Author Topic: Lisp for convert drawing units  (Read 5581 times)
LaPan
« on: September 13, 2007, 09:43:18 PM »
Is there a lisp that can change drawing from; example inches to mm?
Right now what am I doing is manually scale the drawing.....
Lisp 'Guru' out there can u help me?
kpblc
Re: Lisp for convert drawing units
« Reply #1 on: September 14, 2007, 01:46:02 AM »
(setvar "lunits" 2) perhaps?
Sorry for my English.
VVA
« Reply #2 on: September 14, 2007, 01:56:17 AM »
Or
(setvar "insunits" 4) ;_mm
(setvar "insunits" 1) ;_inches
« Reply #3 on: September 14, 2007, 05:21:30 AM »
Exactly what do you want to convert ?
Just the drawing entitys or more or everything. ?
What have you tried ?
... and what are you doing manually .. exactly ?
LaPan
« Reply #4 on: September 16, 2007, 09:15:17 PM »
Ok, like this.
I'm working on drawing that using MM as a default unit.
I want to insert drawing from other consultant that using inches or feet as their default units.
When I insert their drawing to my drawing, the drawing become to small and I must scale it up to match with my drawing.
So, is there a way that I can do so that drawing automatically become in same units/scale with my drawing when I'm insert it?
Jeff_M
  • C3D user & customizer
« Reply #5 on: September 16, 2007, 09:56:31 PM »
Look into the INSUNITS, INSUNITSDEFSOURCE, and INSUNITSDEFTARGET sytem variables.
« Reply #6 on: September 16, 2007, 10:07:58 PM »
What Jeff said ^^
General tip for next time :
If the question had been asked as per post Reply#4 you may have had this answer 4 days ago.
