Author Topic: SelectionFilterBuilder  (Read 9233 times)
It's Alive!
  • Retired
  • AKA Daniel
« on: January 01, 2010, 11:22:25 AM »
Just reading David's blog  http://blog.davidkblackmon.com/
here is my easier way for C#  :laugh:
using System.Text;
namespace ExecMethod
 public class SelectionFilterBuilder : List<TypedValue>
  public SelectionFilterBuilder()
  public SelectionFilterBuilder(DxfCode code, params string[] list)
   base.Add(new TypedValue((short)code, FormatString(list)));
  // Methods
  public void AddDxfCode(DxfCode code, object val)
   base.Add(new TypedValue((short)code, val));
  public void AddEntityFilter(params string[] list)
   base.Add(new TypedValue(0, FormatString(list)));
  public void AddLayerFilter(params string[] list)
   base.Add(new TypedValue(8, FormatString(list)));
  internal static string FormatString(params string[] list)
   StringBuilder sb = new StringBuilder();
   foreach (string s in list)
    sb.Append(s);
    sb.Append(",");
   sb.Remove(sb.Length - 1, 1);
   return sb.ToString();
  public static implicit operator SelectionFilter(SelectionFilterBuilder src)
   return new SelectionFilter(src.ToArray());
then
 [CommandMethod("doit")]
  static public void doit()
   Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
   var builder = new SelectionFilterBuilder();
   builder.AddEntityFilter("CIRCLE","LINE");
   builder.AddLayerFilter("1","2");
   var acSSPrompt = acDocEd.GetSelection(builder);
   if (acSSPrompt.Status == PromptStatus.OK)
    SelectionSet acSSet = acSSPrompt.Value;
    Application.ShowAlertDialog(String.Format("{0}: ",acSSet.Count));
    return;
   Application.ShowAlertDialog("Number of objects selected: 0");
or
   var builder = new SelectionFilterBuilder(DxfCode.Start, "CIRCLE","LINE");
    return;
« Last Edit: January 01, 2010, 11:35:03 AM by Daniel »
xsfhlzh
Re: SelectionFilterBuilder
« Reply #1 on: January 03, 2010, 09:41:15 AM »
That's good
I have improved a bit, so that may be more concise writing
using System;
using System.Text;
namespace TlsCad.Collections
    /// <summary>
    /// TypedValue Collection
    /// </summary>
    public class ResultList : List<TypedValue>
        public ResultList()
            : base()
        public ResultList(IEnumerable<TypedValue> collection)
            : base(collection)
        public void Add(int typeCode, object obj)
            base.Add(new TypedValue(typeCode, obj));
        public void Add(LispDataType type, object obj)
            base.Add(new TypedValue((int)type, obj));
        public void Add(DxfCode type, object obj)
        public override string ToString()
            return ((ResultBuffer)this).ToString();
        public static implicit operator TypedValue[](ResultList rlst)
            return rlst.ToArray();
        public static implicit operator ResultBuffer(ResultList rlst)
            return new ResultBuffer(rlst.ToArray());
        public static implicit operator SelectionFilter(ResultList rlst)
            return new SelectionFilter(rlst.ToArray());
Test Code
            PromptSelectionResult res4 =
                ed.SelectAll(
                    new ResultList
                        {-4,"<or"},
                            {-4,"<and"},
                                {0, "Line"},
                                {8, "01"},
                            {-4,"and>"},
                            {-4,"<and"},
                                {0, "Circle"},
                                {8, "02"},
                            {-4,"and>"},
                        {-4,"or>"}
xsfhlzh
« Reply #2 on: January 03, 2010, 09:47:39 AM »
Another version
using System;
using System.Text;
using System.Collections;
    /// <summary>
    /// TypedValue Tree
    /// </summary>
    public enum ResultType
        Node,
        List,
        DottedPair,
        RelationalOperator,
        LogicalOperator,
    public class ResultTree : IEnumerable
        ResultType _type;
        TypedValue _value;
        List<ResultTree> _lst = new List<ResultTree>();
        public ResultTree this[int index]
            get
                if (_lst.Count==0)
                    if(index==0)
                        return this;
                else
                    if (index>=0 && index < _lst.Count)
                        return _lst[index];
                return null;
        public TypedValue TypedValue
            get { return _value; }
        public List<ResultTree> Nodes
            get { return _lst; }
        public ResultType Type
            get { return _type; }
        public ResultTree()
            _type = ResultType.Node;
        public ResultTree(TypedValue value)
            :this()
            _value = value;
        public ResultTree(int typeCode, object obj)
            : this(new TypedValue(typeCode, obj))
        public ResultTree(LispDataType type, object obj)
            : this(new TypedValue((int)type, obj))
        public ResultTree(DxfCode type, object obj)
        public ResultTree(string operatorContext, bool isLogicalOperator)
            _type = isLogicalOperator ? ResultType.LogicalOperator : ResultType.RelationalOperator;
            _value = new TypedValue(-4, operatorContext);
        public ResultTree(string operatorContext)
            : this(operatorContext, true)
        public ResultTree(ResultType type)
            _type = type;
        public void Add(TypedValue value)
            _lst.Add(new ResultTree(value));
            _lst.Add(new ResultTree(typeCode, obj));
            _lst.Add(new ResultTree(type, obj));
        public void Add(ResultTree rt)
            _lst.Add(rt);
        public void Add(short value)
