Author Topic: Delete backup files more than a certain age  (Read 2984 times)
Chris
« on: August 27, 2009, 09:40:28 AM »
Currently I have an autosave program running that creates a drawing backup every 10 minutes and saves it in a folder on my hard drive. I would like to get a program that will delete all files automatically that are more than a certain age. I would like it to run automatically at a particular time and delete all files that are older than the previous month (if it ran today it would delete all files older than July 1, if it ran on September 1, it would delete all files older than August 1) Any suggestions?
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
Re: Delete backup files more than a certain age
« Reply #1 on: August 27, 2009, 09:53:18 AM »
Yes, I think this could be achieved, but you'd have to be careful  :wink:
Look into the functions: vl-file-delete and vl-file-systime
Lee
CHulse
« Reply #2 on: August 27, 2009, 09:55:00 AM »
I would think you could do that with a simple batch file and set it up as a scheduled task...
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
Chris
« Reply #3 on: August 27, 2009, 09:55:52 AM »
How would I create a list of the files in a folder so I could pass them to a while loop, or foreach that would delete the file if the systime is older than the specified date?
I could indeed use a batch file, I am already using one that will copy fonts to a user's fonts folder, but if I chose that method, how would I run it silently, I really only know how to run command prompt batch files and the command window popping up all the time may get a little annoying for some users.
Win 10
« Reply #4 on: August 27, 2009, 10:05:19 AM »
also look at (dos_filedate <fileName>)
(vl-directory-files dir pat dirs) ; recognizes wildcards - CAB only "L*.dwg" basic letters not real wildcards
(vl-directory-files  [directory pattern directories])
directory
A string naming the directory to collect files for; if nil or absent, vl-directory-files uses the current directory.
pattern
A string containing a DOS pattern for the file name; if nil or absent, vl-directory-files assumes "*.*"
directories
 An integer that indicates whether the returned list should include directory names. Specify one of the following:
-1  List directories only.
0   List files and directories (the default).
1   List files only.
Return Values
A list of file and path names, or nil, if no files match the specified pattern.
CHulse
« Reply #5 on: August 27, 2009, 10:10:21 AM »
Ahh, that's true. I don't know how you could make a batch run silent...
Cary Hulse
Chris
« Reply #6 on: August 27, 2009, 10:12:06 AM »
maybe not silent, but minimized?
Win 10
Chris
« Reply #7 on: August 27, 2009, 10:16:53 AM »
directory
pattern
directories
1   List files only.
Return Values
I think it gets to a certain length and then truncates the rest of the output.  Whenever the program is run, the folder will probably contain between 1000-2000 dwg files.
Win 10
« Reply #8 on: August 27, 2009, 10:25:11 AM »
I don't have any folders like that to test but you could loop the function feeding it one letter at at time.
Loop
(setq fnames (append (vl-directory-files dir (strcat First_letter "*.dwg")  dirs) fnames))
« Reply #9 on: August 27, 2009, 10:40:16 AM »
So this is something you're going to deploy to all users?
Chris
« Reply #10 on: August 27, 2009, 10:42:59 AM »
yes, this is something that I plan on deploying to all users.  AutoCAD's autosave feature doenst really work when you need it, so I plan on giving this autosave program to everyone. I just need to set it up so they dont need to be concerned about their harddrive filling up.
Win 10
« Reply #11 on: August 27, 2009, 10:55:41 AM »
See Help: Start and Exit
Chris
« Reply #12 on: September 03, 2009, 09:36:02 AM »
to solve my issue, I created a fake file that gets updated every day, so it always has the current date for the vl-file-systime then I compare the cadr of the list to the cadr of all the other items in the folder (cadr is the month number) and if the month number is >= 2 the file gets deleted.  I put all the files in a folder into a list using
(setq
      dwglst (mapcar
       '(lambda (x) (strcat "C:/autocad log files/" x))
       (vl-directory-files "C:/autocad log files/" "*.log" 1)
     ) ;_ end of mapcar
and then use foreach to filter each drawing.
I would post my code, but it would need a lot of revising for it to work for anyone else, I have a lot of office specific paths and files specified.
Win 10
