Author Topic: String translation  (Read 4051 times)
matrix2005in
String translation
« on: July 05, 2006, 02:38:41 PM »
hi
the code given below is translate  given string to another
(defun ceasar (txt /)
(vl-string-translate
"abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ"
"asdsdasdsdsadAKJHDFGKLJHDSFGKLHJDSSEFJK"
txt
(setq a
"can be anything that we dont know"
(DEFUN C:TET ()
(SETQ W (ceasar a))
(SETQ D (OPEN "C:\\TEST.TXT" "W"))
(SETQ AB (WRITE-LINE W D))
(CLOSE D)
(DEFUN C:TEP ()
(SETQ AG (OPEN "C:\\TEST.TXT" "R"))
(SETQ AH (READ-LINE AG))
(SETQ AS (ceasar AH)
(ALERT AS)
but this is not working....can any one help me??
thanks
mathew
ElpanovEvgeniy
  • Moscow (Russia)
Re: String translation
« Reply #1 on: July 05, 2006, 03:05:03 PM »
What should the program do?
    txt
  ) ;_  vl-string-translate
) ;_  defun
(DEFUN C:TET (A / AB D W)
  (SETQ W (ceasar a))
  (SETQ D (OPEN "C:\\TEST\\TEST.TXT" "W"));Replace the lengthy path
  (CLOSE D)
(setq a "can be anything that we dont know")
(C:TET a)
(DEFUN C:TEP ( / AG AH AS)
  (SETQ AG (OPEN "C:\\TEST\\TEST.TXT" "R"));Replace the lengthy path
  (CLOSE AG)
  (SETQ AS (ceasar AH))
  (ALERT AS)
Serge J. Gianolla
« Reply #2 on: July 05, 2006, 08:41:00 PM »
This was the code given to you by Bruno Toniutti, and I think it'd be nice to make a reference here, anyway he gave you the answer later on too:
>the encryption is working good but decryption wont..
you must use a rotation of 13 positions (a  (position 1) becomes (1 + 13) =
n  etc.) for an alphabet of 26 characters. Thus this algo works to encrypt
and decrypt.
Bruno Toniutti
(sorry for my english level)
    "nopqrstuvwxyzabcdefghijklmNOPQRSTUVWXYZABCDEFGHIJKLM"
    txt
Hi Evgeniy,
matrix2005in is none other than Mathew2006 you answere to in autodesk ng! - I know this thanks to LE :-)
matrix2005in
« Reply #3 on: July 05, 2006, 10:49:20 PM »
hi
yeah if you see i signing off with my name = "mathew" in both places
there is no catch in that..and another quetion "string stripping" i asked in both places and i got same people answerd...
mathew
Serge J. Gianolla
« Reply #4 on: July 05, 2006, 10:59:04 PM »
hi
mathew
Really! I must have misunderstood your answer then: http://www.theswamp.org/index.php?topic=10378.msg132250#msg132250
 :wink:
matrix2005in
« Reply #5 on: July 05, 2006, 11:11:35 PM »
hi Evgeniy
the same problem... the code is not decrypting or translating to its original form... :-(
matrix2005in
« Reply #6 on: July 05, 2006, 11:13:37 PM »
HA HA
my partner done that while i was not on my desk........ :-D
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: July 06, 2006, 02:53:59 AM »
and decrypt.
Bruno Toniutti
Not necessarily...  :-)
    " aAbBcCdDeEfFgGhHiIjJkKlLmMnNoOpPqQrRsStTuUvVwWxXyYzZ"
    "ZzYyXxWwVvUuTtSsRrQqPpOoNnMmLlKkJjIiHhGgFfEeDdCcBbAa "
    txt
) ;_  defun
; Test:
(setq str "can be anything that we dont know")
(setq crypt-str(ceasar a)) ; ->> "xzmZyvZzmbgsrmtZgszgZdvZwlmgZpmld"
(ceasar crypt-str) ; ->> "can be anything that we dont know"
matrix2005in
« Reply #8 on: July 06, 2006, 09:41:15 AM »
Yeah this code will work...my question is...
CRITERIA ONE
A) ENCRYPT/TRANSLATE SOME STRING USING THE SAME FUNCTION AND SAVE IN A TEXT FILE.
B) CALL  ENCRYPTED TEXT FILE ,READ MESSAGE AND DECRYPT SAME.
CRITERIA TWO
A) ENCRYPT/TRANSLATE SOME STRING USING THE SAME FUNCTION AND SAVE  TEXT FILE IN ONE MACHINE.
B) DECRYPT THE CONTENT IN ANOTHER MACHINE WITH SAME FUNCTION
thanks
mathew
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #9 on: July 06, 2006, 10:15:07 AM »
CRITERIA ONE
CRITERIA TWO
thanks
mathew
I asked it two weeks ago!  :-(
matrix2005in
« Reply #10 on: July 06, 2006, 10:41:40 AM »
oh :-)
OK then is there anyway to translate some word say my name "Mathew" to some other strings say "Fjgasj"  and decrypt back to the original  form...but that must be save in a text file and read/decrypt the same..
mathew
Andrea
« Reply #11 on: July 06, 2006, 03:46:18 PM »
oh :-)
mathew
take a look here... -> ;-)
Keep smile...
matrix2005in
« Reply #12 on: July 18, 2006, 10:57:31 AM »
is there anyone to resolve this?? :roll: :-(
Andrea
« Reply #13 on: July 21, 2006, 03:51:27 PM »
dont forget to close your file...
(DEFUN C:TEP ()
(CLOSE AG)
(ALERT AS)
(ALERT AH)
« Last Edit: July 21, 2006, 03:56:00 PM by Andrea »
Keep smile...
