Starting data size (doubled on each iteration) <25000.0000>:
Iterations <6>:
Working (do not use input devices while test is running)....
All times in seconds,
Data size: 25000, iterations: 10
Sort on Z-ordinate (parallel): 0.1060
Sort on Z-ordinate (sequential): 0.0880
Sort by distance from bp (parallel): 0.0640
Sort by distance from bp (sequential): 0.1500
Distance from bp to nearest point (parallel): 0.0000
Distance from bp to nearest point (sequential): 0.0100
Find point furthest from bp (parallel): 0.0260
Find point furthest from bp (sequential): 0.0260
Find point furthest from bp (sequential, no linq): 0.0200
Data size: 50000, iterations: 10
Sort on Z-ordinate (parallel): 0.2440
Sort on Z-ordinate (sequential): 0.2960
Sort by distance from bp (parallel): 0.1340
Sort by distance from bp (sequential): 0.2430
Distance from bp to nearest point (parallel): 0.0100
Distance from bp to nearest point (sequential): 0.0300
Find point furthest from bp (parallel): 0.0530
Find point furthest from bp (sequential): 0.0710
Find point furthest from bp (sequential, no linq): 0.0300
Data size: 100000, iterations: 10
Sort on Z-ordinate (parallel): 0.2190
Sort on Z-ordinate (sequential): 0.4510
Sort by distance from bp (parallel): 0.2590
Sort by distance from bp (sequential): 0.6370
Distance from bp to nearest point (parallel): 0.0220
Distance from bp to nearest point (sequential): 0.0950
Find point furthest from bp (parallel): 0.1250
Find point furthest from bp (sequential): 0.1320
Find point furthest from bp (sequential, no linq): 0.0700
Data size: 200000, iterations: 10
Sort on Z-ordinate (parallel): 0.5590
Sort on Z-ordinate (sequential): 1.0910
Sort by distance from bp (parallel): 0.4390
Sort by distance from bp (sequential): 1.2250
Distance from bp to nearest point (parallel): 0.0520
Distance from bp to nearest point (sequential): 0.1420
Find point furthest from bp (parallel): 0.2100
Find point furthest from bp (sequential): 0.3150
Find point furthest from bp (sequential, no linq): 0.1390
Data size: 400000, iterations: 10
Sort on Z-ordinate (parallel): 1.6490
Sort on Z-ordinate (sequential): 2.0270
Sort by distance from bp (parallel): 0.8690
Sort by distance from bp (sequential): 2.2600
Distance from bp to nearest point (parallel): 0.1130
Distance from bp to nearest point (sequential): 0.2940
Find point furthest from bp (parallel): 0.6280
Find point furthest from bp (sequential): 0.6700
Find point furthest from bp (sequential, no linq): 0.2920
Data size: 800000, iterations: 10
Sort on Z-ordinate (parallel): 2.5790
Sort on Z-ordinate (sequential): 4.6060
Sort by distance from bp (parallel): 2.8200
Sort by distance from bp (sequential): 5.1220
Distance from bp to nearest point (parallel): 0.2080
Distance from bp to nearest point (sequential): 0.6470
Find point furthest from bp (parallel): 0.4210
Find point furthest from bp (sequential): 0.9120
Find point furthest from bp (sequential, no linq): 0.5660
