there are a few slide managers available here, you just have to find the one you want to use. A quick search will turn up an Autodesk executable variety, a lisp, vba and C# as well.
Is this the one:
I have been using sldmgr.exe to manage slide libraries since R12. In my latest computer upgrade I lost it. Can anyone provide this to me (or direct me to a source)?
Like I said, there are several available here ... the search mechanism isn't the best .. if you are in a particular form and use the search function, it only returns from that forum. Go to the main page of theswamp and do the search from there.
Searching "slides" I got these:http://www.theswamp.org/index.php?topic=30065.0http://www.theswamp.org/index.php?topic=25953.0http://www.theswamp.org/index.php?topic=19782.0
Quote from: CAB on September 03, 2010, 07:42:53 AMSearching "slides" I got these:http://www.theswamp.org/index.php?topic=30065.0http://www.theswamp.org/index.php?topic=25953.0http://www.theswamp.org/index.php?topic=19782.0Thanks CAB. The one Matt W provided is the one I'll I'll most likely use.
