Author Topic: Virtual Memory Usage  (Read 1703 times)
snownut2
  • Bricscad 22 Ultimate
« on: December 11, 2012, 06:28:42 PM »
Odd question;
Is it possible to temporarily write a DCL file to virtual memory from a LISP, use it within that LISP then delete it from VIRTUAL Memory.  I am having issues writing the DCL file to disk as Windows 7 security features are a PITA.  Not sure if this would solve my issue, depending on the ease fo being able to do so.
If it is possible, any ideas on the coding.
Thanks,
Bruce
irneb
Re: Virtual Memory Usage
« Reply #1 on: December 12, 2012, 01:18:36 AM »
I think not, and also I think writing direct to VM would be even more of a PITA.
Have you tried writing the DCL to another folder? Generally I do this by writing to the folder in the TempPrefix system variable. You generally have write access to that folder.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #2 on: December 12, 2012, 01:19:40 AM »
  1. (setq f (open (strcat (getenv "USERPROFILE") "\\Desktop\\test.dcl") "w"))
or
  1. (setq f (open (strcat (getenv "TEMP") "\\test.dcl") "w"))
snownut2
« Reply #3 on: December 12, 2012, 03:33:41 AM »
Thanks,
ElpanovEvgeniy
worked just fine.
Bruce
« Reply #4 on: December 12, 2012, 05:05:47 AM »
For relatively small DCL files, I recommend:
  1. (setq tmp (vl-filename-mktemp nil nil ".dcl"))
  2.
  3. < Write & Load DCL file >
  4.
Example.
