Author Topic: Polyligne over a mtext or a dtext  (Read 5616 times)
fabcad
« on: April 21, 2011, 04:01:53 AM »
Hello everyone,
I would like a function that would create a polyline with the angle and length of a text or mtext.
Thank you.
Brick_top
Re: Polyligne over a mtext or a dtext
« Reply #1 on: April 21, 2011, 07:29:12 AM »
Hi there... not quite this, but it's the best I could do... I'm a beginner  :oops:
(defun rpg (a)
(* a (/ 180.0 pi))
(defun gpr (a)
  (* pi (/ a 180.0))
(defun c:lot ()
  (setq t1 (entget (car (entsel "\nSelect text Object: ")))
tc (textbox (list (assoc 1 t1)))
ti (cdr (assoc 10 t1))
th (/ (cdr (assoc 40 t1)) 2)
ta (rpg (cdr (assoc 50 t1)))
nc (mapcar '(lambda (x) (list (+ (car x)(car ti))(+ (cadr x)(cadr ti)))) tc)
nc1 (polar (car nc) (gpr (+ 90.0 ta)) th)
nc2 (polar (cadr nc) (gpr (- 90.0 ta)) th)
nd (distance nc1 nc2)
nnf (polar nc1 (cdr (assoc 50 t1)) nd)
  );setq
 (entmake (list (cons 0 "line")(cons 10 nc1)(cons 11 nnf)))
);defun
Tharwat
  • Hypersensitive
« Reply #2 on: April 21, 2011, 07:44:57 AM »
Check this out Buddy . :-)
It is for dtext only and I could make it with Mtext but it is a matter of time only .
(defun C:Test (/ ss)
 ; Tharwat
  (prompt "\nSelect texts: ")
  (if (setq ss (ssget "_:L" '((0 . "TEXT"))))
    ((lambda (i / ent e aa ab ac p1 p2)
       (while (setq ent (ssname ss (setq i (1+ i))))
         (setq h (cdr (assoc 40 (entget ent))))
         (setq e (textbox (list
                            (cons -1 ent)
         (command "ucs" "Object" ent)
         (setq aa (car e)
               ab (cadr e)
               ac (list (car ab) (cadr aa))
         (command "_.pline"
                  "_non"
                  (setq p1 (list (car aa) (+ (cadr aa) (/ h 2))))
                  "_non"
                  (setq p2 (list (car ac) (+ (cadr ac) (/ h 2))))
         (command "_.ucs" "_p")
      -1
    (alert "No TEXT(s) selected")
« Reply #3 on: April 21, 2011, 08:15:04 AM »
This will only work with Single-Line Text or MText with a Single Line, but will work in all UCS/Views:
(defun c:test ( / ss i e l )
  (if (setq ss (ssget '((0 . "TEXT,MTEXT"))))
      (setq e (ssname ss (setq i (1- i)))
            l (entget e)
      (entmakex
        (append
          (list
            (cons 0 "LWPOLYLINE")
            (cons 100 "AcDbEntity")
            (cons 100 "AcDbPolyline")
            (assoc 8 l)
            (cons 90 4)
            (cons 70 1)
            (cons 38 (caddr (cdr (assoc 10 l))))
            (assoc 210 l)
          (mapcar '(lambda ( x ) (cons 10 x)) (LM:Strikethrough e))
(defun LM:Strikethrough ( e / dx a b h l m n o p r tb w y )
  ;; © Lee Mac 2011
  (defun dx ( x l ) (cdr (assoc x l)))
    (setq l
          (eq "TEXT" (dx 0 (setq e (entget e))))
          (setq b  (dx 10 e)
                r  (dx 50 e)
                tb (textbox e)
                y  (/ (+ (cadar tb) (cadadr tb)) 2.)
          (list (list (caar  tb) y) (list (caadr tb) y))
          (eq "MTEXT" (dx 0 e))
          (setq n (dx 210 e)
                b (trans (dx 10 e) 0 n)
                r (angle '(0. 0. 0.) (trans (dx 11 e) 0 n))
                w (dx 42 e)
                h (dx 43 e)
                a (dx 71 e)
          (setq h
              ( (member a '(1 2 3)) (/ h -2.) )
              ( (member a '(4 5 6)) 0. )
              ( (/ h 2.) )
          (setq o
              ( (member a '(2 5 8)) (/ w -2.) )
              ( (member a '(3 6 9)) (- w) )
              ( 0. )
          (list (list o h) (list (+ o w) h))
      (setq m
        (list
          (list (cos r) (sin (- r)) 0.)
