Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
How to insert these set of dimensions?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How to insert these set of dimensions? (Read 2430 times)
HasanCAD
Swamp Rat
on:
February 23, 2019, 03:37:05 PM »
Hi all
I am working on a Roads project.
The task is adding these dimesions
I tried several times to code this lisp but can not
Option one there is itermediate iland and another one is no itermediate island
attached a sample file
Thanks in advance
Last Edit: February 28, 2019, 09:16:23 AM by HasanCAD
Logged
Sorry for my English.
Donate to Theswamp
www.sergiwa.com
Tharwat
Swamp Rat
Hypersensitive
WWW
Re: How to insert these set of dimensions?
Reply #1 on:
March 01, 2019, 04:21:01 PM »
This should get you started and would sort the list of coordinates according to the shortest distance to point one ( variable 'p1' ) then you can iterate the coordinates and create the dimensions based on that.
Code - Auto/Visual Lisp:
[Select]
and
setq
p1
getpoint
\n
Specify first point :"
setq
p2
getpoint
\n
Next point :"
p1
setq
ss
ssget
"_C"
p1 p2 '
0
"LINE"
repeat
setq
i
sslength
ss
setq
pts
cons
vlax-curve-getclosestpointto
ssname
ss
setq
i
1-
i
p1
pts
setq
pts
vl-sort
pts '
lambda
a b
distance
p1 a
distance
p1 b
Logged
HVAC, Plumbing, Drainage, Electricity , Fire Fighting Programs and many more .....
HasanCAD
Swamp Rat
Reply #2 on:
March 01, 2019, 08:30:57 PM »
This What i ened up to
Created a cad file has a set of dimentions as 3 blocks then insert the block related to number of selected lines
the lisp working good for first selection of lines but the second
Attached the cad file and a screenshoot for the error
Thanks in advance
[Select]
DEFUN
C:RoadDimensionInsert
ANG BN BOBJ CLYR CNT DIS DISS DOC DTLST LST N1 OBJS OBJVL OSNP P1 P1N P2 PNTS
LST PNTS
LST
1
PNTS
LSTR PNTS
LSTS SPC SSLNGTH X
setq
acad
cond
acad
vlax-get-acad-object
setq
doc
vla-get-ActiveDocument
setq
acad
vlax-get-Acad-Object
spc
if
zerop
vla-get-activespace
doc
if
vla-get-mspace
doc
:vlax-true
vla-get-modelspace
doc
vla-get-paperspace
doc
vla-get-modelspace
doc
setq
uFlag
not
vla-StartUndoMark
doc
setq
osnp
getvar
"osmode"
setvar
"osmode"
0
setq
clyr
getvar
"CLAYER"
setq
diss
nil
setq
dtlst
nil
if
MakeLayer
"TEMP"
8
"Continuous"
0.01
nil
0
"TEMP LAYER"
progn
setq
clyr
getvar
"CLAYER"
setvar
"CLAYER"
"TEMP"
setvar
"CLAYER"
"Defpoints"
if
and
vl-cmdf
"_.-insert"
"C:/RoadDimension/RoadDimension.dwg"
"0,0,0"
"1"
"1"
"0"
; inser blocks
tblsearch
"BLOCK"
"RoadDimension"
progn
vl-cmdf
"_.erase"
"last"
vl-cmdf
"_.-purge"
"blocks"
"RoadDimension"
"n"
while
and
setq
p1
getpoint
\n
Pick Dimension Point at left side of road "
;(setvar "osmode" 128)
setq
p2
getpoint
p1
\n
Pick Dimension Point at right side of road"
setq
objs
ssget
"_C"
p1 p2
cond
10
setq
SSLngth
sslength
objs
HSN:10lines
8
setq
SSLngth
sslength
objs
HSN:8lines
6
setq
SSLngth
sslength
objs
HSN:6lines
T
alert
\n
