Author Topic: ImageFrame....  (Read 2160 times)
Andrea
ImageFrame....
« on: June 16, 2005, 02:26:00 PM »
Hi all,..
a little question...
How can I keep "imageframe" in memory ?
I can't do (getvar "imageframe").....
is there any other variable ?
thanks
Keep smile...
dubb
ImageFrame....
« Reply #1 on: June 16, 2005, 02:33:20 PM »
well...cant you just use
(command "imageframe" "on")
Crank
ImageFrame....
« Reply #2 on: June 16, 2005, 02:54:33 PM »
There are three states 0, 1 or 2 so you can show the image but not having it plotted. This command is saving the value in the drawing in the dictionary ACAD_IMAGE_VARS.
Observere that AutoCAD 2006 has three states now 0, 1 or 2 but the dictionary value is 0, 1 or 3  :!:
A simple way to retrieve the value is:
(defun imageframe ()
  (setq dict (dictsearch (namedobjdict) "ACAD_IMAGE_VARS"))
  (if (not dict)
     0
     (cdr (assoc 70 dict))
Andrea
ImageFrame....
« Reply #3 on: June 16, 2005, 05:37:23 PM »
Quote from: dubb
not useful..
Keep smile...
Andrea
ImageFrame....
« Reply #4 on: June 16, 2005, 05:37:59 PM »
Quote from: Crank
  (if (not dict)
     0
thanks Crank..
Keep smile...
Andrea
ImageFrame....
« Reply #5 on: June 20, 2005, 01:51:27 PM »
Quote from: Andrea
Quote from: Crank
  (if (not dict)
     0
thanks Crank..
Oops,....Crank,
Your code is not working the first time..
need to run the "imageframe" first...
Keep smile...
Crank
ImageFrame....
« Reply #6 on: June 21, 2005, 07:26:13 AM »
Quote from: Andrea
Quote from: Andrea
Oops,....Crank,
The command IMAGEFRAME creates the dictionary. If the dictionary doesn't exist, then this function returnes 0 (= off).
So I don't think that you have to use the command IMAGEFRAME first to get the value.
