Author Topic: Civil3D - Structure Renumbering  (Read 2633 times)
MSTG007
« on: July 23, 2014, 07:36:51 AM »
I know Civil3D has the command to renumber a structure by selecting the upstream all the way to the downstream end. It will auto populate in between to create the range of numbers.
I did not know if there was a method to get civil3d to renumber the structures based on the order that you pick the structure(s).
Thanks again!
Civil3D 2020
Re: Civil3D - Structure Renumbering
« Reply #1 on: July 23, 2014, 08:44:33 AM »
is this a question, or a statement?
Pretty sure not going to renumber them in pick sequence....why don't you try and report back to us?
MSTG007
« Reply #2 on: July 23, 2014, 08:48:24 AM »
This would a question. I just tried it... I can not select individual structure parts to rename in a picking order...
Civil3D 2020
« Reply #3 on: July 23, 2014, 08:50:56 AM »
There is your answer.
MSTG007
« Reply #4 on: July 23, 2014, 08:54:25 AM »
Well lets try this question out. Is there a lisp or sort that can help accomplish this?
Civil3D 2020