            _lst.Add(new ResultTree(LispDataType.Int16, value));
        public void Add(int value)
            _lst.Add(new ResultTree(LispDataType.Int32, value));
        public void Add(double value)
            _lst.Add(new ResultTree(LispDataType.Double, value));
        public void Add(string value)
            _lst.Add(new ResultTree(LispDataType.Text, value));
        public void Add(Point2d value)
            _lst.Add(new ResultTree(LispDataType.Point2d, value));
        public void Add(Point3d value)
            _lst.Add(new ResultTree(LispDataType.Point3d, value));
        public void Add(ObjectId value)
            _lst.Add(new ResultTree(LispDataType.ObjectId, value));
        public void Add(SelectionSet value)
            _lst.Add(new ResultTree(LispDataType.SelectionSet, value));
        public static implicit operator SelectionFilter(ResultTree rtree)
            return new SelectionFilter(rtree.ToArray());
        public static implicit operator ResultBuffer(ResultTree rtree)
            return new ResultBuffer(rtree.ToArray());
        public TypedValue[] ToArray()
            List<TypedValue> values = new List<TypedValue>();
            GetValues(values);
            return values.ToArray();
        private void GetValues(List<TypedValue> values)
            switch (_type)
                case  ResultType.Node:
                    if (_lst.Count == 0)
                        values.Add(_value);
                    else
                        _lst.ForEach(rtree => rtree.GetValues(values));
                    break;
                case ResultType.List:
                    values.Add(new TypedValue((int)LispDataType.ListBegin));
                    values.Add(new TypedValue((int)LispDataType.ListEnd));
                    break;
                case ResultType.DottedPair:
                    values.Add(new TypedValue((int)LispDataType.DottedPair));
                    break;
                case ResultType.RelationalOperator:
                    values.Add(_value);
                    break;
                case ResultType.LogicalOperator:
                    values.Add(new TypedValue(-4, "<" + _value.Value));
                    values.Add(new TypedValue(-4, _value.Value + ">"));
                    break;
        #region IEnumerable 成员
        IEnumerator IEnumerable.GetEnumerator()
            return _lst.GetEnumerator();
        #endregion
The complete test code
        [CommandMethod("t9")]
        public static void Test9()
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptSelectionResult res1 =
                ed.SelectAll(
                    new ResultTree
                        new ResultTree(">,>,*",false)
                            {10, new Point3d()}
                        new ResultTree("<,<,*",false)
                            {10,new Point3d(10,10,0)}
            PromptSelectionResult res2 =
                ed.SelectAll(
                    new ResultList
                        {-4,">,>,*"},
                        {10, new Point3d()},
                        {-4,"<,<,*"},
            PromptSelectionResult res3 =
                ed.SelectAll(
                    new ResultTree("or")
                        new ResultTree("and")
                            {0, "Line"},
                            {8, "01"}
                            {0, "Circle"},
                            {8, "02"}
                ed.SelectAll(
                    new ResultList
                        {-4,"<or"},
                            {-4,"<and"},
                                {0, "Line"},
                                {8, "01"},
                            {-4,"and>"},
                            {-4,"<and"},
                                {0, "Circle"},
                                {8, "02"},
                            {-4,"and>"},
                        {-4,"or>"}
        [CommandMethod("t10")]
        public static void Test10()
            PromptEntityResult res = ed.GetEntity("Select a Entity:");
            using (DBTransaction tr = new DBTransaction())
                tr.OpenRegAppTable(OpenMode.ForWrite);
                tr.RegApp("MyApp");
                Entity ent = tr.GetObject(res.ObjectId, OpenMode.ForWrite) as Entity;
                ent.XData =
                    new ResultList
                        {1001, "MyApp"},
                        {1000, "This is a Test"},
                        {DxfCode.ExtendedDataInteger16, 12}
        [LispFunction("lsptest1")]
        public static ResultBuffer LTest1(ResultBuffer rb)
            ResultTree rtree =
                new ResultTree(ResultType.List)
                    1,
                    new ResultTree(ResultType.DottedPair)
                        10,
                        new Point3d(10, 10, 0)
            return rtree;
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: January 03, 2010, 09:53:37 AM »
Nice work! That's similar to  this http://www.theswamp.org/index.php?topic=14495.msg186823#msg186823
I think the goal was to remove the need to remember the DXF group codes or having to look up from an Enum,
and maybe something like AddEntityFilter or AddLayerFilter would make building the filter more intuitive
penchaoxp
« Reply #4 on: January 03, 2010, 09:57:28 AM »
ding
xsfhlzh
« Reply #5 on: January 03, 2010, 10:16:54 AM »
However, the complex filtering is not a good realization of
For example, to select "01-layer line" or "02-layer Circle"
Can look at the code ResultTree class
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: January 03, 2010, 06:05:09 PM »
I agree, it would be difficult to build complex selection set filters with a user friendly class.
