Author Topic: Importing Layer controls without opening drawings  (Read 10470 times)
0 Members and 7 Guests are viewing this topic.
Re: Importing Layer controls without opening drawings
« Reply #15 on: July 10, 2014, 01:51:03 PM »
I have been working on this for a few... no such luck with calling a script. However, this is pretty powerful stuff!:)
The script is on my C root drive...
Are you unable to run the program?
Note that my program is utilising ObjectDBX to batch process all selected drawings, no AutoCAD Script (.scr) is necessary.
MSTG007
« Reply #16 on: July 10, 2014, 01:54:42 PM »
your program runs great and opens! I have a script file I was seeing if I could run it.
Civil3D 2020
« Reply #17 on: July 10, 2014, 02:26:54 PM »
What are you attempting to use the script file for?
MSTG007
« Reply #18 on: July 10, 2014, 02:30:53 PM »
Built kinda with the first request with the layers. What you provided above was; a way to add revision layers to a bunch of dwgs at the same time. So as it prompts for the layer name and color. (Layer name REVISION1, Color 4), next revision would happen (Layer name REVISION2, Color 4), but change (Layer name REVISION1, to color 9), and so forth with as many revisions there may need. so the Color 4 is bold and the color 9 I screened back.
Civil3D 2020
« Reply #19 on: July 10, 2014, 02:37:52 PM »
So presumably you would incorporate the additional operations to switch REVISION1 to colour 9 into the program I have provided - i.e. into the function argument passed to the LM:odbx function.
I am not sure if you have taken the operations from the code I have provided to use in a Script, or are attempting to call the program I have provided through a Script, but either way, a Script is not required.
MSTG007
« Reply #20 on: July 10, 2014, 02:41:18 PM »
Yes you are right. For me it was easier to code it under the script I do not completely understand how you the operations of your program. lol. I am trying though! lol. But as you stated above yes that is what I would like to do.
Civil3D 2020
« Reply #21 on: July 10, 2014, 02:53:57 PM »
OK - The following code should get you off to a good start:
  1. (defun c:test ( / lay lst nco new oco old )
  2.     (while (not (or (= "" (setq new (getstring t "\nSpecify new layer name <skip>: "))) (snvalid lay)))
  3.         (princ "\nInvalid layer name.")
  4.     )
  5.     (if (or (= "" new) (setq nco (acad_colordlg 7 nil)))
  6.         (progn
  7.             (while (not (or (= "" (setq old (getstring t "\nSpecify old layer name <skip>: "))) (snvalid lay)))
  8.                 (princ "\nInvalid layer name.")
  9.             )
  10.             (if (or (= "" old) (setq oco (acad_colordlg 7 nil)))
  11.                 (if (setq lst (LM:getfiles "Select drawings to process" "" "dwg;dwt;dws"))
  12.                     (LM:odbx
  13.                        '(lambda ( doc / lay )
  14.                             (if (/= "" new)
  15.                                 (vla-put-color (vla-add (vla-get-layers doc) new) nco)
  16.                             )
  17.                             (if (and (/= "" old)
  18.                                     (not
  19.                                         (vl-catch-all-error-p
  20.                                             (setq lay
  21.                                                 (vl-catch-all-apply 'vla-item
  22.                                                     (list (vla-get-layers doc) old)
  23.                                                 )
  24.                                             )
  25.                                         )
  26.                                     )
  27.                                 )
  28.                                 (vla-put-color lay oco)
  29.                             )
  30.                         )
  31.                         lst t
  32.                     )
  33.                 )
  34.             )
  35.         )
  36.     )
  37.     (princ)
  38. )
MSTG007
« Reply #22 on: July 10, 2014, 03:04:24 PM »
Wow Sweet! Thank you.
Civil3D 2020
MSTG007
« Reply #23 on: July 10, 2014, 03:17:19 PM »
Well, I did get a chance to look at it. The following code is what I tried to put together into one lisp like they suggested above.
