Author Topic: Values of VLAX-PUT & VLAX-GET ...  (Read 11135 times)
Re: Values of VLAX-PUT & VLAX-GET ...
« Reply #15 on: May 01, 2010, 08:21:54 AM »
Yes, but not exclusively.
Try this (hope I type this out on my blackberry correctly, ain't ez) --
(vlax-get (setq object (vlax-ename->vla-object (car (entsel)))) 'EntityType)
Then this --
(vla-get-entitytype object)
*faceplant*
« Reply #16 on: May 01, 2010, 01:05:50 PM »
Ooo didn't know about that one! In that case, I'm sure there are others. Thanks dude  :-)
alanjt
  • Standby for witty remark...
« Reply #17 on: May 01, 2010, 01:38:22 PM »
Then this --
*faceplant*
I know the returned integer pertains to the specific object, but what's the purpose of EntityType?
Dropbox
« Reply #18 on: May 03, 2010, 09:39:09 AM »
The succinct description from the property itself is "Returns the entity type of the object as an integer". Example, lines are 19, arcs are 4, circles 8 etc. Obviously they are members of an enumeration tho it appears not formally. That is, while I found the enumeration AcEntityName, with values confirming the preceding "lines are 19" etc. the return type for the EntityType property is not spec'd as AcEntityName but merely Long:
Property EntityType As Long
    read-only
    Member of AutoCAD.AcadLine
    Returns the entity type of the object as an integer.
