Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Convert plates blocks to multiple single bpoly (reactor) cut crossing by poly.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Convert plates blocks to multiple single bpoly (reactor) cut crossing by poly. (Read 1838 times)
LULU1965
Mosquito
on:
November 23, 2016, 07:21:35 AM »
Convert plates blocks to multiple single bpoly (reactor) cut crossing by poly. The blocks overlapping to itself but bpoly must be single for calculation of waste areas. Thanks for all help me. excuse for my English.
Logged
didier
Newt
expatrié
WWW
Re: Convert plates blocks to multiple single bpoly (reactor) cut crossing by poly.
Reply #1 on:
November 23, 2016, 07:29:20 AM »
Coucou
Do you need a program necessarily?
the command "_bpoly" will will make it very easy
friendly
Logged
eternal beginner ...
my english is not fluent ...
LULU1965
Mosquito
Reply #2 on:
November 23, 2016, 07:31:44 AM »
automatic multiple bpoly (attention rectangle overlapping bpoly not good).
Logged
LULU1965
Mosquito
Reply #3 on:
November 23, 2016, 07:36:20 AM »
The blocks overlap I have to get individual areas including overlapping and bpoly me divide (bpoly multiple but on every single block which is divided into two areas by the red polyline.
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Reply #4 on:
November 23, 2016, 07:57:22 AM »
Your blocks overlap... So, you can't use this code :
https://www.theswamp.org/index.php?topic=51605.msg567073#msg567073
Sorry, I can't further guide you... I think that you should only calculate waste, so exploding your blocks twice to lines is my opinion, but result is different than in your posted DWG...
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
LULU1965
Mosquito
Reply #5 on:
November 23, 2016, 08:03:59 AM »
I THINK IS POSSIBLE TO TRANSFORM BLOCKS WITH RECTANGLE POLYLINES.
Logged
ahsattarian
Newt
Reply #6 on:
September 30, 2022, 02:46:50 PM »
Maybe here REGION is the answer.
You can make the left side as a region and also change all pline rectangles into region.
The nbenefit INTERSECT commaand to create the common area which seems to be what you need.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