I like your ResultTree class, that's great work!
xsfhlzh
« Reply #7 on: January 03, 2010, 08:45:09 PM »
Thanks Daniel, I am truly honored.
xsfhlzh
« Reply #8 on: January 04, 2010, 08:10:59 AM »
Operator Overloading
This is more fun,:)
using System;
using System.Text;
        Node,
        List,
        DottedPair,
        RelationalOperator,
        LogicalOperator,
    /// <summary>
    /// TypedValue Tree
    /// </summary>
        ResultType _type;
        TypedValue _value;
            get
                if (_lst.Count==0)
                    if(index==0)
                        return this;
                else
                        return _lst[index];
                return null;
        #endregion
        public ResultTree()
            :this()
            _value = value;
            _type = type;
            _lst.Add(rt);
            switch (_type)
                        values.Add(_value);
                    else
                    break;
                    break;
                    break;
                    values.Add(_value);
                    break;
                    break;
            GetValues(values);
        private void MakeLogicalOperator(string operatorContext, ResultTree res)
            if (_type == ResultType.LogicalOperator && _value.Value.ToString() == operatorContext)
                _lst.ForEach(rtree => res.Add(rtree));
            else
                res.Add(this);
        public static ResultTree operator !(ResultTree rt1)
            ResultTree rt = new ResultTree("not") { rt1 };
            return rt;
        public static ResultTree operator &(ResultTree rt1, ResultTree rt2)
            ResultTree rt = new ResultTree("and");
            rt1.MakeLogicalOperator("and", rt);
            rt2.MakeLogicalOperator("and", rt);
            return rt;
        public static ResultTree operator |(ResultTree rt1, ResultTree rt2)
            ResultTree rt = new ResultTree("or");
            rt1.MakeLogicalOperator("or", rt);
            rt2.MakeLogicalOperator("or", rt);
            return rt;
        public static ResultTree operator ^(ResultTree rt1, ResultTree rt2)
            return
                new ResultTree("xor")
                    rt1,
                    rt2
test code
            ResultTree rt =
                new ResultTree(0, "Line") & new ResultTree(8, "01") & !new ResultTree(10, new Point3d())
                new ResultTree(0, "Circle") & new ResultTree(8, "02");
            Application.ShowAlertDialog(rt.ToString());
« Last Edit: January 04, 2010, 08:17:47 AM by xsfhlzh »
Bryco
« Reply #9 on: January 10, 2010, 12:35:03 PM »
I've been testing selectionsets versus objectIds for a selectall.
If you are only checking for types (circle arc etc) the objectId method is always faster.
However when you also check for layers etc, the selectionset is faster.
