Author Topic: Convert a List to a String ...  (Read 6727 times)
Re: Convert a List to a String ...
« Reply #15 on: May 26, 2010, 03:11:09 PM »
'del' is an argument for the function.
del = delimiter, as in my explanation  :-)
alanjt
  • Standby for witty remark...
« Reply #16 on: May 26, 2010, 03:32:13 PM »
:lmao: :lmao:
My mind was clearly somewhere else. I called it deliminator in my explanation. :ugly:
Dropbox
« Reply #17 on: May 26, 2010, 06:20:43 PM »
:lmao: :lmao:
That does sound cooler  :lol:
Hangman
« Reply #18 on: May 26, 2010, 06:22:58 PM »
:lmao: :lmao:
That's what I interpreted,  'del' for delete or deliminator.   :D
Hangman  8)
alanjt
« Reply #19 on: May 26, 2010, 06:26:27 PM »
:lmao: :lmao:
It travels back in time and delimits all John and Sarah Connor's text.
Dropbox
« Reply #20 on: May 26, 2010, 11:16:00 PM »
Just something I was considering ... several options are available, but they don't give you the option to add a delimiter, unless of course you use lambda or some other equally useful function ... i.e.
(defun list->string (mylist)
  (apply 'strcat mylist)
(defun list->string (mylist delim)
  (setq str (car mylist))
  (vl-every '(lambda (x) (setq str (strcat str delim x))) (cdr mylist))
  str
The second bit of code, while not nearly as concise, allows the addition of delimiters.
To further expand the code, one might do a check for numerical values and convert them explicitly to strings ... that will likely require a bit of code to check for various situations, but as long as the type is going to be string, it may not be required.
