Author Topic: AutoStacking  (Read 8245 times)
cmwade77
AutoStacking
« on: October 28, 2010, 12:30:55 PM »
Ok, we are switching to stacked fractions here (finally).
So, I have a couple of challenges to come up with solutions to:
  • Find a way to turn on AutoStacking via our startup LISP routines and set it to use a / to separate the numbers, not a -
  • Find an easy way (LISP routine is preferred) to change all fractions to be stacked fraction
I have some ideas where to start on the second one, but I have no clue for the first one. If anyone has any ideas, I would love to hear them.
Correction: I thought I had an idea of where to start on the second one, but the method doesn't work, so any ideas there would be appreciated as well.
« Last Edit: October 28, 2010, 12:48:35 PM by cmwade77 »
Re: AutoStacking
« Reply #1 on: October 28, 2010, 12:58:01 PM »
With regards to first one, I believe the settings are stored here:
(strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\MTEXT")
Don't quote me on that though...
As for the second, I should imagine you could use a RegExp expression to replaces strings matching something like (\S)/(\S), then replace it with {$1#$2} or similar..
« Last Edit: October 28, 2010, 01:01:09 PM by Lee Mac »
hermanm
Re: AutoStacking
« Reply #2 on: October 28, 2010, 01:38:15 PM »
For DIMENSIONs without overridden text, it should be as easy as changing the fraction type in the dimension style.
For text overrides in DIMENSIONs, & MTEXT, you will first need to decide what the relative height of the fractions will be, and what type of fraction bar.
So, for example, if you want the relative height of the fractions to be 0.75, with a diagonal fraction bar,
3/8 becomes -> {\H0.75x;\S3#8;}
You will need to find  the n/m type fractions & substitute the stacked fraction representation.
dgorsman
Re: AutoStacking
« Reply #3 on: October 28, 2010, 02:07:56 PM »
You may want to make sure all required fractions are available in the font you are using in order to support non-MTEXT entities like attributes.  I seem to remember the OOTB RomanS.shx not having the "3/4" symbol defined, among others.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
cmwade77
Re: AutoStacking
« Reply #4 on: October 28, 2010, 03:57:22 PM »
Actually, with modern stacking that is not an issue any more, AutoCAD now takes and makes the first number a superscript and the second number a subscript and adjusts the / between them. This is one of the reasons that stacked fractions are not accepted here.
cmwade77
Re: AutoStacking
« Reply #5 on: October 28, 2010, 07:15:36 PM »
Ok, here is what I have so far, please see the attached screenshot for an example of what happens to the text....any ideas?
Re: AutoStacking
« Reply #6 on: October 28, 2010, 08:17:59 PM »
Did you use the curly braces?
EDIT: Sorry, didn't see you attached the code...
« Last Edit: October 28, 2010, 09:21:57 PM by Lee Mac »
hermanm
Re: AutoStacking
« Reply #7 on: October 28, 2010, 09:21:19 PM »
you forgot to escape the backslash preceding the H:
"{\H0.7x;\\S"
here is a more compact way of testing for a numerical character:
(defun isdigit (char)
  (if (> 58 (ascii char) 47) char nil)
Re: AutoStacking
« Reply #8 on: October 28, 2010, 09:33:53 PM »
This needs a lot more error trapping, but this is where I was going with the Regular Expression usage:
(defun c:test ( / RegEx i ss e )
  ;; © Lee Mac 2010
  (setq RegEx (vlax-create-object "VBScript.RegExp"))
  (if (setq i -1 ss (ssget "_:L" '((0 . "MTEXT"))))
    (while (setq e (ssname ss (setq i (1+ i))))
      (vla-put-TextString (vlax-ename->vla-object e)
        (LM:RegExReplace RegEx "{\\H0.7x;\\S$1#$2;}" "-?(\\d+)/(\\d+)" (LM:GetTextString e))
  (vlax-release-object RegEx)
(defun LM:RegExReplace ( reg new pat str )
  ;; © Lee Mac 2010
  (mapcar '(lambda ( prop value ) (vlax-put-property reg prop value)) '(pattern global ignorecase) (list pat actrue acfalse))
  (vlax-invoke reg 'replace str new)
(defun LM:GetTextString ( ent )
  ;; © Lee Mac 2010
  (  (lambda ( string )
       (mapcar
         (function
           (lambda ( pair )
             (if (vl-position (car pair) '(1 3))
               (setq string (strcat string (cdr pair)))
         (entget ent)
       string
« Last Edit: October 29, 2010, 01:03:11 PM by Lee Mac »
hermanm
Re: AutoStacking
« Reply #9 on: October 28, 2010, 11:13:18 PM »
Cool, Lee :)
Probably want to prefix the string with center justification code:
(strcat "\\A1;" <yourstring>)
Re: AutoStacking
« Reply #10 on: October 29, 2010, 06:54:05 AM »
Cool, Lee :)
Thanks Herman  8-)
cmwade77
Re: AutoStacking
« Reply #11 on: October 29, 2010, 11:36:28 AM »
"{\H0.7x;\\S"
Thank you, I can't believe that I missed it.
Lee,
I like your code, but I definitely do not understand it; however, we will often have fractions like: 12/15
Now here comes the challenge:
We will also have factions like: 2-12/15
These need to have the dash removed and the 12/15 stacked
Ok, I think I got it, including getting rid of the dash, I do need some more testing, so please let me know what you think, I have attached the code here.
« Last Edit: October 29, 2010, 12:17:30 PM by cmwade77 »
Re: AutoStacking
« Reply #12 on: October 29, 2010, 12:23:04 PM »
Code updated to allow for the dash  :-)
cmwade77
Re: AutoStacking
« Reply #13 on: October 29, 2010, 12:57:35 PM »
Lee,
The only issue I had was that it would not stack: 123/256 for example, can you replicate this? It woul only stack one number before and after the /
Re: AutoStacking
« Reply #14 on: October 29, 2010, 01:00:41 PM »
Lee,
Ah yes, I was only testing with single digits....
Updated.
