Author Topic: Detect cannoscale change with the toolpalette  (Read 1438 times)
latour_g
« on: December 20, 2017, 10:05:31 AM »
Hi everyone,
Is there a way my tool palette can display the correct scale when the scale is change in AutoCAD ?
An event that could detect when the variable Cannoscale change, something like that..
Thank you
huiz
  • Certified Prof C3D
Re: Detect cannoscale change with the toolpalette
« Reply #1 on: December 20, 2017, 10:11:23 AM »
You can set an event on a variable change. If it is CANNOSCALE, you can update the Palette.
    private static void SystemVariableChanged(object sender, acAppServ.SystemVariableChangedEventArgs e) {
      if (e.Name == "CANNOSCALE" && e.Changed) { DoSomething(); }
latour_g
« Reply #2 on: December 20, 2017, 11:12:35 AM »
Great, that's what I need.  Thank you !