No lines selected
\n
Try to isolate road lines then reuse the lisp"
setvar
"osmode"
osnp
setvar
"CLAYER"
clyr
setq
uFlag
vla-EndUndoMark
doc
defun
*error*
msg
and
uFlag
vla-EndUndoMark
doc
or
wcmatch
strcase
msg
"*BREAK,*CANCEL*,*EXIT*"
princ
strcat
\n
** Error: "
msg
setvar
"osmode"
osnp
setvar
"cmdecho"
cmd
princ
defun
HSN:10lines
repeat
setq
cnt
sslength
objs
setq
objVL
vlax
ename
vla-object
ssname
objs
setq
cnt
1-
cnt
setq
p1n
objVL p1
setq
dtlst
cons
p1n dtlst
setq
dis
distance
p1 p1n
setq
diss
cons
dis diss
setq
lst
gc
:sort diss
setq
n1
nth
0
lst
setq
lst
mapcar
lambda
x
x n1
lst
setq
lst
vl-remove
nth
0
lst
lst
setq
pnts
lst
SortPointList 'XYZ 1e
3
dtlst
setq
pnts
lstS
vl-remove
nth
0
pnts
lst
pnts
lst
setq
pnts
lstR
reverse
pnts
lst
setq
pnts
lst
1
nth
0
pnts
lst
setq
ang
angle
pnts
lst
1
nth
0
pnts
lstR
setq
bn
strcat
"RoadDim-"
itoa
SSLngth
vl-catch-all-error-p
setq
bobj
vl
catch
all
apply
function
vla-InsertBlock
list
spc
vlax-3D-point
pnts
lst
1
bn
1.0
1.0
1.0
ang
LM:setdynprops
bobj
list
cons
"0"
nth
0
lst
cons
"1"
nth
1
lst
cons
"2"
nth
2
lst
cons
"3"
nth
3
lst
cons
"4"
nth
4
lst
cons
"5"
nth
5
lst
cons
"6"
nth
6
lst
cons
"7"
nth
7
lst
cons
"8"
nth
8
lst
command
"_.EXPLODE"
"Last"
defun
HSN:8lines
repeat
setq
cnt
sslength
objs
setq
objVL
vlax
ename
vla-object
ssname
objs
setq
cnt
1-
cnt
setq
p1n
objVL p1
setq
dtlst
cons
p1n dtlst
setq
dis
distance
p1 p1n
setq
diss
cons
dis diss
setq
lst
gc
:sort diss
setq
n1
nth
0
lst
setq
lst
mapcar
lambda
x
x n1
lst
setq
lst
vl-remove
nth
0
lst
lst
setq
pnts
lst
3
dtlst
setq
pnts
lstS
vl-remove
nth
0
pnts
lst
pnts
lst
setq
pnts
lstR
reverse
pnts
lst
setq
pnts
lst
1
nth
0
pnts
lst
setq
ang
angle
pnts
lst
1
nth
0
pnts
lstR
setq
bn
strcat
"RoadDim-0"
itoa
SSLngth
setq
bobj
vl
catch
all
apply
function
vla-InsertBlock
list
spc
vlax-3D-point
pnts
lst
1
bn
1.0
1.0
1.0
ang
LM:setdynprops
bobj
list
cons
"0"
nth
0
lst
cons
"1"
nth
1
lst
cons
"2"
nth
2
lst
cons
"3"
nth
3
lst
cons
"4"
nth
4
lst
cons
"5"
nth
5
lst
cons
"6"
nth
6
lst
command
"_.EXPLODE"
"Last"
defun
HSN:6lines
repeat
setq
cnt
sslength
objs
setq
objVL
vlax
ename
vla-object
ssname
objs
setq
cnt
1-
cnt
setq
p1n
objVL p1
setq
dtlst
cons
p1n dtlst
setq
dis
distance
p1 p1n
setq
diss
cons
dis diss
setq
lst
gc
:sort diss
setq
n1
nth
0
lst
setq
lst
mapcar
lambda
x
x n1
lst
setq
lst
vl-remove
nth
0
lst
lst
setq
pnts
lst
3
dtlst
setq
pnts
lstS
vl-remove
nth
0
pnts
lst
pnts
lst
setq
pnts
lstR
reverse
pnts
lst
setq
pnts
lst
1
nth
0
pnts
lst
setq
ang
angle
pnts
lst
1
nth
0
pnts
lstR
setq
bn
strcat
"RoadDim-0"
itoa
SSLngth
setq
bobj
vl
catch
all
apply
function
vla-InsertBlock
list
spc
vlax-3D-point
pnts
lst
1
bn
1.0
1.0
1.0
ang
LM:setdynprops
bobj
list
cons
"0"
nth
0
lst
cons
"1"
nth
1
lst
cons
"2"
nth
2
lst
cons
"3"
nth
3
lst
cons
"4"
nth
4
lst
command
"_.EXPLODE"
"Last"
;; Set Dynamic Block Properties - Lee Mac
;; Modifies values of Dynamic Block properties using a supplied association list.