                    (LM:odbx
                            (if (/= "" new)
                                    (not
                                           (setq lay
                        lst t
;;------------------=={ Get Files Dialog }==------------------;;
;;  An analog of the 'getfiled' function for multiple files.  ;;
;;  Author: Lee Mac, Copyright © 2013 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  msg - Dialog box label; 'Select Files' if nil or "".      ;;
;;  def - Default directory; dwgprefix if nil or "".          ;;
;;  ext - File extension filter (e.g. "dwg;lsp"); "*" if nil  ;;
;;  Returns:  List of selected files, else nil                ;;
;;  Version 1.3    -    25-07-2013                            ;;
(defun LM:getfiles ( msg def ext / *error* dch dcl des dir dirdata lst rtn )
    (defun *error* ( msg )
        (if (= 'file (type des))
            (close des)
        (if (and (= 'int (type dch)) (< 0 dch))
            (unload_dialog dch)
        (if (and (= 'str (type dcl)) (findfile dcl))
            (vl-file-delete dcl)
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
        (and
            (setq dcl (vl-filename-mktemp nil nil ".dcl"))
            (setq des (open dcl "w"))
                (foreach x
                        "lst : list_box"
                        "    width = 40.0;"
                        "    height = 20.0;"
                        "    fixed_width = true;"
                        "    fixed_height = true;"
                        "    alignment = centered;"
                        "    multiple_select = true;"
                        "but : button"
                        "    width = 20.0;"
                        "    height = 1.8;"
                        "getfiles : dialog"
                        "    key = \"title\"; spacer;"
                        "    : row"
                        "        : edit_box { key = \"dir\"; label = \"Folder:\"; }"
                        "        : button"
                        "            key = \"brw\";"
                        "            label = \"Browse\";"
                        "    spacer;"
                        "    : row"
                        "        : column"
                        "            : lst { key = \"box1\"; }"
                        "            : but { key = \"add\" ; label = \"Add Files\"; }"
                        "        : column {"
                        "            : lst { key = \"box2\"; }"
                        "            : but { key = \"del\" ; label = \"Remove Files\"; }"
                        "    spacer; ok_cancel;"
                    (write-line x des)
                (setq des (close des))
                (< 0 (setq dch (load_dialog dcl)))
            (new_dialog "getfiles" dch)
            (setq ext (if ext (LM:getfiles:str->lst (strcase ext) ";") '("*")))
            (set_tile "title" (if (member msg '(nil "")) "Select Files" msg))
            (set_tile "dir"
                (setq dir
                    (LM:getfiles:fixdir
                        (if (or (member def '(nil "")) (not (vl-file-directory-p (LM:getfiles:fixdir def))))
                            (getvar 'dwgprefix)
                            def
            (setq lst (LM:getfiles:updatefilelist dir ext nil))
            (mode_tile "add" 1)
            (mode_tile "del" 1)
            (action_tile "brw"
                (vl-prin1-to-string
                   '(if (setq tmp (LM:getfiles:browseforfolder "" nil 512))
                        (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir tmp)) ext rtn)
                              rtn (LM:getfiles:updateselected dir rtn)
            (action_tile "dir"
                (vl-prin1-to-string
                   '(if (= 1 $reason)
                        (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:fixdir $value))) ext rtn)
            (action_tile "box1"
                (vl-prin1-to-string
                        (lambda ( / itm tmp )
                            (if (setq itm (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" $value ")"))))
                                (if (= 4 $reason)
                                        (   (equal '("..") itm)
                                            (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:updir dir))) ext rtn)
                                        (   (and
                                                (not (vl-filename-extension (car itm)))
                                                (vl-file-directory-p (setq tmp (LM:getfiles:checkredirect (strcat dir "\\" (car itm)))))
                                        (   (setq rtn (LM:getfiles:sort (append rtn (mapcar '(lambda ( x ) (strcat dir "\\" x)) itm)))
