Author Topic: Looking for improvments - ToBase10  (Read 1880 times)
mkweaver
« on: May 25, 2009, 01:43:04 PM »
I searched on line and was unable to find a routine that did quite what I needed.  Initially this started out as a binary to hex converter.  Needless to say it changed a bit.
This is going to be part of a routine to perform a CRC32 check on text strings and therefore will need to be about as fast as possible.  That said, I haven't spent any time optimizing for speed.
All suggestions welcome.
Mike
  Routine: ToBase10
  Purpose: Convert a number from any base between 2 and 36 to base 10
  Arguments: NumBase - integer where 2<= NumBase <= 36.  The number base from which we are
    converting.
  InputValue
    Symbol - example: '010010
    Number - example:   10010
    string - example: "010010" or "10010"
  Returns: The input value converted to base 10
  This routine is the inverse of the base routine found in the acad developement help files
    under "ASCII Code Conversion", hence, (tobase10 16 (base 16 5284)) returns 5284
  Example1: (tobase10 2 '11001011 )  returns      203
  Example2:     (tobase10 2  11001011 )  returns      203
  Example3:     (tobase10 2 "11001011")  returns      203
  Example4:     (tobase10 6 '15243 )     returns     2475
  Example5:     (tobase10 6  15243 )     returns     2475
  Example6:     (tobase10 6 "15243")     returns     2475
  Example7:     (tobase10 16 '34F1A )    returns   216858
  Example9:     (tobase10 16 "34F1A")    returns   216858
    Notice that '34F1A cannot be represented as a number, hence, only two examples
  Example10: (tobase10 36 '11001011 ) returns 60525828
  Example11:    (tobase10 36  11001011 ) returns 60525828
  Example12:    (tobase10 36 "11001011") returns 60525828
    As a check, use: http://pages.swcp.com/~spsvs/resume/BaseConversion/BaseConversion.html
(defun ToBase10 (NumBase InputValue / rtval)
    ((= 'str (type inputvalue))
     (setq inputvalue (strcase inputvalue))
    ((= 'SYM (type inputvalue))
     (setq InputValue (vl-symbol-name InputValue))
    ;;Base is not an integer
    ((not (= 'int (type NumBase)))
     (strcat
       "ERROR|ToBase10 base argument must be an integer - "
       (vl-prin1-to-string (type NumBase))
       " provided (" (vl-prin1-to-string NumBase) ")"
    ;;Base argument is out of range
    ((or
       (> 2 NumBase)
       (< 36 NumBase)
     (strcat
       "ERROR|ToBase10 Base argument must be greater than 1 and less than 36 - " (itoa NumBase) " provided."
    ;;InputValue is of wrong type for specified base
    ((and
       (> NumBase 10)
       (not (= 'STR (type InputValue)))
       "ERROR|Numbers in a base greater than 10 must be expressed as a string - ToBase routine."
    ;;InputValue has invalid characters
    ((not (vl-every
    (function
      (lambda (asciicode)
  ;;Character below "0" used
  ((< asciicode 48) nil)
  ;;Character greater than valid used for base less than or equal to 10
  ((and
     (<= NumBase 10)
     (> asciicode (+ 47 NumBase))
   nil
  ;;For base greater than 10, invalid character used
  ((and (> NumBase 10)
(not (wcmatch (chr asciicode) (strcat "[0-9],[A-" (chr (+ NumBase 54)) "]")))
   nil
  (T T)
    (vl-string->list (if (= 'INT (type InputValue))
       (itoa InputValue)
       InputValue
     (strcat
       "ERROR|Invalid InputValue argument provided to ToBase10 routine : " (vl-prin1-to-string InputValue)
    (T
     ;; "11001011" binary  203 decimal
     ;;  |||||||L-1*2^0 =   1
     ;;  ||||||L--1*2^1 =   2
     ;;  |||||L---0*2^2 =   0
     ;;  ||||L----1*2^3 =  16
     ;;  |||L-----0*2^4 =   0
     ;;  ||L------0*2^5 =   0
     ;;  |L-------1*2^6 =  64
     ;;  L--------1*2^7 = 128
     ;;         The sum = 203
     ;;  or
     ;; "15243" base 6 to 2475 decimal
     ;;  ||||L----3*6^0 =    3
     ;;  |||L-----4*6^1 =   24
     ;;  ||L------2*6^2 =   72
     ;;  |L-------5*6^3 = 1080
     ;;  L--------1*6^4 = 1296
     ;;         The sum = 2475
     ;;  or
     ;; "34F1A" base 16 to     decimal
     ;;  ||||L--10*16^0 =      10
     ;;  |||L--- 1*16^1 =      16
     ;;  ||L----15*16^2 =    3840
     ;;  |L----- 4*16^3 =   16384
     ;;  L------ 3*16^4 =  196608
     ;;         The sum =  216858
     ;;  concept compliments of: http://www.shunsoft.net/ipcalc/help/chap09.html
     (setq
       indx   0
       ;;Get the list of multipliers
       temp (mapcar
      (function
(lambda (x)
  (if (< 57 x)
    (- x 55)
    (- x 48)
      (reverse (vl-string->list
   (itoa InputValue)
   InputValue
       rtval   0
     (repeat (length temp)
       (setq
digit (nth indx temp)
rtval (+ rtval (* Digit (expt NumBase indx)))
indx  (1+ indx)
     rtval
Re: Looking for improvments - ToBase10
« Reply #1 on: May 02, 2010, 05:27:26 PM »
See here  :-)
