Hello again,
I receive dwgs from a client that does not use autocad. The way that program insert
blocks is that it gives it a random name every time it inserts it (even though its the same block)
..ex 1AD3C_PC_GROUP, 1BDD4_PC_GROUP. The problem is that all blocks are all in one layer. I
dont know if its a translation issue or just bad drafting. I need to select certain blocks & put it in
a seperate layer.
The block has text in it (not attributes)....Has anyone come up yet with a lisp program that can
select blocks that has a certain "text" string in it? Maybe text and attribute?
