Author Topic: finding nested xrefs - AutoLISP  (Read 4045 times)
jbuzbee
« on: January 24, 2020, 08:44:19 AM »
I have a routine that "backs up" files.  It works fine but I need find out which xrefs are nested.
Thanks for any help
James Buzbee
Windows 8
jbuzbee
Re: finding nested xrefs - AutoLISP
« Reply #2 on: January 24, 2020, 10:36:49 AM »
This looks like a good start - Thanks!
James Buzbee
Windows 8
« Reply #3 on: January 24, 2020, 10:39:51 AM »
Below is a variation of the code I previously posted here, modified to apply to xrefs only:
  1. (defun _nestedxrefs ( blk / enx rtn xrn )
  2.    (while (setq blk (entnext blk))
  3.        (if (and (setq enx (entget blk))
  4.                 (= "INSERT" (cdr (assoc 0 enx)))
  5.                 (setq xrn (cdr (assoc 2 enx)))
  6.                 (= 4 (logand 4 (cdr (assoc 70 (tblsearch "block" xrn)))))
  7.                 (not (member xrn rtn))
  8.            )
  9.            (setq rtn (cons xrn rtn))
  10.        )
  11.    )
  12.    rtn
  13. )
  14. (defun _xrefhierarchy ( / blk def nst rtn )
  15.    (while (setq def (tblnext "block" (null def)))
  16.        (if (or (setq blk (cdr (assoc 2 def))
  17.                      nst (_nestedxrefs (tblobjname "block" blk))
  18.                )
  19.                (= 4 (logand 4 (cdr (assoc 70 def))))
  20.            )
  21.            (setq rtn (cons (cons blk nst) rtn))
  22.        )
  23.    )
  24.    rtn
  25. )
  26. (defun _printxrefhierarchy ( blk lst ind )
  27.    (terpri)
  28.    (repeat ind (princ "    "))
  29.    (princ "+---")
  30.    (if (setq nst (cdr (assoc blk lst)))
  31.        (progn
  32.            (princ "+ ")
  33.            (princ blk)
  34.            (foreach sub nst
  35.                (_printxrefhierarchy sub lst (1+ ind))
  36.            )
  37.        )
  38.        (progn
  39.            (princ "> ")
  40.            (princ blk)
  41.        )
  42.    )
  43. )
  44. (defun c:xrefhierarchy ( )
  45.    (   (lambda ( lst )
  46.            (foreach blk lst
  47.                (_printxrefhierarchy (car blk) lst 0)
  48.            )
  49.            (textpage)
  50.        )
  51.        (_xrefhierarchy)
  52.    )
  53.    (princ)
  54. )
« Reply #4 on: January 24, 2020, 10:49:19 AM »
Alternatively, here's a predicate function that will return T if the supplied block name corresponds to a nested xref:
  1. (defun nestedxref-p ( xrn / def ent enx flg tmp )
  2.     (and
  3.         (setq def (tblsearch "block" (setq xrn (strcase xrn))))
  4.         (= 4 (logand 4 (cdr (assoc 70 def))))
  5.         (progn
  6.             (while
  7.                 (and
  8.                     (setq tmp (tblnext "block" (not tmp)))
  9.                     (not flg)
  10.                 )
  11.                 (setq ent (tblobjname "block" (cdr (assoc 2 tmp))))
  12.                 (while
  13.                     (and
  14.                         (setq ent (entnext ent))
  15.                         (not flg)
  16.                     )
  17.                     (setq flg
  18.                         (and
  19.                             (setq enx (entget ent))
  20.                             (= "INSERT" (cdr (assoc 0 enx)))
  21.                             (= xrn (strcase (cdr (assoc 2 enx))))
  22.                         )
  23.                     )
  24.                 )
  25.             )
  26.             flg
  27.         )
  28.     )
  29. )
  1. (nestedxref-p "YourXRefName")
« Reply #5 on: January 24, 2020, 11:30:13 AM »
@Lee .. would something like this work as well?
  1. (defun _nested (bn / e)
  2.   (and (setq e (tblsearch "block" bn))
  3.        (= 4 (logand 4 (cdr (assoc 70 e))))
  4.        (null (ssget "_X" (list '(0 . "insert") (cons 2 bn))))
  5.   )
  6. )
« Reply #6 on: January 24, 2020, 02:12:46 PM »
  5.   )
  6. )
Good suggestion Ron, but that could return false positives for unreferenced xrefs.
« Reply #7 on: January 27, 2020, 09:27:15 AM »
  5.   )
  6. )
Ahhh yes .. good point :)
kenkrupa
« Reply #8 on: October 14, 2021, 01:17:18 PM »
Thank you Lee Mac for nestedxref-p -- just what I needed!
ribarm
  • Marko Ribar, architect
« Reply #9 on: June 27, 2022, 11:49:21 PM »
Real fun with XXX...
M.R. on Youtube
cadpoobah
« Reply #10 on: May 06, 2024, 02:28:46 PM »
  3. ...
  4.        (_xrefhierarchy)
  5.    )
  6.    (princ)
  7. )
Excellent, Lee. Thanks for sharing.
Curious, what is the order of the list that (_xrefhierarchy) returns? Is it random based on how tblnext finds the refs? Also, does it always list the "deepest" (child) references first, followed by any parent xrefs w child xrefs?
What I see is something like this:
  (("Child1") ("Child2") ("Childn") ("Parent1" "Child1") ("Parent2" "Child2")...)
Chris Lindner
Onebutton CAD Solutions
www.onebuttoncad.com #dayjob
www.unpavedart.com    #sidehustle
« Reply #11 on: May 07, 2024, 05:03:23 AM »
You're welcome  :-)
The order in which they are encountered in the block symbol table, in reverse (though, a simple sort could easily be applied).
No - the list is merely the order in which they are encountered in the block symbol table; the nesting hierarchy is determined by recursively querying list items with multiple entries against the original list when printing the output.