                                                  lst (LM:getfiles:updatefilelist dir ext rtn)
                                    (if (vl-some 'vl-filename-extension itm)
                                        (mode_tile "add" 0)
            (action_tile "box2"
                (vl-prin1-to-string
                        (lambda ( / itm )
                            (if (setq itm (mapcar '(lambda ( n ) (nth n rtn)) (read (strcat "(" $value ")"))))
                                (if (= 4 $reason)
                                    (setq rtn (LM:getfiles:updateselected dir (vl-remove (car itm) rtn))
                                    (mode_tile "del" 0)
            (action_tile "add"
                (vl-prin1-to-string
                        (lambda ( / itm )
                            (if (setq itm
                                    (vl-remove-if-not 'vl-filename-extension
                                        (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" (get_tile "box1") ")")))
                            (mode_tile "add" 1)
                            (mode_tile "del" 1)
            (action_tile "del"
                (vl-prin1-to-string
                        (lambda ( / itm )
                            (if (setq itm (read (strcat "(" (get_tile "box2") ")")))
                                (setq rtn (LM:getfiles:updateselected dir (LM:getfiles:removeitems itm rtn))
                            (mode_tile "add" 1)
                            (mode_tile "del" 1)
            (if (zerop (start_dialog))
                (setq rtn nil)
    (*error* nil)
    rtn
(defun LM:getfiles:listbox ( key lst )
    (start_list key)
    (foreach x lst (add_list x))
    (end_list)
    lst
(defun LM:getfiles:listfiles ( dir ext lst )
    (vl-remove-if '(lambda ( x ) (member (strcat dir "\\" x) lst))
            (   (cdr (assoc dir dirdata)))
            (   (cdar
                    (setq dirdata
                        (cons
                            (cons dir
                                (append
                                    (LM:getfiles:sortlist (vl-remove "." (vl-directory-files dir nil -1)))
                                    (LM:getfiles:sort
                                        (if (member ext '(("") ("*")))
                                            (vl-directory-files dir nil 1)
                                            (vl-remove-if-not
                                                (function
                                                    (lambda ( x / e )
                                                        (and
                                                            (setq e (vl-filename-extension x))
                                                            (setq e (strcase (substr e 2)))
                                                            (vl-some '(lambda ( w ) (wcmatch e w)) ext)
                            dirdata
(defun LM:getfiles:checkredirect ( dir / itm pos )
        (   (vl-directory-files dir) dir)
        (   (and
                (=  (strcase (getenv "UserProfile"))
                    (strcase (substr dir 1 (setq pos (vl-string-position 92 dir nil t))))
                (setq itm
                    (cdr
                        (assoc (substr (strcase dir t) (+ pos 2))
                                ("my documents" . "Documents")
                                ("my pictures"  . "Pictures")
                                ("my videos"    . "Videos")
                                ("my music"     . "Music")
                (vl-file-directory-p (setq itm (strcat (substr dir 1 pos) "\\" itm)))
            itm
        (   dir   )
(defun LM:getfiles:sort ( lst )
    (apply 'append
        (mapcar 'LM:getfiles:sortlist
            (vl-sort
                (LM:getfiles:groupbyfunction lst
                    (lambda ( a b / x y )
                        (and
                            (setq x (vl-filename-extension a))
                            (setq y (vl-filename-extension b))
                            (= (strcase x) (strcase y))
                (function
                        (and
                            (setq x (vl-filename-extension (car a)))
                            (setq y (vl-filename-extension (car b)))
                            (< (strcase x) (strcase y))
(defun LM:getfiles:sortlist ( lst )
    (mapcar (function (lambda ( n ) (nth n lst)))
        (vl-sort-i (mapcar 'LM:getfiles:splitstring lst)
            (function
                    (while
                        (and
                            (setq x (car a))
                            (setq y (car b))
                            (= x y)