;; blk - [vla] VLA Dynamic Block Reference object
;; lst - [lst] Association list of ((<Property> . <Value>) ... )
;; Returns: nil
defun
LM:setdynprops
blk lst
itm x
setq
lst
mapcar
lambda
x
cons
strcase
car
x
cdr
x
lst
foreach
x
vlax-invoke
blk 'getdynamicblockproperties
if
setq
itm
assoc
strcase
vla
get
propertyname x
lst
vla
put
value
x
vlax
make
variant
cdr
itm
vlax
variant
type
vla-get-value
x
; END DEFUN - LM:setdynprops
defun
SortPointList
fA fz dx dy dz pL
fp f
if
and
setq
fp
cadr
assoc
fA
list
list
'XYZ
lambda
a b c
if
a
if
b
if
c
dz z1 z2
dz z1 z2
dy y1 y2
dx x1 x2
list
'XZY
lambda
a b c
if
a
if
c
if
b
dy y1 y2
dy y1 y2
dz z1 z2
dx x1 x2
list
'YXZ
lambda
a b c
if
b
if
a
if
c
dz z1 z2
dz z1 z2
dx x1 x2
dy y1 y2
list
'YZX
lambda
a b c
if
b
if
c
if
a
dx x1 x2
dx x1 x2
dz z1 z2
dy y1 y2
list
'ZXY
lambda
a b c
if
c
if
a
if
b
dy y1 y2
dy y1 y2
dx x1 x2
dz z1 z2
list
'ZYX
lambda
a b c
if
c
if
b
if
a
dx x1 x2
dx x1 x2
dy y1 y2
dz z1 z2
setq
f
lambda
p1 p2
x1 y1 z1 x2 y2 z2 a b c
mapcar
set
x1 y1 z1
p1
mapcar
set
x2 y2 z2
p2
mapcar
set
a b c
mapcar
function
lambda
a b
equal
a b fz
p1 p2
fp a b c
vl-sort
pL
function
f
; defun SortPointList
defun
gc
:sort
lst fun
merge tmp
defun
merge
l1 l2
cond
null
l1
l2
null
l2
l1
fun
car
l1
car
l2
cons
car
l1
merge
cdr
l1
l2
T
cons
car
l2
merge l1
cdr
l2
setq
fun
eval
fun
lst
mapcar
list
lst
while
cdr
lst
setq
tmp lst lst
nil
while
cdr
tmp
setq
lst
cons
merge
car
tmp
cadr
tmp
lst
tmp
cddr
tmp
and
tmp
setq
lst
cons
car
tmp
lst
car
lst
defun
MakeLayer
name colour linetype lineweight willplot bitflag description
regapp
"AcAecLayerStandard"
;; (MakeLayer name colour linetype lineweight willplot bitflag description )
;; Specifications:
;; Description Data Type Remarks
;; Layer Name STRING Only standard chars allowed
;; Layer Colour INTEGER may be nil, -ve for Layer Off, Colour < 256
;; Layer Linetype STRING may be nil, If not loaded, CONTINUOUS.
;; Layer Lineweight REAL may be nil, 0 <= x <= 2.11
;; Plot? BOOLEAN T = Plot Layer, nil otherwise
;; Bit Flag INTEGER 0=None, 1=Frozen, 2=Frozen in VP, 4=Locked
;; Description STRING may be nil for no description
;; Function will return list detailing whether layer creation is successful.
;; © Lee Mac 2010
or
tblsearch
"LAYER"
name
entmake
append
list
cons
0
"LAYER"
cons
100
"AcDbSymbolTableRecord"
cons
100
"AcDbLayerTableRecord"
cons
2
name
cons
70
bitflag
cons
290
if
willplot
1
0
cons
6
if
and
linetype
tblsearch
"LTYPE"
linetype
linetype
"CONTINUOUS"
cons
62
if
and
colour
0
abs
colour
256
colour
7
cons
370
fix
100
if
and
lineweight
0.0
lineweight
2.11
lineweight
0.0
if
description
list
list
3
list
cons
1000
cons
1000
description
Logged
Donate to Theswamp
www.sergiwa.com
Tharwat
Swamp Rat
Hypersensitive
WWW
Reply #3 on:
March 02, 2019, 04:42:18 AM »
Try the following program and be sure is that the program would select the crossed Line objects only and ignores polylines and I am raising this issue because you already have polyline objects among the lines that represents the road routes as in the above attached sample drawing.
[Select]
defun
c:dimroad
p1 p2 ss i bkn int pts doc ins ang blk prs bse
;; Tharwat - 02.Mar.2019 ;;
if
and
setq
p1
getpoint
\n
setq
p2
getpoint
\n
Next point :"
p1
setq
ss
ssget
"_C"
p1 p2 '
0
"LINE"
setq
i
sslength
ss
if
or
i
6
i
8
i
10
or
tblsearch
"BLOCK"
setq
bkn
strcat
"RoadDim-"
if
i
10
"10"
strcat
"0"
itoa
i
alert
strcat
"Block name <"
bkn
"> not found in current drawing."
alert
"Number of collected lines are not equal to 6 or 8 nor to 10"
setq
int
1
repeat
i
setq
pts
cons
ssname
ss
setq
i
1-
i
p1
pts
setq
pts
vl-sort
pts
lambda
a b
distance
p1 a
distance
p1 b
setq
doc
ins
last
pts
ang
angle
car
pts
ins
if
and
ang
pi
0.5
ang
pi
1.5
setq
ang
pi ang
setq
ins
car
pts
progn
vla-endUndomark
doc
vla-StartUndoMark
doc
setq
blk
entmakex
list
0
"INSERT"
cons
10
ins
cons
2
bkn
cons
50
ang
41
1.0
42
1.0
43
1.0
prs
vlax-invoke
vlax
ename
vla-object
blk
'getdynamicBlockproperties
pts
reverse
pts
bse
car
pts
mapcar
lambda
d
setq
int
1+
int
vl-some
lambda
x
if
vla
get
propertyname x
itoa
int
progn
vlax-put
x 'Value
distance
bse d
t
prs
cdr
pts
vla-endUndomark
doc
princ
vl-load-com
Logged
HasanCAD
Swamp Rat
Reply #4 on:
March 03, 2019, 12:00:55 PM »
OK
Thanks for your lisp but whats making my lisp not working.
Logged
Donate to Theswamp
www.sergiwa.com
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
