Author Topic: Start up problem  (Read 2376 times)
mushrat
Start up problem
« on: September 12, 2007, 11:57:25 AM »
When I startup my LDD2004 I get this message like a lisp program is running at startup. I have to hit enter twice to clear it. Is there any way to detrermine which routine is the culprit? Thankyou.
AutoCAD menu utilities loaded.loaded
loaded
Select objects:
Error: no function definition: 11/14/02; error: extra right paren on input
FengK
Re: Start up problem
« Reply #1 on: September 12, 2007, 12:37:15 PM »
not tested. maybe try the following:
type VLIDE in command line to start the code editor. on menu, click "Debug" and then check "Break On Error".  leave the editor open and open another drawing, when error occurs, press Ctrl+F9, and see what happens in the code editor. it should jump to the line where problem exists.
mushrat
« Reply #2 on: September 12, 2007, 02:34:46 PM »
Thanks Kelie, that did it!
« Reply #3 on: September 12, 2007, 05:55:17 PM »
Good tip Kelie !
FengK
« Reply #4 on: September 12, 2007, 06:43:50 PM »
you're welcome.
FengK
« Reply #5 on: September 12, 2007, 06:45:56 PM »