          (list (sin r) (cos    r)  0.)
          (list   0.        0.      1.)
        b (reverse (cdr (reverse b)))
      (mapcar
        (function
          (lambda ( p )
            (mapcar '+
              (mapcar
                (function
                  (lambda ( x ) (apply '+ (mapcar '* x p)))
                m
              b
        l
fabcad
« Reply #4 on: April 21, 2011, 08:21:08 AM »
Thank you,
Unfortunately, the first functions do not work in my AutoCAD MAP 3D 2009.
Thank you Lee Mac
Your function works well with both types of texts.
This website is really good, for being French, insert pictures are very helpful to understanding.
Good day
See you soon.
« Last Edit: April 21, 2011, 08:26:17 AM by fabcad »
« Reply #5 on: April 21, 2011, 08:41:47 AM »
You're very welcome (de rien) fabcad, enjoy :wink:
Tharwat
  • Hypersensitive
« Reply #6 on: April 21, 2011, 08:45:07 AM »
*cough* .... *cough*
« Reply #7 on: April 21, 2011, 09:17:09 AM »
That's a winner Lee. 8-)
« Reply #8 on: April 21, 2011, 09:45:20 AM »
Thanks Alan  8-)
alanjt
  • Standby for witty remark...
« Reply #9 on: April 21, 2011, 09:49:25 AM »
Very nice Lee. I needed the same thing one day a while back and quickly wrote this one, but I'll be replacing it with yours in case I need it again.
(defun c:STR (/ foo ss r)
  ;; Strike through MText/Text (draw line through middle of selected text objects)
  ;; Alan J. Thompson, 09.20.10
  (defun foo (o / a b)
    (vla-getboundingbox o 'a 'b)
    (mapcar 'set '(a b) (mapcar 'vlax-safearray->list (list a b)))
    (list o
          (vlax-ename->vla-object
            (entmakex (list '(0 . "LINE")
                            (list 10 (car a) (/ (+ (cadr a) (cadr b)) 2.))
                            (list 11 (car b) (/ (+ (cadr a) (cadr b)) 2.))
  (if (setq ss (ssget "_:L" '((0 . "MTEXT,TEXT"))))
      (vlax-for x (setq ss (vla-get-activeselectionset
                             (cond (*AcadDoc*)
                                   ((setq *AcadDoc* (vla-get-activedocument
                                                      (vlax-get-acad-object)
        (setq r (vla-get-rotation x))
        (vla-put-rotation x 0.)
        (foreach i (foo x) (vla-rotate i (vla-get-insertionpoint x) r))
      (vla-delete ss)
Dropbox
« Reply #10 on: April 21, 2011, 09:55:16 AM »
Nice one Alan  8-)
alanjt
« Reply #11 on: April 21, 2011, 09:59:40 AM »
Nice one Alan  8-)
Thanks. Mine gets hosed if the text has a crazy width. I use a zero width for all text, unless I'm typing notes in paperspace, so I didn't think of that. I like yours a lot more.
I actually use this macro to place MText so I can easily get MText with a zero width:
; mtext with 0 width
(defun c:T (/ pt)
  (initdia)
  (command "_.mtext")
  (if (setq pt (getpoint "\nSpecify insertion point <First corner>: "))
    (command "_non" pt "_W" 0.)
Dropbox
« Reply #12 on: April 21, 2011, 10:04:20 AM »
Nice one Alan  8-)
I actually use this macro to place MText so I can easily get MText with a zero width.
Good idea - zero-width MText is much tidier IMO and that macro saves having to draw the MText window.
HTH
alanjt
« Reply #13 on: April 21, 2011, 10:12:44 AM »
Nice one Alan  8-)
HTH
Thanky Thanky. If you notice, it will continue with normal MText behavior if you right-click when prompted fro insertion point - for those time I'm placing notes in paperspace.  ^-^
Dropbox
« Reply #14 on: April 21, 2011, 10:19:23 AM »
 :kewl:
