Author Topic: Dynamic Intelligent Leader !  (Read 181473 times)
Andrea
Re: Dynamic Intelligent Leader !
« Reply #120 on: September 04, 2009, 12:56:58 PM »
My compliments for your work Andrea!
I found a problem when I use a new UCS.
If not set as current WCS, at the prompt "Pick Text location..." text is positioned away from the cursor.
I have not found where to enter the function
(trans pt from 0 1)
FIXED !  thanks.
Keep smile...
Andrea
« Reply #121 on: September 04, 2009, 12:59:01 PM »
Hallo Andrea
Ich glaube die Pfeilgröße wird falsch berechnet.
feste !   ( FIXED ! )
Keep smile...
« Reply #122 on: September 04, 2009, 01:40:36 PM »
Dialog box... :angel:
Yes,..this can be done.. thanks.   :kewl:
But,..maybe I can ask..?
Dialog DiLEADER contest ?
something like....:
Andrea, is that OpenDCL?
Andrea
« Reply #123 on: September 04, 2009, 02:05:19 PM »
something like....:
Was made with QuickPreview Button from..
www.ObjectDCL.com
...sorry.  ;-)
Keep smile...
Andrea
« Reply #124 on: September 07, 2009, 11:44:22 PM »
New Release..
DiLEADER v.2.2.3
Fixes and novelties:
   - Bug Fix with DiLCUSTOMARROW allowing user to browse folder
   - Some Princ message fixed
   - Bug Fix with diffrent Dimstyle than "Standard"
   - Bug Fix if Dimasz and Dimtxt is set to 0 (default = dimscale)
   - Bug Fix with UCS WCS conversion.
   - By pressing CANCEL on DLCUSTOMARROW function this will allow user
     to remove the DiLEADER Custom Arrow Path.
   - New command: DiLCONFIG allow user to set DiLEADER via Dialog Box.
   - DLMASK renamed to DiLMASK and DLCUSTOMARROW renamed to DiLCUSTOMARROW
     To respect DiL name standard.
   - New command DiLATTACH allow to created DiLEADER with exiting TEXT.
 :roll:
« Last Edit: September 08, 2009, 12:06:10 AM by Andrea »
Keep smile...
Aerdvark
« Reply #125 on: September 08, 2009, 01:49:08 AM »
Hi Andrea,
Looks great to me, might want to share the code with us?
You did not post the lisp routine itself.
Very well done!
Regards,
Marco
« Reply #126 on: September 08, 2009, 09:05:46 AM »
Great Job Andrea!
How many man hours do you have in the now? 8-)
« Reply #127 on: September 08, 2009, 09:53:57 AM »
is that a zen question?
alanjt
  • Standby for witty remark...
« Reply #128 on: September 08, 2009, 11:41:02 AM »
this thing is out of control. i can't compliment you enough on this Andrea.
Dropbox
Andrea
« Reply #129 on: September 08, 2009, 11:55:56 AM »
Oops !... :lmao:
sorry guys..
Well,...thanks for all your comments suggestions and compliments..
For me...It is not important how many hours, day or month I spent to make a program..
I always learn.  :kewl:
Keep smile...
Hugo
« Reply #130 on: September 08, 2009, 11:58:31 AM »
Hallo Andrea
Wo kann man die neue Version Uploaden.
Danke
« Reply #131 on: September 08, 2009, 12:14:38 PM »
No zen intended. :-)
Was genuinely interested in the count. Reflecting to past projects I know the hours just pile up.
Some roads I would not have gone down had I known. 8-)
Andrea
« Reply #132 on: September 08, 2009, 12:16:47 PM »
Hallo Andrea
Danke
hier, lade ich Sie auch Ihren Text mit diesem vor der Ausstrahlung übersetzt
Keep smile...
Hugo
« Reply #133 on: September 08, 2009, 02:48:22 PM »
Danke Andrea
Echt ein Super Lisp.
Danke Danke
architecture68-raff
  • Strange things are afoot at the Circle-K.
« Reply #134 on: September 08, 2009, 02:56:32 PM »
Ich habe nicht gewusst, dass jemand hier spricht Deutsch   :-)
Chicago, Illinois
ADT 2005, Revit Architecture 2009, Sketchup 7