The function below is fairly easy to use
         static ObjectIdCollection SelectAll(string dxfNames)
             dxfNames = dxfNames.ToUpper();
             string[] dxf=dxfNames.Split(new char[] {','},StringSplitOptions.RemoveEmptyEntries);
             Document doc = acadApp.DocumentManager.MdiActiveDocument;
             ObjectIdCollection ids = new ObjectIdCollection();
                 BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                 DBDictionary ld = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
                 Layout layout = null;
                 foreach (DBDictionaryEntry l in ld)
                     layout = tr.GetObject(l.m_value, OpenMode.ForRead) as Layout;
                     BlockTableRecord space = (BlockTableRecord)tr.GetObject
                         (layout.BlockTableRecordId, OpenMode.ForRead);
                     foreach (ObjectId id in space)
                         foreach (string name in dxf)
                             if (id.ObjectClass.DxfName == name)
                                 ids.Add(id);
                                 break;
                 tr.Commit();
             return ids;
         } // end SelectAll
and how to call it
move = Matrix3d.Displacement(new Vector3d(0, -1, 0));
                foreach (ObjectId id in SelectAll("Line,Arc,Circle,ellipse"))
                    c = (Curve)tr.GetObject(id, OpenMode.ForRead);
                    if (c.Layer == "0")
                        count++;
                        c.UpgradeOpen();
                        c.TransformBy(move);
                tr.Commit();
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: January 11, 2010, 03:57:39 AM »
what about this?  :lol:
using AcDb = Autodesk.AutoCAD.DatabaseServices;
[assembly: CommandClass(typeof(ExecMethod.Commands))]
 public class ObjectIdDictionary : Dictionary<string, List<ObjectId>>
  private ObjectIdDictionary() { }
  public ObjectIdDictionary(Database database, ObjectId spaceid)
   AcDb.TransactionManager manager = database.TransactionManager;
   using (Transaction transaction = manager.StartTransaction())
    BlockTableRecord blockTableRecord =
     transaction.GetObject(spaceid, OpenMode.ForRead)
     as BlockTableRecord;
    foreach (ObjectId e in blockTableRecord)
     string key = e.ObjectClass.DxfName;
     if (this.ContainsKey(key))
      this[key].Add(e);
     else
      this.Add(key, new List<ObjectId> { e });
    transaction.Commit();
 public static class Commands
   Database database = HostApplicationServices.WorkingDatabase;
   ObjectIdDictionary dict = new ObjectIdDictionary(database, database.CurrentSpaceId);
    if (dict.ContainsKey("POINT"))
     foreach (ObjectId e in dict["POINT"])
      DBPoint o = transaction.GetObject(e, OpenMode.ForWrite) as DBPoint;
      o.ColorIndex = 1;
    if (dict.ContainsKey("LINE"))
     foreach (ObjectId e in dict["LINE"])
      Line o = transaction.GetObject(e, OpenMode.ForWrite) as Line;
      o.ColorIndex = 2;
    if (dict.ContainsKey("LWPOLYLINE"))
     foreach (ObjectId e in dict["LWPOLYLINE"])
      Polyline o = transaction.GetObject(e, OpenMode.ForWrite) as Polyline;
      o.ColorIndex = 3;
    if (dict.ContainsKey("CIRCLE"))
     foreach (ObjectId e in dict["CIRCLE"])
      Circle o = transaction.GetObject(e, OpenMode.ForWrite) as Circle;
      o.ColorIndex = 4;
xsfhlzh
« Reply #11 on: January 11, 2010, 06:51:11 AM »
I agree, but only through AC2010
Test it use Linq :-)
        [CommandMethod("t8")]
        public static void Test8()
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead);
                var dict = from ObjectId id in btr
                         group id by id.ObjectClass.DxfName;
                foreach (var ids in dict)
                    switch (ids.Key)
                        case "LINE":
                            foreach (var id in ids)
                                Entity ent = id.GetObject(OpenMode.ForWrite) as Entity;
                                ent.ColorIndex = 1;
                            break;
                        case "CIRCLE":
                                ent.ColorIndex = 3;
                            break;
                tr.Commit();
It's Alive!
  • Retired
  • AKA Daniel
« Reply #12 on: January 11, 2010, 07:58:16 AM »
Ha! that is cool   8-)
Bryco
« Reply #13 on: January 11, 2010, 10:50:42 AM »
The linq is about the same as Daniel's dictionary method (sometimes slightly slower)
Both are faster than mine which seems to point to objectidcollections being a bit slow.
It seems the dwg gets bigger, so I think you need to delete the dictionary after using it.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #14 on: January 11, 2010, 05:33:59 PM »
Bryco, compare this to yours for speed
   List<String> dxf = new List<string>
    (dxfNames.Split(new char[] { ',' }, StringSplitOptions.RemoveEmptyEntries));
   Document doc = AcAp.Application.DocumentManager.MdiActiveDocument;
       if (dxf.Contains(id.ObjectClass.DxfName))
        ids.Add(id);
    tr.Commit();
   return ids;
  } // end SelectAll