                        (setq a (cdr a)
                              b (cdr b)
                        (   (null x) b)
                        (   (null y) nil)
                        (   (and (numberp x) (numberp y)) (< x y))
                        (   (= "." x))
                        (   (numberp x))
                        (   (numberp y) nil)
                        (   (< x y))
(defun LM:getfiles:groupbyfunction ( lst fun / tmp1 tmp2 x1 )
    (if (setq x1 (car lst))
            (foreach x2 (cdr lst)
                (if (fun x1 x2)
                    (setq tmp1 (cons x2 tmp1))
                    (setq tmp2 (cons x2 tmp2))
            (cons (cons x1 (reverse tmp1)) (LM:getfiles:groupbyfunction (reverse tmp2) fun))
(defun LM:getfiles:splitstring ( str )
        (lambda ( l )
            (read
                (strcat "("
                    (vl-list->string
                        (apply 'append
                            (mapcar
                                (function
                                    (lambda ( a b c )
                                            (   (= 92 b)
                                                (list 32 34 92 b 34 32)
                                            (   (or (< 47 b 58)
                                                    (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                                                    (and (= 46 b) (< 47 a 58) (< 47 c 58))
                                                (list b)
                                            (   (list 32 34 b 34 32))
                                (cons nil l) l (append (cdr l) '(( )))
        (vl-string->list (strcase str))
(defun LM:getfiles:browseforfolder ( msg dir flg / err fld pth shl slf )
    (setq err
        (vl-catch-all-apply
            (function
                (lambda ( / app hwd )
                    (if (setq app (vlax-get-acad-object)
                              shl (vla-getinterfaceobject app "shell.application")
                              hwd (vl-catch-all-apply 'vla-get-hwnd (list app))
                              fld (vlax-invoke-method shl 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) msg flg dir)
                        (setq slf (vlax-get-property fld 'self)
                              pth (LM:getfiles:fixdir (vlax-get-property slf 'path))
    (if slf (vlax-release-object slf))
    (if fld (vlax-release-object fld))
    (if shl (vlax-release-object shl))
    (if (vl-catch-all-error-p err)
        (prompt (vl-catch-all-error-message err))
        pth
The above is just a snippet of the file that I have attached.
It asks me a layer and I enter REVISION1 and then errors out.
Civil3D 2020
« Reply #24 on: July 10, 2014, 03:27:58 PM »
Sorry, I forgot to rename a few variables, try the attached.
MSTG007
« Reply #25 on: July 10, 2014, 03:42:05 PM »
dude... fully working over here! Its gonna be scary what things I can think about using this for... way cool. :mrgreen:
Civil3D 2020
« Reply #26 on: July 10, 2014, 04:53:28 PM »
Excellent to hear - I hope it saves you some time  :-)
HasanCAD
« Reply #27 on: July 12, 2014, 03:13:10 AM »
I belive that, this routine will be great if can read from Excel file (which has old and new layers) and names as "LAYTRANS-update"
MSTG007
« Reply #28 on: July 14, 2014, 07:15:04 AM »
Is it possible with this routine to do a batch xref. Lets say I have a project. All the files dwgs have the job number in the name. I then copy it to a new jopb number and rename those files. Can this possible help replace the paths with dwgs I have renamed rather than opening each drawing and browsing for each xref in all the drawings? :ugly:
Civil3D 2020
« Reply #29 on: July 14, 2014, 12:42:50 PM »
Certainly possible - but unfortunately more time & work than I can justify donating to the forum...
Yes, this should be possible -
You can simply pass a function to my LM:odbx function to modify the ActiveX Path property for each of your xrefs.
Here is a very rough example:
  1. (defun c:test ( / lst )
  2.     (if (setq lst (LM:getfiles "Select drawings to process" "" "dwg;dwt;dws"))
  3.         (LM:odbx
  4.            '(lambda ( doc / str )
  5.                 (vlax-for blk (vla-get-blocks doc)
  6.                     (if (and (= :vlax-true (vla-get-isxref blk))
  7.                              (wcmatch (setq str (vla-get-path blk)) "*oldjobnumber*")
  8.                         )
  9.                         (vla-put-path blk (vl-string-subst "newjobnumber" "oldjobnumber" str))
  10.                     )
  11.                 )
  12.             )
  13.             lst t
  14.         )
  15.     )
  16.     (princ)
  17. )
