c804d0>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A19A") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 17.1324 15.7896 0.0) (11 13.0686 17.1784 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c804d8>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A19B") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 13.1225 14.5653 0.0) (11 17.1594 15.7802 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c804e0>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A19C") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 17.1594 12.9584 0.0) (11 13.1225 14.5653 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c804e8>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A19D") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 13.0833 11.8611 0.0) (11 17.1594 12.9584 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c804f0>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A19E") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 17.2378 10.1367 0.0) (11 13.0833 11.8611 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c804f8>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A19F") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 13.1225 9.15689 0.0) (11 17.2378 10.1367 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c80500>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A1A0") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 17.1986 7.23653 0.0) (11 13.1225 9.15689 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c80508>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A1A1") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 13.0833 5.78647 0.0) (11 17.1986 7.23653 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c80510>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A1A2") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 17.2207 3.86134 0.0) (11 13.0833 5.78647 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c80518>) (0 . "LINE") (330 . <Entity name: 1c80490>) (5 . "A1A3") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbLine") (39 . -0.76) (10 13.1113 1.69204 0.0) (11 17.2207 3.86134 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c80520>) (0 . "LWPOLYLINE") (330 . <Entity name: 1c80490>) (5 . "A1A4") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbPolyline") (90 . 4) (70 . 1) (43 . 0.0) (38 . 0.0) (39 . -0.76) (10 18.1195 10.0695) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 28.3643 10.0695) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 28.3643 28.753) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 18.1195 28.753) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c80528>) (0 . "LWPOLYLINE") (330 . <Entity name: 1c80490>) (5 . "A1A5") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbPolyline") (90 . 6) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . -0.76) (10 14.5649 -3.16418) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 14.5649 1.13547) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 14.0521 1.60882) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 12.7898 1.60882) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 12.7898 -3.16418) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 14.5649 -3.16418) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c80530>) (0 . "LWPOLYLINE") (330 . <Entity name: 1c80490>) (5 . "A1A6") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbPolyline") (90 . 6) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . -0.76) (10 15.3658 -3.16418) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 15.3658 1.13547) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 15.8786 1.60882) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 17.1409 1.60882) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 17.1409 -3.16418) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 15.3658 -3.16418) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0))
| ((-1 . <Entity name: 1c80538>) (0 . "LWPOLYLINE") (330 . <Entity name: 1c80490>) (5 . "A1A7") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbPolyline") (90 . 4) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . -0.76) (10 14.5649 8.87504) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 15.3658 8.87504) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 15.8786 9.3484) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 15.8786 17.9402) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0))
=             End of Routine                  =
Andrea
« Reply #5 on: October 14, 2008, 09:18:08 AM »
nice one.. :-)
I put my contribution...
(if (findfile Fname)
(alert "Write permission denide")
revised.
« Last Edit: October 14, 2008, 09:35:18 AM by Andrea »
Keep smile...
« Reply #6 on: October 14, 2008, 09:30:40 AM »
Good idea Andrea!
« Reply #7 on: October 14, 2008, 11:30:04 AM »
hey CAB,
FWIW..I also added the (getvar 'dwgprefix) to your fname so the output file would be in the same directory.
Ron
« Reply #8 on: October 14, 2008, 11:44:51 AM »
Picky picky picky.
Just kidding, I updated the version 2.1 with the suggestions.
Comments & suggestions are always welcome. :-)
Two heads are better than one.
« Reply #9 on: October 14, 2008, 11:59:05 AM »
« Reply #10 on: October 15, 2008, 06:59:31 PM »
Alan,
  You maybe want to change it for dynamic blocks, as the star in the name of the block will make it error.  I just tried it and it error'ed out of me; just and FYI.
My quick fix.
(setq Fname (Strcat (getvar 'dwgprefix) "Block Data-" (if (= (substr bname 1 1) "*") (strcat "-star-" (substr bname 2)) bname) ".txt"))
« Reply #11 on: October 15, 2008, 07:22:13 PM »
Thanks Tim, I updated the code above with your fix.
« Reply #12 on: August 17, 2009, 08:12:26 AM »
Latest version attached.
GDF
« Reply #13 on: August 18, 2009, 11:39:22 AM »
Using 2010 version.
Pick a block: ; error: bad argument type: lentityp nil
I tried it on an attributed block...It still writes out to file.
« Last Edit: August 18, 2009, 11:46:43 AM by GDF »
« Reply #14 on: August 18, 2009, 12:12:38 PM »
Fails in this loop:
(while
             (/= (assoc 0 (setq elst (entget (setq ent (entnext ent))))) "")
