Author Topic: [XDrX-PlugIn(163)] Dynamically display the area ect.. information of rectange  (Read 85 times)
xdcad
https://www.cadtutor.net/forum/topic/70763-display-the-area-by-picking-rectangle/
(defun c:xdtb_dynrecarea (/ #mcolor cen data dynpt height lastpnt mArea nums
    p-1 p2 p-2 pn1 pt1 pt2 pts str txt wid
  (defun _callback (dynpt)
    (if (not (and
       (equal pn1 dynpt 1e-3)
       (equal lastpnt dynpt 1e-3)
(setq lastpnt dynpt
      pt2 (xdrx-getpropertyvalue (list pn1 p-2) "getclosestpointto"
dynpt t
(setq pt1 (xdrx-getpropertyvalue (list pn1 p-1) "getclosestpointto"
dynpt t
      wid (distance pt2 dynpt)
      height (distance pt1 dynpt)
      pts (list pt2 dynpt pt1 pn1)
      cen (xdrx-line-midp dynpt pn1)
      mArea (* wid height)
      nums (length data)
      str (xdrx-string-formatex (xdrx-string-multilanguage "宽度= %.1f\r\n高度= %.1f\r\n面积=%.1f" "Width= %.1f\r\nHeight= %.1f\r\nArea=%.1f")
wid height mArea
(xd::grdraw:drawtext txt str cen 5 (* (getvar "viewsize") 0.025) 2
     (getvar "ucsxdir") nil 8
    str
  (xdrx-begin)
  (xdrx-sysvar-push '("osmode" 8))
  (if (setq pn1 (getpoint (xdrx-string-multilanguage "\n矩形起始点<退出>:" "\nRect Start Point<Exit>:")))
      (setq #mcolor 1)
      (setq p-1 (mapcar
  pn1
  '(1 0 0)
    p-2 (mapcar
  pn1
  '(0 1 0)
    txt (xdrx-mtext-make)
      (XD::Drag:CallBackSetMouseMove "_callback")
      (if (setq p2 (xd::doc:getcorner pn1
      (xdrx-string-multilanguage "\n对角点<退出>:" "\ndiagonal point<Exit>:")
      #mcolor '(1 0 0)
  (xdrx-polyline-make pts t)
  (xdrx-setpropertyvalue (entlast) "color" #mcolor)
  (xdrx-prompt (strcat "\n" str))
      (xdrx-pointmonitor)
  (xdrx-end)
The code I wrote uses XDRX-API,which can be downloaded from github.com and is updated at any time.
https://github.com/xdcad
https://sourceforge.net/projects/xdrx-api-zip/
http://bbs.xdcad.net
