Author Topic: zoom extents in all layouts (help with routine)  (Read 2602 times)
alanjt
  • Standby for witty remark...
« on: May 01, 2008, 03:45:16 PM »
i found this floating around here a while back. i use it regularly, but i was wondering if it is possible to change it so it will NOT zoom extents in modelspace in addition to zoom extents in all paperspace layouts?
if i remember correctly it was alan's code, but i'm not 100% on that, it was undocumented and i completely forgot to say who did it.
;zoom extents in all layouts
(defun c:zal (/ *acad* *doc* layouts ct lay)
  (setq   *acad*   (vlax-get-acad-object)
   *doc*   (vla-get-activedocument *acad*)
   layouts   (vla-get-layouts *doc*)
  (setq ct (vla-get-activelayout *doc*))
  (vlax-for lay   layouts         ; step through layouts
    (vla-put-activelayout *doc* lay)   ; activate layout
    (if   (= (vla-get-activespace *doc*) 0) ; If in paperspace
      (if (= (vla-get-mspace *doc*) :vlax-true)
               ; in mspace viewport
   (vla-put-mspace *doc* :vlax-false) ; inactivate vp
      )               ; endif
    )               ;endif
    (vla-zoomextents *acad*)
  (vla-put-activelayout *doc* ct)
Dropbox
Guest
Re: zoom extents in all layouts (help with routine)
« Reply #1 on: May 01, 2008, 03:49:19 PM »
I don't know much about vlisp, but this line jumped out at me.
I'd say comment it out and let 'er rip.
I'm sure someone with more experience with vlisp will chime in and correct me if I'm wrong.
« Reply #2 on: May 01, 2008, 03:52:54 PM »
Check the layouts name, and if it isn't equal to Model, then let it do it's thing, but if it is, then just go to the layout.
« Reply #3 on: May 01, 2008, 06:23:38 PM »
This is what i use:
(defun c:zal (/ doc ct)
  (setq doc (vla-get-activedocument
ct  (vla-get-activelayout doc)
  (vlax-map-collection
    (vla-get-layouts doc)
    '(lambda (x)
       (if (/= (vla-get-name x) "Model")
   (vla-put-activelayout doc x)
   (if (= (vla-get-mspace doc) :vlax-true)
     (vla-put-mspace doc :vlax-false)
   (vla-zoomextents (vlax-get-acad-object))
  (vla-put-activelayout doc ct)
alanjt
« Reply #4 on: May 01, 2008, 08:09:47 PM »
This is what i use:
    '(lambda (x)
ronjonp, that's perfect. thank you for sharing.
Dropbox
« Reply #5 on: May 02, 2008, 09:53:25 AM »
Not a problem :)
